how does convergence config on lcd/lcos work ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-02-2013, 06:24 PM - Thread Starter
te36's Avatar
Especially on epson or sony vpl-hw50es, how can they do zone based convergence ? I could understand panel wide convergence config by physically shifting panels eg: with piezo or the like. But zone based sub-pixel ? How ????
te36 is offline
post #2 of 6 Old 07-02-2013, 06:26 PM
Seegs108's Avatar
Quoted: 4229 Post(s)
Liked: 2098
None of these companies physically move the panels to converge the units. They use software to pseudo-shift the image. This is also how they do zone-based convergence.
This is also why using too much shift can have negative results on picture quality. There is only so much this software can do if your unit has bad native physical convergence.
Seegs108 is online now
post #3 of 6 Old 07-02-2013, 07:40 PM - Thread Starter
te36's Avatar
Aaah. Too bad. Somebody told me JVC was using piezos to move the whole panel on the higher end LCOS.
So with just software, moving a single pixel wide red line half a pixel would mean to dim it by 50% on the pixel where it belongs and then adding 50% of its brightness to the neighboring pixel ? Yeah, that kinda sucks. I guess i have to see how much of a picture improvement is possible with such an approach at all. Sound as if it's an immediate loss of resolution/sharpness.
I'd rather have an honest mechanical adjustment option, even it it meant that i would have to open the projector and use a screwdriver.
te36 is offline
post #4 of 6 Old 07-02-2013, 07:46 PM
Seegs108's Avatar
Liked: 2098
Maybe the high end units are? I can't think of any way possible to do zone-based convergence shift in a physical manner, though.
post #5 of 6 Old 07-02-2013, 08:14 PM
zombie10k's Avatar
Quoted: 2859 Post(s)
Liked: 2863
if you're lucky enough to get a copy that only needs a full pixel adjustment, you're not going to see any perceivable loss in resolution.
some panels aren't 'clocked' identical and the full pixel shift could fix 1 part of the grid while making another worse. This forces the zone adjustments which has been debated in other threads.
My RS55 is off by about 1/2 pixel with blue (even across the entire panel) when first turning it on and is near perfect after a short warmup. If any color is off, I'd rather it be blue. it's the least perceived color from seating distance.
zombie10k is online now
post #6 of 6 Old 07-08-2013, 06:41 PM
noah katz's Avatar
Quoted: 887 Post(s)
Liked: 305
There's a Catch 22 with that - making it adjustable, as opposed to bonded in place, makes it intrinsically less robust and stable.
Noah
noah katz is offline
Sony Vpl Hw50es 3d Projector
