Official Mitsubishi HC5 Owners Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #631 of 744 Old 06-25-2014, 01:56 PM
Vaan Janne's Avatar
Quoted: 49 Post(s)
is there any possibility to connect 3 pin bluetooth emitter into the hc5´s 3d emitter output.
i bought Hi-shock active glasses + emitter because the seller said it would work with hc5.. oviously he
does not know that he sels when he send´s me glasses + emitter that cannot be hooked into my pj.
atleas he should have asked if i have a bd player that can output into 3 pin emitter.
FUUUUUUUCCCCKKKKKKKKKK.....i water 3 weeks for this ****.
have already contacted the seller...he has not replyed yet
Vaan Janne is offline
post #632 of 744 Old 06-26-2014, 01:23 PM
Florus's Avatar
Liked: 0
Well, I'm not sure about the Hi-shock emitter but the 3d output of the HC5 is vesa compatible and works with 3rd party RF systems (Optoma, Monster, 3D now, ...).
On the bottom of this page (END of page!) you'll find the pin layout of the cable you'll have to solder for those emitters, maybe your Hi-shock emitter uses a similar layout?
Florus is offline
post #633 of 744 Old 06-26-2014, 02:28 PM
Vaan Janne's Avatar
Quoted: 49 Post(s)
luckily i got a mail from seller they have shipped an adapter. but it´s shipped separetly.
- but thanks for the info.
post #634 of 744 Old 06-30-2014, 09:19 AM
cval44's Avatar
Reviews please.
cval44 is offline
post #635 of 744 Old 06-30-2014, 12:22 PM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Originally Posted by cval44 View Post
Reviews please.
still wating for the adapter
post #636 of 744 Old 06-30-2014, 12:25 PM
cval44's Avatar
Thinking about 3d so if this emitter and glasses works well I may make the jump.
cval44 is offline
post #637 of 744 Old 06-30-2014, 12:56 PM
Vaan Janne's Avatar
Quoted: 49 Post(s)
it´s exelent 2D. best i´we seen. I also hope the new 3d setup is better than mitsubishis own. i´ll get back hopefully this week...when the cable arrives
post #638 of 744 Old 07-03-2014, 12:22 PM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Anyone watching movies without the cinema filtter ?
post #639 of 744 Old 07-03-2014, 03:28 PM
Vaan Janne's Avatar
Quoted: 49 Post(s)
I have another HC5 in the mail coming.
I have omega setup with DLP filtters ( yes...i have tried to get rid of them and get the LCD version) and im gonna make a go with them and try the system.
I´ll report after some testing....propably some quick test next week,s thurday evening...if not im not gonna have time to test untill August 17 propably.
So untill then.... also the Hi-shock active glasses...that i can test AS SOOOON AS THE FRIKIN ADAPTER GETS HERE... im so bored about it.
Oh i also have Awater3D polarizers and a silverscreen to test dual HC5 rig...my silver screen propably is not good enough though.
these are exiting times... i have waited this about 2 years.
-Janne-
post #640 of 744 Old 07-03-2014, 10:38 PM
3dmaven's Avatar
I've thought about trying the omega setup also with HC-5's. I have the filters (LCD version) and 20 or so pair of glasses, but I can't afford to pick up another projector right now and it is so expensive to get 3D media. So for now I rent 2 or 3 3D blurays a month and watch them with the active glasses (playstation 3d glasses). I do love the image with the omega glasses: beautiful color, no ghosting, and a rock solid 3D image with no eye fatigue.
3dmaven is offline
post #641 of 744 Old 07-03-2014, 10:43 PM
3dmaven's Avatar
Whenever I do it looks really bad. I haven't tried using my Lumagen to correct for the color shift with the cinema filter off since it seemed like a losing battle and that I would really gain any brightness. In fact, at just over 1000 hours I still don't feel the need for any more brightness in 2D or 3D, but my projector is in a batcave environment.
3dmaven is offline
post #642 of 744 Old 07-04-2014, 08:39 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
What projector you used when you demoed the omega filtters ?
yes passive is just sooo smooth...it's like 1 chip dlp compared any 3 chip machine after another, it's just so much easier on the eyes with 3 chip.
post #643 of 744 Old 07-04-2014, 08:51 AM
3dmaven's Avatar
I actually still own the filters (I bought them when they first came out). I use them with two very old Barco reality projectors, which can only do 720p, but are very bright (and cheap). I really want to try the filters with some newer projector that have some color control (deep reds tend to shimmer a bit on my setup due to an inability to calibrate the colors well)
3dmaven is offline
post #644 of 744 Old 07-04-2014, 09:04 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Would the dlp version of filtters work better with your old barco... they ar3 crt ? Besicly closer to dlp ? ?..motoman would know
post #645 of 744 Old 07-11-2014, 05:45 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
wrote this on omega thread, but i thought to post it here also.
TESTED....fast test. im on my way to a festival, just got time to build a rack for the second unit and install it yesterday.
remember i have the dlp filtters.
I think the result is better with my Lcos and dlp filtter than with my old setup, LCD with dlp filtters.
I would looove try out the new lcd filtters.
I got some of the colors better but some are still off. plus side no ghosting at all.
the left if i remember corretly had overal yellowish tint that i did not get off at all. the hc5´s cinema filtter has no effect
on on that channel. the right channel was overwhelmed with more blue when using the cinema filtter, so used them at off position
from both projectors. the right channel has a blue overal tint on it still.
i will do more testing when i get back from the festivals. i can also test my polarizers with hc5 but i will not propably compare to a ghost free picture.
motoman is right on one thing, your eyes get used to the signals after while... at the end of my test session i did not see a quite much difference in left and right channel
but as you can see from the jpg´s they are like from differet color world.
But i was a little bothered about the change in whole color universe change when i fiddled with cms and other color settings to trying to get the
left and right colors match.
i have really mixed feelings. propably with the right filtters the result is much better and i gotta say the 3d imersion is much better when there is no ghosting on 3d picture,
like with polarizers. and The active flicker is annoying. i rather watch polarized 3d than active.
post #646 of 744 Old 07-11-2014, 05:46 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
HAH i still have not gotten the adapter to try out hi-shock active wear.
post #647 of 744 Old 07-15-2014, 03:23 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Here are the photos
I like the results pretty good, there is still some improvement. If one could get the overal yellow tint off the left and some of the blueish right channel tint off
the picture would be awsome. But it´s still much better result with omega dlp filtters and my lcos PJ´s than with my HQ polarizers and not perfect silver screen.
what´s your take on this motoman. Would i get better result with the correct set of filtters. By that i mean less yellowis overal on left and less blueish overal on right ?
post #648 of 744 Old 07-15-2014, 04:39 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Here
the images refuse to go in order. the "yellowish" is the left one
ID:	162073   Click image for larger version
ID:	162081   Click image for larger version
ID:	162089   Click image for larger version
ID:	162097   Click image for larger version
ID:	162113   Click image for larger version
ID:	162121   Click image for larger version
ID:	162129   Click image for larger version
ID:	162137   Click image for larger version
post #649 of 744 Old 07-17-2014, 02:31 PM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Tested the hi-shocks glasses. Adapter finally arrived.
more brighter than the mitsubishi own glasses.
Can't adjust the World 3d brightnes from the projector... or anyplace else.
almoust no flicker.
lots of ghosting.
post #650 of 744 Old 07-17-2014, 02:37 PM
canton160's Avatar
Quoted: 24 Post(s)
Liked: 50
This best setting for 3D IMHO is 3.5/ 4 less brightness but also less ghosting..
Anthem MRX310 | XTZ 93.23 DIY 5.1 (Seas Jantzen Mundorf) | DXD808 | Oppo 103D | LG OLED 55EC930V | Mitsubishi HC5 | Lusoscreen 100"
canton160 is offline
post #651 of 744 Old 08-10-2014, 02:32 PM
Vaan Janne's Avatar
Quoted: 49 Post(s)
lego 3d looked pretty awsome allthough it has lot's of colours. Also gamed dead space with helix mod and it's awsome.
gotta say im pretty close to settling into this dual hc5 omega rig.
just gotta go check out the never active3d sony units.
i think hc5 is great choise to do a dual rig.
post #652 of 744 Old 08-10-2014, 03:26 PM - Thread Starter
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
How is brightness compared to watching with active glasses? How's crosstalk compared to HC5's native performance? Is it tiring? Do you notice any color irregularities with your vision afterwards?
Elix is offline
post #653 of 744 Old 08-10-2014, 03:42 PM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Brightnes.... hmm could not ask more, allthouh i have a batcave. I would say atleast double, i have lamp at normal and iris about 6. Other pj has different value.
Crosstalk about zero, if you watch white on black, there is relly faint halo, i mean really low = much more depth on 3d.
i think hc5's active 3d is super crappy. Difference is like day and night. How can passive be tiring ? You are watching 2 2d videos with superb motion interpolation.
well i think 3d is always kind of tiring if the distance between images is high, but i did not notice any active similar tiring.
Yes there is minor tint on eyes after watching. You cant really avoid color tinting afterwards if it is there when watching. Alltough you caNt detect it if not watching with only one eye open.
Elix likes this.
post #654 of 744 Old 09-03-2014, 02:07 PM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
I am the new owner of a HC-5 what has the bulb life been with these projectors? Keeping brightness at 1000 hours or alot of drop off? Also whats a good price for a new oem lamp and where? Pm about the lamp. Thanks
greg1292 is offline
post #655 of 744 Old 09-09-2014, 12:51 PM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
I found my own answer even though the projector looked
good with 1171 hours on the bulb running in high lamp mode the new lamp is 100 times better. Running in eco mode the image jumps off the 122" screen.
Over all a nice machine for the money. Coming from the RS-46 could not be happier with the motion and DLP pop of the HC5. Is this projector perfect? No but does more right than wrong.
Elix likes this.
greg1292 is offline
post #656 of 744 Old 09-11-2014, 12:02 PM
SilkyAndy X's Avatar
I wonder if anyone could help.
My PJ seems to be showing red tinge in the bottom right and blue tinge in the top right on white screens. only on forum pages or file explorer etc. Not noticeable in films or on the test screens which is odd. Any advice or tips appreciated.
SilkyAndy X is offline
post #657 of 744 Old 09-11-2014, 01:18 PM - Thread Starter
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
How much the iris is closed? Can you test by fully opening the iris?
Elix is offline
post #658 of 744 Old 09-11-2014, 02:30 PM
I usually have the iris on user (8) or variable. It shows on either but is more pronounce on the variable setting or on any higher bright setting.
The red is actually the lower portion of the screen and blue higher portion but it is more noticeable on the right hand side
post #659 of 744 Old 09-12-2014, 12:49 AM - Thread Starter
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Can you test by opening up the iris completely and seeing if coloration still shows?
Elix is offline
post #660 of 744 Old 09-12-2014, 02:33 AM
I have tested at fully open and the problem is even worse.
Mitsubishi , Mitsubishi Brand , Mitsubishi Electronics America , Mitsubishi Hc9000d 3d 1080p Lcd Projector , Mitsubishi Hc5 , Epson Powerlite Home Cinema 8350 , Benq W7000 Home Projection System
