How do I watch downloaded 3d mkv file to my 3d support projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-24-2013, 01:59 AM - Thread Starter
Larry Clark's Avatar
I have BenQ W1070 which has 3d capablity. I have a pc. I haven't any bluray 3d player or I don't want to buy any 3d bluray disc or bluray player because they are costly. I download video from torrent. All are 3d and .mkv file. I tested that format to 3d tv and they were running fantastic like movie theater. Now how do I watch that format through my projector?
Larry Clark is offline
post #2 of 10 Old 05-24-2013, 02:32 AM
blee0120's Avatar
Quoted: 429 Post(s)
Liked: 229
Hahaha, good luck. Stealing content is something that will not get you help on the forum
blee0120 is online now
post #3 of 10 Old 05-24-2013, 03:22 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Elix is offline
post #4 of 10 Old 05-24-2013, 03:46 AM
SiggUA's Avatar
Liked: 25
The most popular pirate format 1080p half SBS is not supported by the Benq W1070.
Only formats specified in HDMI 1.4 are supported.
SiggUA is offline
post #5 of 10 Old 05-24-2013, 04:43 AM
Pugnax555's Avatar
In 1 hour and 15 minutes, you've gone from planning on using a 3d BD player, but now don't plan to get one because they're too costly. Got it.
Pugnax555 is offline
post #6 of 10 Old 05-24-2013, 05:50 AM
blee0120's Avatar
Quoted: 429 Post(s)
Liked: 229
Most media players won't support sbs half 1080p, but the Oppo 103 does. I ripped my 3d blu rays in sbs half because when I had the jvc rs40, they had some trouble playing tb files. I tried those files on my w1070 and they only worked in 1080p on my Oppo 103. It converts it to frame packing to play in 1080p. I doubt the OP is interested in a $500 blu ray player since the ones now at under $100 is too much
post #7 of 10 Old 05-27-2013, 03:42 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Sorry for the dumb question but what is SBS half 1080p?
pdxrealtor is offline
post #8 of 10 Old 05-30-2013, 01:33 PM
JerryW's Avatar
Quoted: 24 Post(s)
Liked: 36
Seoul Broadcasting System?
https://en.wikipedia.org/wiki/Seoul_Broadcasting_System
Copyright is not property, it is merely a temporary loan from the public domain.
JerryW is offline
post #9 of 10 Old 05-30-2013, 02:04 PM
Seegs108's Avatar
Quoted: 4196 Post(s)
Liked: 2087
SBS stands for side-by-side and the 'half" refers to the resolution. What you get with an encode like this is a single 1080p frame split in half and each half given to the left eye and the other to the right eye. If supported, the display takes each half and uses it to send you the appropriate eye to see for 3D.
Seegs108 is online now
post #10 of 10 Old 05-31-2013, 04:42 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Benq W1070 1080p 3d Projector
