Need Advise: Projector for a living room night viewing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-03-2013, 09:05 PM - Thread Starter
crtone's Avatar
Hello,
I need some advise on selecting a suitable projector for my living room. It will be used only for night viewing with no lights on, but the room has off-white walls and ceiling. Curtain drawn on the windows.
Projector preferences:
1. Motorized zoom and focus
2. Lens memory
3. Noise level ~ 25 db
4. Good contrast , colors, and sharpness.
5. Used for movie viewing, 2D 16:9 mostly, also must have good black and white (4:3) capability.
6. Possible 2.35:1 option
7. Do not care about 3D
The unit will be ceiling mounted, so i need remote control capability (calibration setup etc.)
Projector budget under $ 4000.
I have looked at PT-AE8000 and like what I have read so far. Would also consider JVC DLA-X55R, but not sure about the brightness for my application.
crtone is offline
post #2 of 8 Old 07-03-2013, 09:11 PM
Browninggold's Avatar
Liked: 37
I would look for a Sony VW95. I owned a 90 and worked great in my living room.
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
post #3 of 8 Old 07-03-2013, 09:23 PM
Seegs108's Avatar
Quoted: 4202 Post(s)
Liked: 2089
The VW95 is fantastic choice, but I don't know if he's going to be able to find a new one for under $4000. Another alternative would be a JVC DLA-RS46 or possibly an RS4810 depending on how much they are going for these days. The latter adds e-shift and a color management system which is worth it if you have the money to spend. Your cheapest option would be a Sharp XV-Z30000, but I think the JVCs and Sony projectors are much better for 2D content.
Seegs108 is online now
post #4 of 8 Old 07-03-2013, 10:15 PM - Thread Starter
crtone's Avatar
Thanks for the suggestion. JVC 4810 is in the $ 5000 range, a bit higher than I plan to spend. RS46 is around $ 3500, which is doable.
All JVC projectors list the brightness at around 1200 Lu. I plan a 120" wide screen (16:9 option) with a viewing distance of 16-18 ft. Will it be bright enough, that is the question ?
crtone is offline
post #5 of 8 Old 07-03-2013, 10:18 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
You can find a rs48/x55 for under $4000
blee0120 is offline
post #6 of 8 Old 07-04-2013, 09:24 AM
hessel holland's Avatar
Contact Mike or Craig at AVS
hessel holland is offline
post #7 of 8 Old 07-04-2013, 09:45 AM
zombie10k's Avatar
Quoted: 2817 Post(s)
Liked: 2764
Originally Posted by crtone View Post
Hello,
2. Lens memory
if cost is a concern, the RS46 is a better overall projector than the Panasonic 8000 at the equal price. I've had these in a direct A/B stack for comparison, the JVC has noticeably better 2D PQ. Contrast and sharpness are 2 stand out features of the JVC.
If you are going with a nice size screen (120" or higher) you might appreciate the e-shift in the RS4810/X55.
zombie10k is online now
post #8 of 8 Old 07-04-2013, 11:47 AM
Mike Garrett's Avatar
Quoted: 5575 Post(s)
Liked: 3554
mjgarrett100@gmail.com
Mike Garrett is online now
Sony Vpl Vw95es Full Hd 3d Home Cinema Projector
