Sony HW50 3D troubleshooting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-02-2013, 09:26 PM - Thread Starter
hkg1975's Avatar
Hi - I bought the above and love it for 2D. Finally got round to trying 3D from both Netflix and on demand cable. But.....I don't seem to be able to see anything in 3D. On cable the program shows as two side-by-side images but there is no 3D effect. I am using the glasses that came with the projector (and yes, they are fully charged and switched on). What am I missing? I have seen 3D on an epson so I know what it should look like and nothing seems to be happening... did I get a bad projector? I am using a denon 3313ci receiver which purports to have 3d pass through. Hdmi redmere connection to the projector Thanks!
hkg1975 is offline
post #2 of 2 Old 05-03-2013, 06:21 AM
karcs's Avatar
Hi hkg, might be obvious, but did you try switching the 3D mode to side-by-side on projector?
Also, are you sure the glasses are "talking" with the projector? The only simple test I can think of is to adjust the 3D brightness (essentially it adjusts the glasses). You will notice your glasses getting brighter or dimmer.
And of course to eliminate any other source, you will want to go straight from your Cable (service) to projector, just in case the receiver really is blocking something.
karcs is offline
Sony Vpl Hw50es 3d Projector
