The Blacker the Theater, The Better the Image - Page 32 - AVS Forum | Home Theater Discussions And Reviews
 1489Likes
post #931 of 4042 Old 07-13-2014, 02:33 PM
zombie10k's Avatar
Quoted: 3480 Post(s)
Liked: 3568
Agreed, I see images of some really nice home theaters, but it seems cosmetics are prioritized above performance - where as my take is the opposite.
as my room gets darker by the day, I think about this more often as I look through some of the build threads.
the improvements so far are amazing to see with content I am familiar with. The JVC's are screaming for a blacked out room..
zombie10k is offline
post #932 of 4042 Old 07-13-2014, 02:45 PM
cardoski's Avatar
Quoted: 1444 Post(s)
Liked: 1501
Originally Posted by ellisr63 View Post
Are you using the velvet for acoustic panels too? Our soffits are open frame, and we are filling them with Denim insulation. Will the velvet be ok... Or do I need something more porous?
Acoustic panels are next, but I would cover them in velvet. I recently got new speakers and I need to make covers for them so I have velvet on order, they are super distracting. Every little thing shows up in a velvet room.
It's always in the last place you look.
cardoski is offline
post #933 of 4042 Old 07-13-2014, 02:59 PM
zombie10k's Avatar
Liked: 3568
thanks for the painful reminder.... this is becoming highly obvious now that the entire wall where my screen is located is covered in pitch black velvet. my black speakers look grey in comparison.
post #934 of 4042 Old 07-13-2014, 03:30 PM
Done Deal DR's Avatar
Quoted: 98 Post(s)
Liked: 146
I'm certainly no expert on the subject, but from what reading I've done you cannot cover acoustic panels in velvet as sound doesn't pass through the velvet making whatever acoustic treatment material underneath moot. GOM seems to be the popular material to use, however finding anything near the blackness/darkness of velvet isn't possible.
ellisr63 likes this.
Home Theater Build in Progress (Contemporary living room, Klipsch RF-7 II 5.2 audio, Sony VPL-HW50ES Projector, Da-Lite 16:9 159" HP, recessed Mid Atlantic rack, etc)
Done Deal DR is offline
post #935 of 4042 Old 07-13-2014, 04:03 PM
cardoski's Avatar
Liked: 1501
I see, well panels are out then, super happy with sound anyway.
cardoski is offline
post #936 of 4042 Old 07-13-2014, 04:18 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
These panels might work. You should order a swatch of material. I am using them with no problem and the prices are good.
http://www.acoustimac.com/acoustic-p...oustic-panels/
cardoski likes this.
rwestley is offline
post #937 of 4042 Old 07-13-2014, 04:28 PM
DavidHir's Avatar
Quoted: 1944 Post(s)
Liked: 1583
There are a number of moments in high contrast, deep black scenes where my jaw just drops watching my RS4810. In fact, it just happened the other night watching Hellboy on Blu-ray.
DavidHir is offline
post #938 of 4042 Old 07-13-2014, 04:40 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
But for bass traps velvet is ok, correct?
Yamaha CX-A5100, JBL 8340A, 4 JBL 8320, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, .
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #939 of 4042 Old 07-13-2014, 04:45 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
I ended up doing the stage out of Home Depot black carpet... It is not as dark black as velvet for sure... Who knows, maybe I will change it to velvet later.
ellisr63 is offline
post #940 of 4042 Old 07-13-2014, 04:48 PM
DavidHir's Avatar
Liked: 1583
Not sure if I posted this before in this thread, but here is my latest. Rosco paint, "Tuxedo" black carpet, Protostar on side walls close to edge of Stewart ST100 screen. Not sure you can make it out, but on the far left side is a window blackout styrofoam panel covered with Duvetyne material.
DavidHir is offline
post #941 of 4042 Old 07-13-2014, 05:09 PM
dan webster's Avatar
Quoted: 185 Post(s)
Liked: 140
I am looking for a way to stop light from my screen from bouncing off the side of my 2 black tower speakers located on either side of my screen. I thought about using velvet but i am not sure ho to attach it on the speaker. Would the prostar material be an option?
Dolby Atmos 7.2.4 Marantz AV8802a processor Gemstone 200x7 Emotiva upa-500 amps
Oppo 103 Sony UBP-X800 4K Ultra HD Blu-ray Jvc RS500 projector Vivitek 1186 projector
Carada 110"BW screen Monster HTS 5100 MK11 power conditioner
Golden Ear Triton 5 L&R &super center XXL triton 7's sides Martin logan motion 12 rears
4 RSL C34 in ceiling SVS PB2-plus sub Outlaw LFM-1-plus sub
dan webster is offline
post #942 of 4042 Old 07-13-2014, 05:33 PM
zombie10k's Avatar
Liked: 3568
dan are the speakers flat on the side? Mine are and was considering covering 1/4 plywood with the velvet and then attaching them to the speakers with a bit of clear silicon caulking. This should allow it to be removed with no damage since that stuff holds but isn't like glue.
post #943 of 4042 Old 07-13-2014, 07:19 PM
eyekode's Avatar
Quoted: 23 Post(s)
It should be fine, not much absorbs or reflects low frequency.
Salem
ellisr63 and Done Deal DR like this.
eyekode is offline
post #944 of 4042 Old 07-13-2014, 08:48 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
Salem
ellisr63 is offline
post #945 of 4042 Old 07-13-2014, 08:57 PM
PrimeTime's Avatar
Quoted: 588 Post(s)
Liked: 289
With black (olefin) carpet (likely similar to Depot's), I have found that the darkness (or "reflectance," if you will) of the carpet varies with the grain-like orientation of the fibers.
I installed one strip on a wall in the "short" direction, and an adjacent strip on the same wall was spliced to it in the "long" direction. One strip looked definitely darker (from a given viewpoint) than the other, though they are the same carpet. I found that I could alter the grain of the lighter-appearing carpet section by combing it with a wire brush in a "favored" direction that made it appear darker and more closely matched the other segment.
PrimeTime is offline
post #946 of 4042 Old 07-13-2014, 08:58 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
Thanks, I will have to try that.
ellisr63 is offline
post #947 of 4042 Old 07-14-2014, 05:10 AM
TMA1's Avatar
Quoted: 14 Post(s)
TMA1 is offline
post #948 of 4042 Old 07-14-2014, 05:17 AM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 41
wow,now thats black!!
john2910 is offline
post #949 of 4042 Old 07-14-2014, 08:14 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Who wants to be first in line to place and order and brag about having the blackest home theater in the world.
john2910 likes this.
rwestley is offline
post #950 of 4042 Old 07-14-2014, 08:35 AM
zombie10k's Avatar
Liked: 3568
wow that is impressive... I want it! I'll call the the HT room 'The Abyss' titled after one of my favorite movies.
post #951 of 4042 Old 07-14-2014, 09:36 AM
cardoski's Avatar
Liked: 1501
[QUOTE=dan webster;25716057]I am looking for a way to stop light from my screen from bouncing off the side of my 2 black tower speakers located on either side of my screen. I thought about using velvet but i am not sure ho to attach it on the speaker. Would the prostar material be an option?[/QUOT
I am making covers that fit over the speaker but are not attached, I had some for my last speakers, no pictures, but when I finally get to finishing the covers will post.
cardoski is offline
post #952 of 4042 Old 07-14-2014, 11:05 AM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
[quote=cardoski;25732761]
Acoustats, and Vandersteens as I recall both had grill cloth socks. Here is a place that makes them for the Acoustats... http://upholsteryarizona.com/acoustat_upholstery.htm (don't pay attention to the pic).
ellisr63 is offline
post #953 of 4042 Old 07-14-2014, 11:22 AM
Quoted: 185 Post(s)
Liked: 140
Yes my speakers are flat. That sounds like a good idea i may give it a try. Thanks
post #954 of 4042 Old 07-14-2014, 12:50 PM
zombie10k's Avatar
Liked: 3568
I finished the front wall where my screen is located, it's pitch black now and looks very classy. I'm thrilled with the results, I can't stop looking at it.
I'm working on the side wall next, first removing the sconces and wiring in those black eyeball lights I posted earlier.
This is one of my favorite threads on this forum... great motivation to maximum my current projectors. I'll post some before / after photos once I get the next wall done.
post #955 of 4042 Old 07-14-2014, 01:22 PM
cardoski's Avatar
Liked: 1501
Really interested in how this will effect your HP screen, as you may or may not know I have been waffling over getting a hP screen for like a year. lol.
cardoski is offline
post #956 of 4042 Old 07-14-2014, 02:00 PM
airscapes's Avatar
Quoted: 381 Post(s)
Liked: 304
Did you get one? They are off the market till later this fall.. or so Dalite says they will be back..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #957 of 4042 Old 07-14-2014, 02:33 PM
Moderator
rboster's Avatar
Quoted: 1152 Post(s)
Liked: 1235
Which "line" of Rosco paint are you using (video paint)? If you could provide a link. Any tricks on using their paint. I think I remember being a paint you need to dilute before using and better to spray, then using a brush??
FS: HDBaseT HDMI Cable extender Kit (up to 100 ft) for $75 : http://www.avsforum.com/forum/210-vi...l#post52653465//
rboster is online now
post #958 of 4042 Old 07-14-2014, 02:44 PM
R Harkness's Avatar
Quoted: 2080 Post(s)
Liked: 1784
I know what you mean.
The usual inclination is to paint surfaces. But, especially when going really dark, a surface covered smoothly with dark velvet or some material tends to look even nicer and more classy when done right.
ellisr63 and cardoski like this.
R Harkness is offline
post #959 of 4042 Old 07-14-2014, 02:47 PM
DavidHir's Avatar
Liked: 1583
I used the Supersaturated. It's very thick and looks like black tar. My painter didn't bother diluting it as we tested that and it only seemed to lighten it up a bit. Just used a roller and brush.
http://www.rosco.com/scenic/supersaturated.cfm
Velour black #06003
DavidHir is offline
post #960 of 4042 Old 07-14-2014, 02:51 PM
cardoski's Avatar
Liked: 1501
I am looking at the 2.4 gain screen from Elunevison actually. I have a unity 4k Elunevision screen now and it performs very good. But it would be nice to be able to clamp the iris in my JVC down a bunch and still have a bright picture. I have a really good setup for an HP screen, my PJ is mounted behind me on a shelf, mid screen, and the screen is as wide as the room so now bad viewing angles. Just so happy with the uniformity on my current screen I am scared to go with a HP screen.
cardoski is offline
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
