-6 Vertical Keystone correction - Okay to use? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-25-2013, 01:57 AM - Thread Starter
cemo62's Avatar
Quoted: 69 Post(s)
Hello
My projector is Sony HW50es- Screen is 106inch fixed frame elite cinewhite 1.1 and viewing distance is 12 feet.
Will i lose serious pic quality or insignificant?
I would like to see your opinions
Thank you
Cem- ps: sorry for my english
cemo62 is offline
post #2 of 6 Old 05-25-2013, 04:44 AM
timescape7's Avatar
Originally Posted by cemo62 View Post
Hello
Thank you
As much as possible, avoid using keystone. It will degrade pq, somehow.
timescape7 is offline
post #3 of 6 Old 05-25-2013, 05:24 AM
Ron Jones's Avatar
Quoted: 920 Post(s)
Liked: 938
Hello
Thank you
If you set up your projector correctly you should only be using the lens shift adjustment and not the keystone adjustment.
What is your setup::
- Is the projector centered horizontally with the screen or is it positioned to the left to right of the screen center (if so how much is it offset from the screen's center)?
- Is the projector ceiling mounted or is it table or shelf mounted?
- what is the distance from the screen to the front of the projector?
- What is the vertical position of the projector relative to the screen (for example how far above or below the top edge of the screen is the projector located).
The projector should be level (not tilted up or down) and the front of the projector should be parallel with the screen (not rotated right or left) then the projector's lens shift adjustments should be used to center the image on the screen.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #4 of 6 Old 05-25-2013, 05:32 AM
timescape7's Avatar
Check out the official hw50es threads....
post #5 of 6 Old 05-25-2013, 05:40 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Keystone should never be used in a HT environment with a permanently installed projector. Keystone is a though back from the days of table top presentation projection where the built in offset or lens sift was insufficient. The screen was up on a stage or high on a wall and the projector was on a desk or table. The image was trapezoid and looked bad. Keystone digitally compressed/stretched/combined pixels to make the image square. You be the judge, compressed processed pixels with keystone.. does it change the image..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #6 of 6 Old 05-25-2013, 07:00 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
Keystoning is caused by the projector lens not being parallel to the screen.. This makes various sides of the lens further or closer to the screen than the opposite side. Keystone correction uses very difficult scaling vs easy scaling to make the image rectangular again. This scaling softens the image making it really degraded. Its night and day. when Ron says don't tilt the projector up or down but make it level, he is really saying make the lens parallel to the screen surface. the is as Ron says also includes twisting the lens left right so that it is completely parallel. Use lens shift to center the image vertically and horizontally. The election polls should be closed. No one who cares about image quality would use electronic keystone correction.
mark haflich is offline
Sony Vpl Hw50es 3d Projector
