Can a jvc rs66 with pamamorph 480 throw enough brightness into a SI Black Diamond 1.4gain 144inch screen for 2D and 3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-20-2013, 02:37 PM - Thread Starter
Jim Parys's Avatar
If not what is the largest i should go?
Jim Parys is Living the dream...
La Sirena III Theater
Jim Parys is offline
post #2 of 4 Old 04-20-2013, 02:57 PM
Seegs108's Avatar
Quoted: 4195 Post(s)
Liked: 2087
Is that 144" wide or diagonal. If diagonal, you'll be looking at ~19ft lamberts with the lens in place, which is plenty bright. I wouldn't go any larger than this because the bulb will dim over time.
Seegs108 is online now
post #3 of 4 Old 04-20-2013, 09:56 PM - Thread Starter
Jim Parys's Avatar
Yes diagonal. Thanks for the input. Looking at the blak diamond zero edge and that is the largest they make that screen
post #4 of 4 Old 04-21-2013, 07:46 AM
Mike Garrett's Avatar
Quoted: 5556 Post(s)
Liked: 3541
As Seegs said above, that combination works fine. You are pushing the boundaries, so you are not going to get the lamp life of someone using a smaller screen, but that is one of the trade offs for having such a large screen.
mjgarrett100@gmail.com
Mike Garrett is offline
