No video help with jvc rs45 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-14-2013, 04:01 PM - Thread Starter
flee27's Avatar
Went down to watch a movie today and could not get any video output from the projector. Turns on fine and no visible issues with indicator light. Brought another DVD player down and temporarily hooked it up directly to hdmi 2. Switch inputs on the projector and have the same issue. Just a black screen. All the on screen display menus work fine. Help please.
Foster
flee27 is offline
post #2 of 7 Old 04-15-2013, 04:54 AM
kkpro's Avatar
Quoted: 117 Post(s)
Liked: 62
You didn't by chance hit the "hide" button did you?
kkpro is online now
post #3 of 7 Old 04-15-2013, 07:16 AM
Mike Garrett's Avatar
Quoted: 5590 Post(s)
Liked: 3578
mjgarrett100@gmail.com
Mike Garrett is offline
post #4 of 7 Old 04-15-2013, 07:51 PM - Thread Starter
flee27's Avatar
Definitely not the hide button. I can hit the hide button and make the source display show up and disappear. Can't find a reset function so unplugged then it for a while. Same issue. It just doesn't recognize the hdmi inputs. Don't have anything to test the computer or component inputs.
Thanks though.
flee27 is offline
post #5 of 7 Old 04-15-2013, 07:56 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
It is possible that your hdmi inputs are fried due to a nerby lightening strike. If an hdmi cable was hooked uo to an input this can happen. Some projectors have a separate hdmi chip for each input. Some have only one chip wired to the two hdmi inputs. Don't know whether the JVCs have one chip or two. I have had this happen to me.
mark haflich is offline
post #6 of 7 Old 04-15-2013, 08:04 PM
Liked: 1010
Try running a three cable component cable from your Bluray player to the JVC. Be sure not to send it 1080p but use 480i or 1080i or 720p. 1080p will shut off the component output on your bluray player. If it works on less than 1080p via component your HDMI input chip(s) are shot. Repair is possible and might be covered by warranty especially if you don't know why they failed.
post #7 of 7 Old 04-17-2013, 07:10 AM
Liked: 1010
Flee27. It is customary for a TO seeking help with a problem and receiving advice so valuable that a price can not be assigned to it to report publically on the application of such advice or the discovery of some other solution to the problem. smile.gif
Jvc Dla Rs45 Home Theater Projector 1080p Hdmi
