jvc dla-x55 calibration help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-20-2013, 06:51 PM - Thread Starter
niners's Avatar
I purchased a jvc dla-x55 and was hoping to find calibration setting by others who have had great success.
I replaced my old Epson 3020 and although never saw them side by side I don't think the picture on the jvc is much better.
Any help support on how to tweak and if there is value in having it done professionally.
Thanks in advance
niners is offline
post #2 of 8 Old 05-23-2013, 06:02 PM
Robinson ------'s Avatar
film
standard
6500
gamma (2.2)
dark level white (+4)(helps with detail in blacks)
contrast (+14)(free avs709)
brightness (-6)(free avs709)
mpc-film
enhance-32
dynamic-0
smoothing-0
rnr-off
color management-off
motion-off
aperture (-15)
lamp-low
dhmi-enhanced
color space-4/4/4 (or auto)
progressive- auto
other peoples calibrated settings... (Credit to crabalocker)
color temp (-2/-8/0/-3/-1/0)
custom gamma (2.3)
white- 48, 94, 139, 193, 288, 391, 496, 598, 704, 808, 916, 970
red-47, 94, 139, 190,
green-48, 94, 139, 193,
blue-42, 90, 139, 190,
cms
red- 0, 3, -2, 5
orange- 0, 0, 0, 0
yellow- 0, 6, 4, 18
green- 0, 13, 10, 1
cyan- 0, -5, 10, 10
blue- 0, 0, 6, 8
magenta- 0, -6, 15, 20
JVC rs4810 (115)
Pioneer Kuro-9gen (50)
Oppo 103d
Marantz sr7001
Klipsch rb81/rc62/rs52
Robinson ------ is offline
post #3 of 8 Old 05-25-2013, 05:51 AM
timescape7's Avatar
Every projector and lamp is different. Can't use someone else setting...
timescape7 is offline
post #4 of 8 Old 05-25-2013, 04:46 PM - Thread Starter
niners's Avatar
Thanks timescape
Is it worth getting a professional to calibrate and if so what should I expect to pay
niners is offline
post #5 of 8 Old 05-25-2013, 10:46 PM
Crabalocker's Avatar
Quoted: 182 Post(s)
Liked: 122
I had mine professionally THX calibrated and it turned out fantastic. I paid around $500 for mine and it looks .....again, fantastic.
I also bought ChromaPure and the D3 meter and made my own calibrating setting. It looked good but not nearly as good as the pro calibrators. frown.gif Still, it looked better than the stock settings. I think when I getter better at calibrating it should look closer to the pro calibrator...at least that's what I'm hoping.
Crabalocker is offline
post #6 of 8 Old 05-26-2013, 11:31 AM
Edit.
JVC rs4810 (115)
Oppo 103d
Marantz sr7001
post #7 of 8 Old 05-26-2013, 08:53 PM - Thread Starter
niners's Avatar
I did a bunch of reading and I think i might buy the same setup for calibrating that you have mentioned.
It sounds as though with the projector you need to recalibrate every couple hundred hours. So diy seems to be the best long term solution and as you state overtime hope to get better.
Did you use the Grey and color guide for dummies to get started
niners is offline
post #8 of 8 Old 05-27-2013, 03:03 PM
Quoted: 182 Post(s)
Liked: 122
No. ChromaPure has a bunch of calibrating videos on their site and followed them. You also have to burn the REC709 disc. Really easy to follow but there is definitely a learning curve. Tom is really good at answering any questions and you get a lot of support from others in that thread.
No matter how you calibrate with the program it will look better than stock.
Jvc Dlax55rbu 3d Full Hd Front Projector , Epson V11h501020 Powerlite Home Cinema 3020 2d And 3d Home Theater Projector
