and if you had to chose... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-26-2013, 11:07 AM - Thread Starter
deekay08's Avatar
Hi All,
would like to know what most of you would chose... I currently have an opportunity for either a BenQ W1200 @ 1200$ or BenQ W7000 with 2 pair of BenQ 3D glasses @ 1800$,
both are demo one has 54 hrs and the other about 90hrs...
If you would have this option what would be your choice ?
deekay08 is offline
post #2 of 4 Old 03-26-2013, 11:46 AM
ondaedg's Avatar
Isn't the w1200 a couple of years old? I'd go with the w7000 or the Benq W1070. The 1070 will probably put out a better picture at a lower price. Check out the thread in the under $3000 forum.
http://www.avsforum.com/t/1435626/benq-w1070-dlp-full-hd-3d-ready-with-lens-shift-for-1000
ondaedg is offline
post #3 of 4 Old 03-26-2013, 12:12 PM - Thread Starter
deekay08's Avatar
I saw the W1070 the only issue it does not have FI...
deekay08 is offline
post #4 of 4 Old 03-26-2013, 12:28 PM
ondaedg's Avatar
True, it doesn't have FI. Keep in mind though that the w1200 doesn't offer 3d while the w1070 does. It depends on what you're looking for.
ondaedg is offline
Benq W1200 300 Inch 1080p Front Projector , Benq W7000 Home Projection System , Benq W1070 3d Ready Dlp Projector 1080p Hdtv
