Media room is ready but I need projector / screen avice. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-26-2013, 07:34 PM - Thread Starter
ThomasBorn's Avatar
My dedicated media room is finally "done" construction wise but now I need to start looking in to a projector and screen. I have full control of lighting in the room and no windows. I am looking at spending $4000-$5500 for both projector and screen. I have pretty large Definitive Technology speakers that will either go behind the screen or I will have to figure out how I will place the clr2500 center speaker below the screen.
I dont need a fancy auto masking screen and I am lost as to which gain and size I need for the room. I was thinking a 100'' - 110'' screen if it will fit right with the slope ceiling. I just randomly select movies to rent but they are all in different screen formats so I am not sure how the size to masking works with these screens.
For the projector i was thinking JVC but not sure what model; I am also open to other models. I see people refer to "B" stock but what is that (refurbished is different from b-stock) ?
What would you guys/girls recommend?
Usage:
1. Primarily 2D movies but I might branch out to 3D movies in the future.
2. Sports / Netflix / Amazon streaming
3. Very casual Xbox gaming
ThomasBorn is offline
post #2 of 5 Old 04-26-2013, 07:41 PM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
JVC RS4810 + Darbee Darblet + Da-Lite High Power 2.4 gain screen + Oppo or Sony s790 Bluray Player = Within your budget...
You could go for the AT screen as well if you want to place the speakers behind the screen, though AT screens are more expensive.
Access HERE from this thread
coderguy is offline
post #3 of 5 Old 04-26-2013, 07:44 PM
mbw23air's Avatar
Quoted: 154 Post(s)
Liked: 141
Usage:
I'm going to recommend the JVC RS4810. I would contact AVS about their pricing and they could also recommend a screen for you.
Mike
JVC RS600(Calibrated with Chromapure using an iD3), Stewart Cima Neve 2.35 115" diagonal screen, Lumagen Radiance XD, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Panasonic UB-900 UHD blu-Ray player, HDFury
mbw23air is online now
post #4 of 5 Old 04-27-2013, 06:59 AM - Thread Starter
ThomasBorn's Avatar
Is the Darbee Darblet for the sports and gaming or is that just needed for all projector media?
I have a PS3 I use for my BluRay playing; what does the Oppo or Sony s790 do that my PS3 will not?
post #5 of 5 Old 04-27-2013, 10:50 AM
mbw23air's Avatar
Quoted: 154 Post(s)
Liked: 141
The Darbee Darblet is for all sources as it sharpens and enhances contrast with little to no negative side effects as long as used in moderation. I have an OPPO but the PS3 will also work great as a bluray player.
Mike
Sony Blu Ray Disc Player Bdp S790
