JVC-DLA X3 wired control - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-02-2013, 01:36 PM - Thread Starter
devunow's Avatar
Hi there...
for some reason my JVC X3 has stopped responding to the remote. (It works fine with the buttons on the back.)
Things I have tried:
The remote works with other projectors, so it is not the remote.
I have switched the codes on the remote still no joy (A code/B code)
I have updated to the latest firmware.
Universal remote does not work. (used to work)
I have disconnected the 3D IR emitter, no joy
Because my projector is very difficult to get to (high on a back wall) is it possible to purchase a wired remote that I can plug in the back?
Or is there a way to control the projector via the serial cable?
ANy help/suggestions are greatly appreciated.
Many thanks
Devun
devunow is offline
post #2 of 4 Old 07-03-2013, 09:37 AM
JonStatt's Avatar
Quoted: 50 Post(s)
Liked: 48
There are TWO IR sensors on the X3. It is highly unlikely that both have failed, although there seems to be a bit of a pervasive issue with the front one failing. Have you pointed the remote right up towards the back of the unit to see if that one is responding?
Many have found that if you leave the projector unplugged for 12 hours or longer, that the IR sensor starts working again.....but the problem eventually returns. Some have had the IR sensor/board replaced.
JonStatt is offline
post #3 of 4 Old 07-04-2013, 08:09 AM - Thread Starter
devunow's Avatar
Great, thanks. I didn't realise there were two!
The IR receiver on the back works fine and I have installed a IR repeater, so all is back to normal...
I appreciate your reply.
devunow is offline
post #4 of 4 Old 08-06-2013, 10:55 AM
Dan P.'s Avatar
I'm also trying to figure out how to use that "remote control" plug on the X3.
http://www.avsforum.com/t/1484667/jvc-rs40-x3-remote-control-port
Dan P. is offline
Jvc
