New Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-08-2013, 10:52 PM - Thread Starter
Bengali's Avatar
Hi,
I just pulled the trigger for the 50es :-)
I will be using a humble Epson Duet for now 42.5" x 79.5"
I believe the bottom of the Duet Screen is approx. 36" from the ground.
I will be using a shelf and it is fixed at 52.69" from the ground.
Is the projector central calculator correct? It is giving me a 12.1' from screen to projector with the 79" diag screen at 1.0 Zoom.
I'm only sitting about 9-10 feet away from the screen so the projector will have to be 1-2 feet right behind me? I was hoping to move it back further 15-16 feet. At distance of 16 feet, the screen jumps up in the +100" range.
Is there any link to some new owner, quick setup/setup tips/guides for the 50es?
Bengali is offline
Samsung 50 Inch Led Hdtv Un50es6100
