SONY VPL-HW55ES : New SXRD Model from SONY IFA BERLIN 2013 - Page 10 - AVS Forum | Home Theater Discussions And Reviews
Old 11-09-2013, 05:39 AM
jojodyne's Avatar
Quoted: 31 Post(s)
Liked: 24
The review measured calibrated brightness and contrast at d65 and rec709. While i would like confirmation from other sources, it is not inconceivable that uncalibrated max brightness remained the same while calibrated brightness increased by 10%. In fact that would be consistent with the "new panels" that sony mentions on the HW55 slides. Maybe they need less headroom for clouding/shading correction, therefore sony could increase contrast and calibrated brightness. Let's just wait and see, what other measure....
I would expect them to have the same measured lumens, with the 55 having slightly better measured contrast.
jojodyne is offline
Old 11-09-2013, 07:49 AM
Mike Garrett's Avatar
Quoted: 5613 Post(s)
Liked: 3594
Since the contrast has increased, Sony probably had to get increased light, out of the engine to get the same light output out of the projector.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 11-09-2013, 08:58 AM
Gradius2's Avatar
Quoted: 20 Post(s)
Another alternative is JVC, but we need more reviews and impressions from users for sure.
[]s,
Fernando
Gradius2 is offline
Old 11-09-2013, 09:50 AM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 39
wich JVC?
john2910 is offline
Old 11-09-2013, 09:53 AM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 39
I will get this unit(sony hw55) on monday..
I do regret it a little bit and not ordered the epson tw9200..
But maybe i am wrong...when i get it this monday i will give my impression of this unit over here..
john2910 is offline
Old 11-09-2013, 10:11 AM
Gradius2's Avatar
Quoted: 20 Post(s)
Originally Posted by john2910 View Post
wich JVC?
DLA-RS49 or DLA-RS57.
[]s,
Fernando
Gradius2 is offline
Old 11-09-2013, 11:47 PM
Masterkale's Avatar
Quoted: 36 Post(s)
I will get my sony hw55es in white on monday. I ordered the wireless unit with it but that will arive next week.
The epson Tw9200 is not much better than the TW9100. The same with the sony hw50 and hw55. I believe (and told) the epson is not a better projector that the sony. The epson is only brighter and cheaper.
Masterkale is offline
Old 11-11-2013, 12:43 AM
RobertSmith8's Avatar
Great,
If you have the possibility and time, I would be more than happy if you can test a 3D movie using WHDMI, is WHDMI enough ?
RobertSmith8 is offline
Old 11-11-2013, 03:03 AM
Masterkale's Avatar
Quoted: 36 Post(s)
Originally Posted by RobertSmith8 View Post
Great,
I quess the unit will be having the same transfer rate as hdmi 1.4.. I will keep you guys posted.
Old 11-12-2013, 10:40 AM
Aaronh's Avatar
Liked: 31
Did you get your HW55? Can you confirm the throw ratio? I'd like to install my mount so I can throw mine up as soon as it gets here....
Aaronh is offline
Old 11-12-2013, 11:56 AM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 39
Yes i have it now ,and its calibrated now..
My first short impressions(i come from a epson tw9000).
The good:
A razor sharp picture does this unit throw at your screen..
Amazing contrast(a step up from my epson).
Very very good blacks.
No more screendoor(i sit very upclose and i saw that on my epson.).
Reality creation gives 3d more clarity..
3d is sharper and it has far more details then my old epson..
FI works good in 3d
More then enough light for my 100 inch screen in 2d.
The bad:
Still ghosting in 3d(sometimes more then my old epson tw9000)
The ir transmitter inside the sony unit is not that strong( i have it on the same place sitting where my epson was but now i loose sync).
i can see some flicker through the glasses that was better with the epson..
But its a great projector with great pop and depth in the image and razor sharp!
So this is just my opinion and not a professional review..
Best regards:)
john2910 is offline
Old 11-12-2013, 12:04 PM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 39
By the way i started a owners thread..with my impressions..
john2910 is offline
Old 11-12-2013, 12:40 PM
Mr. Hatcher's Avatar
Quoted: 216 Post(s)
Liked: 137
The good:
FI works good in 3d
The bad:
Best regards:)
You should try the new RF transmitter with glasses accessory pack. This is supposed to make the 3D much better.
Credit: Sony Store
Transmitter: Optional external transmitter (TMR-PJ2)
Glasses: Optional rechargeable glasses (TDG-PJ1)
Respectfully,
Mr. Hatcher
Mr. Hatcher's hybrid-HT
Mr. Hatcher is offline
Old 11-12-2013, 01:24 PM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 39
Credit: Sony Store
Hello there,
i think of getting that rf emitter and glasses.
But the flicker and the ghosting will be the same i think..
Dont get me wrong because the clarity and depth and pop in 3d (this is far better then my old epson) looks great..
But ghosting you will see sometimes.
john2910 is offline
Old 11-12-2013, 01:54 PM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 39
this one i think you meant: Sony Emitter AD025-RF-X1;)
john2910 is offline
Old 11-12-2013, 01:55 PM
Quoted: 216 Post(s)
Liked: 137
Hello there,
Credit: Projector Reviews
Sounds like 3D in particular should benefit from some of the improvements to the light engine. Also of note, although an IR transmitter for the IR glasses is built into the unit, the new HW55Es supports the latest initiatives, so you can now buy an optional RF emitter (TMR-RF1), and new lighter RF glasses (TDG-BT500A). In every case where we’ve seen a projector support both the older IR and new RF configurations we have found the RF solution to be brighter, and superior overall. I would expect the same here!
Respectfully,
Mr. Hatcher
Old 11-12-2013, 02:03 PM
Quoted: 216 Post(s)
Liked: 137
Well I pulled my data straight from Sony's website, hence the reason I credited them. Not sure where you got your info from, or Art for that matter...I see his is different as well. Oh well, point being, there are better options available that should make 3D more enjoyable. smile.gif
Respectfully,
Mr. Hatcher
Old 11-12-2013, 04:54 PM
Masterkale's Avatar
Quoted: 36 Post(s)
100 inch: 3.00-4.79 meter
120 inch: 3.61-5.76 meter
150 inch: 4.52-7.20 meter
Old 11-12-2013, 07:41 PM
Aaronh's Avatar
Liked: 31
Looks like maybe a slightly wider throw range than the 50ES? Thanks for the info - my mount is installed - now I just need the projector to hang from it!
Aaronh is offline
Old 11-13-2013, 05:52 PM
scotsman8's Avatar
Quoted: 12 Post(s)
any word on when AVS are getting these in? I'm getting giddy waiting especially since my Xbox is going to be in next week!
scotsman8 is offline
Old 11-13-2013, 07:24 PM
hendricksonet's Avatar
Mine is coming tomorrow. !STOKED! This is my first projector so hopefully it ends up being a good choice.
hendricksonet is offline
Old 11-13-2013, 07:33 PM
Aaronh's Avatar
Liked: 31
Gaaahhh! I'm going crazy waiting for mine to show up!!!!
Congrats - this for a first PJ is like hitting a grand slam in the world series in your first at bat..... a game winning goal in extra time in your first world Cup final....
Aaronh is offline
scotsman8's Avatar
Quoted: 12 Post(s)
Did you order from AVS? This will also be my 1st projector
Old 11-13-2013, 08:25 PM
Liked: 3594
Sony has not shipped these to dealers yet. Getting pretty irritating. mad.gif
Old 11-13-2013, 09:47 PM
I ordered from the Sony store bc I couldn't wait (sorry avs). They also had some financing offers I wanted to take advantage of.
Old 11-14-2013, 02:28 AM
Trepidati0n's Avatar
Quoted: 39 Post(s)
Liked: 107
I would agree. But if they are selling decently on their own website for full MSRP, I can't blame them for milking their current position in the market. Still a crappy thing to do to their vendors.
I must be guilty because people say I am guilty because they chose to call me guilty because they refuse to see the truth. Much easier to be part of the mob..
Trepidati0n is offline
Old 11-14-2013, 02:34 AM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 39
I am at 100 inch now..
Best regards
john2910 is offline
Old 11-14-2013, 06:49 AM
Liked: 3594
Told that HW55's will start shipping to dealers today and tomorrow. smile.gif
Old 11-14-2013, 07:31 AM
Masterkale's Avatar
Quoted: 36 Post(s)
Best regards
I just copied the hw55es manual that i received with it.
Old 11-14-2013, 07:40 AM
scotsman8's Avatar
Quoted: 12 Post(s)
Sony Vpl Vw95es Full Hd 3d Home Cinema Projector , Sony Vpl Hw50es 3d Projector , Sony Vpl Hw55es 3d Projector
