Panasonic PT-AE7000 Lamp Issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-26-2013, 02:50 PM - Thread Starter
Mikejr012000's Avatar
Hi,
I'm new to the forum and projectors in general. I purchased the pt7000 approx 2 months ago and with only 98 hrs on the lamp it died. The Power Indicator is a solid red with the Lamp Indicator flashing red. I removed and inserted the lamp to ensure a proper fit with no success.
The troubleshooting portion of the owners manual suggest the it maybe be an issue with the lamp circuit. Is this a common occurance?
I have replaced the lamp and the projector is working fine for now. I'm just wondering if i should return the projector to the store is purchased it at ( in store 2 year warranty) or keep it and hope this lamp does not burn out either. Is there some sort of warranty on the lamp. Customer service at Panasonic was no help. Also, the projector seems to be loosing signal and flashing today when is was giving a friend a demo of the 3D.
I love the projector, just worried i have a lemon and should return it to the store demanding an exchange.
Mikejr012000 is offline
Panasonic Pt Ae7000u 1080p Full Hd Projector , Replacement Lamp For Pt Ae7000u
