Do spare OEM JVC Projector Lamps have a shelf life? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-25-2013, 08:34 AM - Thread Starter
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
Is it OK to purchase a spare OEM JVC projector lamp for a JVC RS46 projector if you are not going to use it right away or should you wait until you actually need it?
Glenn Baumann is offline
post #2 of 6 Old 06-25-2013, 09:17 AM
stanger89's Avatar
Quoted: 2634 Post(s)
Liked: 1354
What I've always heard/been told is that you want to use a lamp right away to make sure it's not DOA, or defective since lamps usually only have a short, eg 90 day, warranty (I'm speaking in generalities here not specifics to any brand). On the other hand lamps don't have a shelf life, or wear out when not in use so they can be stored indefinitely.
Thus good practice is to use the new lamp right away and keep the older working lamp as a backup. That way you make sure the new one works, while having a "known good" lamp as a backup.
Even if JVC's warranty is better (I haven't followed) I'd think you still might want to use the new one right away so you get the most warranty coverage out of it rather than running your old lamp which is likely out of, or closer to out of warranty.
Other option is to try the new lamp, and after you're sure it works, swap them back.
stanger89 is offline
post #3 of 6 Old 06-25-2013, 10:16 AM - Thread Starter
Quoted: 113 Post(s)
Liked: 54
Thank you very much!
post #4 of 6 Old 06-26-2013, 03:39 PM
larryep's Avatar
yep
run your brand new lamp that came with the projector. order your new lamp around 950 hours on original lamp. take original lamp out when warrenty is up (mine is 1000 hours) the original lamp becomes the back up lamp for all others if it is still good and bright. place oem lamp in projector and run it till it dies or runs dim. then order another lamp, and so on and so on.
larryep is offline
post #5 of 6 Old 06-26-2013, 08:45 PM
Mike Garrett's Avatar
Quoted: 5568 Post(s)
Liked: 3550
Originally Posted by larryep View Post
yep
The new JVC's are 1,000 hours or one year. With most people the one year will come first.
mjgarrett100@gmail.com
Mike Garrett is online now
post #6 of 6 Old 06-28-2013, 03:42 AM
larryep's Avatar
2 weeks with mine at 70 hours. I am on pace for 1500 hrs. a year.biggrin.gif
larryep is offline
Jvc Dla Rs46 Projector
