Stacking 2JVC projectors - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 07-03-2013, 09:05 AM - Thread Starter
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 327
If someone was going to stack to jvc projectors, would the contrast stay the same or would it increase? In instance, if you closed the iris down on two RS66s and get 100,000:1 on both, would it increase or stay at 100,000:1?
blee0120 is online now
post #2 of 27 Old 07-03-2013, 09:21 AM
fierce_gt's Avatar
Quoted: 1772 Post(s)
Liked: 1689
good question. i'd think it'd stay the same, as you'd get double the brightness in both the whites and the blacks
depending your room though, you might notice the increase in whites more than the increase in blacks.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #3 of 27 Old 07-03-2013, 09:31 AM - Thread Starter
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 327
I assume just brightness too
post #4 of 27 Old 07-03-2013, 02:17 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2581
Contrast would stay the same but black level would increase. You're doubling the light output throughout the whole spectrum. For instance, if you were getting .001 ftl at 0IRE and 25ftl at 100IRE with just one projector, when adding another (assuming it's outputting the same exact amount of light and everything else is the same) you are going to double the light a 0 and 100 IRE. So now you're at .002 and 50ftl at 0 and 100 IRE respectively. Real world results will vary obviously.
Seegs108 is offline
post #5 of 27 Old 07-03-2013, 03:54 PM - Thread Starter
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 327
Sounds about right. A dual jvc projector setup would be killer on an AT screen, where you can get about 1600 lumens calibrated at 60,000:1 with the iris open on two rs66s. Probably cost about $12K with b-stock projectors. Finding two good one, lined up correctly would be a pain
post #6 of 27 Old 07-03-2013, 04:42 PM
stanger89's Avatar
Quoted: 3679 Post(s)
Liked: 2047
Aligning two projectors is essentially impossible, you'd need something like the Geobox discussed in the Omega 3D thread to align everything.
stanger89 is offline
post #7 of 27 Old 07-03-2013, 05:01 PM
Mike Garrett's Avatar
Quoted: 7073 Post(s)
Liked: 4779
Also hard to get perfectly aligned.
mjgarrett100@gmail.com
Mike Garrett is offline
post #8 of 27 Old 07-03-2013, 05:01 PM - Thread Starter
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 327
I guess, that's why HP screens are made
post #9 of 27 Old 07-03-2013, 05:29 PM
archiguy's Avatar
Quoted: 3936 Post(s)
Liked: 4086
I remember some guys used to stack those Sony G-90 CRT projectors to double the light output. I think I recall one guy who did it on the Forum (Art?) had some big-shot calibrator there for a week getting those two titanic tanks with six 9 inch guns perfectly aligned. tongue.gif
archiguy is online now
post #10 of 27 Old 07-03-2013, 05:47 PM - Thread Starter
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 327
That member lives close by me, about 25min. I saw his and its nice.
post #11 of 27 Old 07-03-2013, 06:35 PM
stanger89's Avatar
Liked: 2047
There's a big difference between CRTs and Digital Projectors, with a CRT you can (and I'm going to kill the terminology here) adjust the guns/geometry such that you can get two machines perfectly aligned. You can push/pull a portion of the frame (corner, side, etc) essentially independently of each other. This is necessary since no two machine have exactly the same optics/construction/alignment.
With a digital projector you don't have that option, the overall geometry of the output is fixed, you can zoom/shift the image, but it's all proportional across the picture. That means you need to resort to electronics, like here:
http://www.youtube.com/watch?v=yLqkZ45AW-c
post #12 of 27 Old 07-04-2013, 12:46 AM
Thebes's Avatar
Thebes is offline
post #13 of 27 Old 07-04-2013, 01:01 AM
Highjinx's Avatar
Quoted: 642 Post(s)
Liked: 275
Been wondering how a quad blend would go, 4 x X35 JVC's would give one 4k with brightness and CR....at a decent price.
May the success of a Nation be judged not by its collective wealth nor by its power, but by the contentment of its people.
Hiran J Wijeyesekera - 1985.
Highjinx is online now
post #14 of 27 Old 07-04-2013, 01:47 AM - Thread Starter
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 327
It seem as if they did it without much effort
post #15 of 27 Old 07-04-2013, 02:06 AM
Thebes's Avatar
Hi,
yes, it seems. With the lens-shift of these JVC and the focus setting, it seems "easy" and the result is quite amazing, isn't it ? :
One Projector :
Two Projectors :
Thebes is offline
post #16 of 27 Old 07-04-2013, 02:27 AM - Thread Starter
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 327
It looks pretty good. It will bring amazing results if done right. I can imaging getting getting 2 b-stock RS65 or 66s and getting 60K:1 contrast with 15ftL+ on a 165in unity screen. Can probably be done under $10K. How sharp would two eshift images be? I wonder how much you would have to pay to get a performance like that with one projector?
post #17 of 27 Old 07-04-2013, 04:12 AM
jmcguire525's Avatar
you should check out the Ultimate 3D thread, he had two RS40's stacked for passive 3D.
jmcguire525 is offline
post #18 of 27 Old 07-04-2013, 08:15 AM
zombie10k's Avatar
Quoted: 3874 Post(s)
Liked: 3954
that's impressive and looked relatively straight forward to set up. The best part is getting to keep your existing screen and active shutter glasses. Swapping out an existing screen for a silver screen or one with high retention of polarization isn't likely in most folks agenda for a passive system unless they are head over heels for 3D or have a large viewing audience requiring cheap glasses.
The 2.8HP goes a long way to prevent needing a setup like this. The Sharp 30K @ near eye level on my screen is plenty bright in 3D.
zombie10k is online now
post #19 of 27 Old 07-04-2013, 08:56 AM
stanger89's Avatar
Liked: 2047
I'd like to see some close ups of a grid pattern. Hard to make a judgement on how well two 1920x1080 projectors are aligned based on a 600x338 picture on the web.
And remember you have to be aligned a lot better for 2D (without glasses) than you do for 3D (with glasses).
post #20 of 27 Old 07-04-2013, 09:32 AM - Thread Starter
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 327
The HP screen is almost the perfect match, but it can cripple speaker placement. Some like to have the theater experience with audio too.
post #21 of 27 Old 07-04-2013, 10:26 AM
zombie10k's Avatar
Liked: 3954
I don't think it's all doom unless you have an AT rig. With my current setup, my full range front speakers are quite large (~5 feet) with a nice size center channel. The sound stage in the front with the XT32 tuning sounds great.
visually it would be nice to just see the screen. But I'm not giving up the big HP just yet.
post #22 of 27 Old 07-04-2013, 10:28 AM
zombie10k's Avatar
Liked: 3954
you can see the image is a bit softer in the closeup of the 'FOCUS' screen.
post #23 of 27 Old 07-04-2013, 10:34 AM - Thread Starter
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 327
Calibrating would be extremely tricky I think. But laser projectors would be the ideal setup because an external device can be added to add extra lumens. But until those are available and at a reasonable price, there will be a good wait
post #24 of 27 Old 07-04-2013, 02:46 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
You calibrate each one separately either if you are doing a stack or a blend.
mark haflich is offline
post #25 of 27 Old 07-04-2013, 03:44 PM
stanger89's Avatar
Liked: 2047
That's what I thought, but the translated note for that picture sounded like it was saying the other projector was blanked out when you do that, but now that I think about it, that doesn't make sense (unless they physically blocked the other projector).
post #26 of 27 Old 07-04-2013, 03:57 PM
Liked: 1012
In order to have both warmed up the same, the procedure is to block the light from one while you calibrate the other. Because the pixels can't be perfectly aligned, the image will look softer close up. The color temperature of a stack should hower be very close to the maximum deviation of the worst one.
post #27 of 27 Old 07-05-2013, 06:49 AM
archiguy's Avatar
Liked: 4086
Seems like if you needed a super bright image with one of these JVC projectors you'd be better off - both monetarily and from an image sharpness standpoint - cranking the iris wide open, turning the projector up to the "high" setting, and resigning yourself to replacing the lamp every 1000 hours.
Jvc Dla Rs66
