JVC DILA-RS 4810 projector and turning on projector using 3.5 mm input on back?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-09-2013, 07:20 PM - Thread Starter
larryep's Avatar
hello forum members
I have learned all the IR commands from the JVC remote. The 1 command that wont work is the power on command. The only way to turn on the projector is to briefly pull out the 3.5 mm connection on back of the projector and use the JVC remote. Once I do this all other learned commands work fine.
any help would be much appreciated
Larry
larryep is offline
post #2 of 2 Old 07-12-2013, 04:06 PM - Thread Starter
larryep's Avatar
I have sent my first hex command through the serial rs232 cable using a freeware program called Hercules 3-2-6. I got the projector to turn on but still can't use xlobby front end software to do it.
larryep is offline
