The Blacker the Theater, The Better the Image - Page 70 - AVS Forum | Home Theater Discussions And Reviews
 1624Likes
post #2071 of 4216 Old 11-29-2015, 11:39 AM
Sam S's Avatar
Quoted: 275 Post(s)
Liked: 118
I hope this is OK to ask in this thread... as I start to consider black out room treatments for the next renovation of my room, I have one big issue: My speakers (B&W Nautilus 802) have a gloss black head! This has always been a distraction, reflecting light from my plasma. The obvious response will be "get new speakers", but I really like these speakers, and replacing them would mean replacing the center/surrounds as well (for acoustic matching), and I'd have to invest $20K+ to get the quality/performance that I have now with the B&Ws. The second response might be to cover the speaker heads, but that will likely destroy the acoustic properties, as they were designed. Any other ideas?
Sam S is online now
post #2072 of 4216 Old 11-30-2015, 08:09 AM
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
I would recruit a friend to help me blind test putting a sock over one speaker and leaving the other one with just the grill over the woofers and see how egregious the sound difference may be. If it isn't absolutely horrible I would put a sock over them when watching movies (the big issue of reflections distracting from the image will be taken care of). You could easily pull the socks off when you want to seriously listen to music.
edfowler is online now
post #2073 of 4216 Old 11-30-2015, 08:37 AM
R Harkness's Avatar
Quoted: 2132 Post(s)
Liked: 1846
I think you should be able to simply make a black velvet cover for the head portion. (Of course, not covering the drivers). It doesn't even need to be permanent, just something to plop on when you don't want to see the shine of the heads when watching movies.
I have high end speakers and the black velvet covers don't seem to have any effect on the acoustics.
If you are really picky, you could choose Devore viscose black velvet, which is both extremely dark and light absorbing, but also very thin and almost acoustically transparent, so it would have the least effect. (Or, if you don't need something as dark as velvet, you could make hoods out of black speaker cloth. Again, no need to cover the drivers if it's the shine of the head unit that is the problem).
This is the Devore velvet:
http://www.whaleys-bradford.ltd.uk/s...t-black-devore
R Harkness is online now
post #2074 of 4216 Old 11-30-2015, 09:35 AM
Sam S's Avatar
Quoted: 275 Post(s)
Liked: 118
Great tips! That thinner material is something I had not seen or thought of. I forgot to mention, I actually do use a black velvet that I custom-cut to fit on top of my B&W HTM1 center channel, as that was the source of the worst reflections, even though the center is not gloss.
And I like the idea of pulling off the 'sock' when I'm listening to music.
Sam S is online now
post #2075 of 4216 Old 12-06-2015, 12:51 AM
thxman's Avatar
Quoted: 646 Post(s)
Liked: 688
thxman is online now
post #2076 of 4216 Old 12-07-2015, 08:48 AM
Moderator
rboster's Avatar
Quoted: 1237 Post(s)
Liked: 1367
Originally Posted by thxman View Post
Well, this thread has inspired my new build.
Love the color scheme
For Sale JVC DLA-X750R/RS500 Projector includes two lamps
http://www.avsforum.com/forum/252-fr...l#post54970964
rboster is online now
post #2077 of 4216 Old 12-07-2015, 08:52 AM
thxman's Avatar
Quoted: 646 Post(s)
Liked: 688
post #2078 of 4216 Old 12-09-2015, 11:58 AM
kirbybreezy's Avatar
Could I use 3M Super 77/78 adhesive on the casing to a motorized screen housing? It is white and I want to cover it in velvet. Just want to make sure I don't do any damage to the internals of it.
Also how do you remove the adhesive, or do you?
kirbybreezy is offline
post #2079 of 4216 Old 12-09-2015, 11:59 AM
EDIT: Double post
post #2080 of 4216 Old 12-09-2015, 12:13 PM
skypop's Avatar
Quoted: 224 Post(s)
Liked: 124
I use double sided tape to attach velvet to anything that might need to be removed without leaving any residue.
2 Channel: Fi 2A3 mono's,Hovland HP100 W/MM Phono Stage,Technics SP10MK2/SME/Benz,Medallion Cabinets With Fostex 206EN Drivers,Peerless Subs....HT:126" Seymour AT Screen,JBL Studio 590's LCR,JBL SCS8's Side Surrounds,JBL HT5 Fr Heights, and JBL SCS8 Rear Heights,JBL Studio 580's Back Surrounds,2 Epik Empire Subs,HSU Midbass Sub,Marantz 7702MK2,Outlaw 7125,Marantz Ma500's,Panasonic UB900,Toshiba HD35,JVC RS400. Black Velvet.
skypop is offline
post #2081 of 4216 Old 12-09-2015, 01:28 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
I did my case. You have to be very careful to keep the spray out of the case.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #2082 of 4216 Old 12-15-2015, 01:51 PM
Daniel Chaves's Avatar
Quoted: 436 Post(s)
Liked: 345
[QUOTE=airscapes;39610090]I did my case. You have to be very careful to keep the spray out of the case.
Why not spray the material instead of the casing, if your worried about over spray?
Looks good by the way.
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Marantz SR6011 ATMOS/DTSX + Darbee 5000s
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Polk Audio TSx110B (Ceiling FL/FR RL/RR), (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE
Arrangement: 5.1.4 Source: OPPO UDP-203 4k Bluray Player, Roku 4, HTPC, Nexus Player
Daniel Chaves is offline
post #2083 of 4216 Old 12-15-2015, 03:11 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
[quote=Daniel Chaves;39772978]
It is contact cement, you need it on both surfaces and let it dry slightly before you apply it. Been a while since I did it and just remember it being very tedious working with an 8'+ length of fabric.. you also can not get any adhesive on the velvet surface as it melts the pile.
Daniel Chaves likes this.
Doug
post #2084 of 4216 Old 12-15-2015, 06:38 PM
zombie10k's Avatar
Quoted: 3881 Post(s)
Liked: 3963
Originally Posted by humbug2 View Post
Has anyone used, seen, or heard of
1" Thick (20) Black Acoustic Ceiling Tiles - 24" x 24" Fiberglass Sound Board - 80 sq ft - Select Acoustical NRC .75 2 Ft x 2 Ft at
http://www.amazon.com/dp/B00K381YS6/...I36B2RJDIJROMA
I am thinking about doing a 8 x 10 ft area in front of my screen.
I looked for a while and found a tile that looks great.
B&H has these
http://www.bhphotovideo.com/c/produc...e_24_x_24.html
here is a photo showing my room partially completed.
I ended up covering the ceiling grid with the protostar material found here:
http://www.fpi-protostar.com/hitack.htm
great blackout project and it makes a huge difference in my room consider my screen is quite large and just inches from the ceiling.
painted lights with BBQ paint mounted in the black ceiling tile.
zombie10k is online now
post #2085 of 4216 Old 12-16-2015, 04:28 AM
Skylinestar's Avatar
Quoted: 1214 Post(s)
Liked: 227
Thank god you cover up the shiny grid.
Other than Protostar, is there any other alternative to "blacken" the grid?
What's up with big cinemas that don't bother about the grid?
Skylinestar is offline
post #2086 of 4216 Old 12-16-2015, 11:28 AM
stanger89's Avatar
Quoted: 3704 Post(s)
Liked: 2057
B&H has these
Maybe I asked this before, but did those make for an acoustic improvement in your room? Ie are they better than normal ceiling tiles painted black?
stanger89 is online now
post #2087 of 4216 Old 12-16-2015, 11:57 AM
zombie10k's Avatar
Liked: 3963
I do think they helped vs. the traditional tiles I had in there before. They are dense fiberglass and have a nice looking black finish. Not cheap, but very happy with this product.
@Skylinestar - I was distracted by this at our last IMAX session (Real Imax, not the 'Faumax') - I could see the grid the entire movie.
Even the best black paint from Rosco was still visible so I ended up cutting over 200 sections of protostar to apply to the grid (~60 tiles). It looks remarkable and completely disappears during a movie.
post #2088 of 4216 Old 12-16-2015, 02:14 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Zombie, how far out from the front of your screen do you have blacked out?
gpmbc is offline
post #2089 of 4216 Old 12-16-2015, 06:34 PM
zombie10k's Avatar
Liked: 3963
It's about 14 feet of black ceiling tile /grid then transitions to a drywall area that is just above my seating at 17 feet. I'm trying to decide if I want to paint this with the Rosco paint or find a way to attach the velvet to the ceiling.
the protostar material on the grid worked out perfect. it was worth the hard work installing it.
Dan Hitchman likes this.
post #2090 of 4216 Old 12-16-2015, 09:04 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Nice man, definite black hole.
gpmbc is offline
post #2091 of 4216 Old 12-17-2015, 02:36 AM
Acoustic tile and optic fiber lights just done my room
skypop and giogt600 like this.
esr8 is offline
post #2092 of 4216 Old 12-17-2015, 02:44 AM
Walls finished in dulux flat black
ID:	1125354   Click image for larger version
esr8 is offline
post #2093 of 4216 Old 12-17-2015, 07:16 AM
titanle's Avatar
Quoted: 42 Post(s)
That looks awesome!!
titanle is offline
post #2094 of 4216 Old 12-19-2015, 04:12 PM
Boggle's Avatar
Quoted: 35 Post(s)
hi all,
i am doing a fiber optic ceiling project with drop ceiling tiles. i got syfabrics triple velvet for the tiles.
for the support grid, should i go with gaffers tape or protostar? or will that be too noticeable, and i should go through the hassle of gluing triple velvet to the grid as well.
Boggle is offline
post #2095 of 4216 Old 12-19-2015, 04:12 PM
Boggle's Avatar
Quoted: 35 Post(s)
hi all,
Boggle is offline
post #2096 of 4216 Old 12-19-2015, 04:31 PM
zombie10k's Avatar
Liked: 3963
Protostar is going to look better than gaffers tape. My grid came out excellent, just be patient when installing it and it will come out perfect.
post #2097 of 4216 Old 12-19-2015, 09:55 PM
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
I just covered the entry door coming into the back of my theater and the flat equipment door at the back of the theater with triple black velvet. I used 3m Super 77 multi-purpose spray adhesive and it seemed to work great. The flat equipment door was way easier to cover without wrinkles. It was difficult to get the entry door perfectly smooth since it had six raised panels on the face of it. But hey, its black velvet in the back of a dark theater, I think its going to be just fine.
post #2098 of 4216 Old 12-20-2015, 01:26 PM
Originally Posted by Boggle View Post
hi all,
The support grid is hidden so what do you mean about covering it. The tiles have a u shape cutout on the edge which help support it on the aluminum channel
Craig Peer likes this.
esr8 is offline
post #2099 of 4216 Old 12-20-2015, 04:34 PM
Naylorman32's Avatar
Quoted: 450 Post(s)
Liked: 201
WOW. thats beautiful. Congrats on a sick looking room
Naylorman32 is online now
post #2100 of 4216 Old 12-20-2015, 04:43 PM
Quoted: 450 Post(s)
Liked: 201
I tried to put velvet on my ceiling tiles in front of my screen, about 4 feet out, but the push pins couldn't hold the fabric up.
Can anyone recommend a double sided tape (or something like it), that I can just apply to my ceiling grid to hold up the velvet? I could then use push pins to touch up spots here and there.
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
