HD950 still a worthwile purchase? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-30-2013, 12:58 AM - Thread Starter
Spiralmind's Avatar
Is spending money on a new JVC HD950 silly at this point? (04-30-2013) If it was down to $2500 or less? Ive had a HD350 and liked it. But would that money be better spent on a newer, lower initial cost projector?
Thanks for any ideas.
Spiralmind is offline
post #2 of 4 Old 04-30-2013, 08:32 AM
Mike Garrett's Avatar
Quoted: 5604 Post(s)
Liked: 3587
Does the projector have a warranty? Personally, I would take a new RS46 over it. The 46 will have a sharper lens, better motion and a longer lasting lamp. Contrast and black levels should be the same.
mjgarrett100@gmail.com
Mike Garrett is online now
post #3 of 4 Old 05-01-2013, 01:54 AM - Thread Starter
Spiralmind's Avatar
Is there anything the HD950 would do better? And what if I could get it for $2250 shipped and it did have a warranty, do you think it would be getting closer to worth it at that point?
I did notice the rs46's were going for just a bit more and was going to inquire about them. What more does the x70 bring at $4k approx and the x90 at $6k? I have an HD350 with an almost brand new bulb that shut off and hasnt turned on for 9 months since I bumped the directv box and unplugged it and I must have sent a surge or something and hurt the projectors power supply or something... I enjoyed this projector and since I have a bulb I though I might get another compatible projector, but if these are just too old then its probably a bad idea..?
Thanks for your help!
post #4 of 4 Old 05-01-2013, 09:45 AM
Liked: 3587
With warranty and that price the HD950 is a good option. The X70 and X90 get you 4K up-conversion.
Jvc Dla Hd350 Full Hd D Ila Home Theater Front Projector
