3D Color Calibration Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 05-21-2013, 04:52 PM
jchasen's Avatar
Originally Posted by tskalecki View Post
Hi guys
i would like to do 3D calibration for my PJ but have problem , my Oppo 93 and Optoma hd 83 have no conversion 2d-3d is there some posibility to get HCRF pattern ore any other pattern disc in 3d , it can be sbs for example ? any help be apriciate
http://www.avsforum.com/t/1442511/spears-munsil-hd-benchmark-blu-ray-2nd-edition/0_50
The Spears & Munsil HD Benchmark Blu-Ray 2nd Edition can be ordered online from Oppo.
jchasen is offline
Old 05-26-2013, 02:27 AM
tskalecki's Avatar
already bought thx for help :-)
tskalecki is offline
Old 01-08-2014, 03:42 PM
coolplazma's Avatar
Is it valid to do the 3D Grayscale calibration by simply using the standard 2D HD Rec.709 and enabling the projector's 2D->3D conversion, then measuring through the glasses?
Coolplazma's HT Den project. Early project info. Needs update with final results.
coolplazma is offline
Old 01-10-2014, 08:12 PM
3dmaven's Avatar
This should be fine. I think some folks are doing it this way, I used to and it worked well for me. You should be able to get a calibration disk with 3d patterns now though, if you want to be extra sure that your pj doesn't do anything strange with the signal when converting 2d -> 3d.
3dmaven is offline
Old 01-17-2014, 10:39 AM
coolplazma's Avatar
I gave this a shot and it seems to work ok with the standard AVS HD 709 patterns.
One hitch though, when metering with the Sony 3D glasses in front of my i1D3. I couldn't seem to get the glasses positioned to allow more than ~1.9FL, whereas without the glasses the meter reports ~20FL in that same position. I had the glasses (one lense anyway) as close to the i1D3 eye as possible - basically the i1D3 was sitting inside the glasses frame. Also verified the glasses were acitve/in-sync.
Any thoughts?
Sony Vpl Hw50es 3d Projector
taboola here
