POWER ZOOM - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-15-2013, 05:57 PM - Thread Starter
DES1's Avatar
Is it typical for home theatre users to watch TV broadcast in their theatre ? (Sports, movies, etc.) I do all the time. For example, if I get 10 minutes into a rented DVD and it's junk, I switch to TV programming. My question is; when I switch to TV, I have to shrink the picture, with the remote control, to fit the screen. I'm planning to upgrade my projector to a Digital Projectors, M300 3D with manual zoom. With a ceiling mounted projector, will I have to drag out a ladder every time I switch from DVD to TV to adjust the picture size ? confused.gif
DES1 is offline
post #2 of 4 Old 07-15-2013, 06:27 PM
Seegs108's Avatar
Quoted: 4961 Post(s)
Liked: 2478
You could always use the built in scaler on your projector so you don't have to zoom in and out to fit the screen every time the aspect ratio changes. That seems like the logical choice here.
Seegs108 is offline
post #3 of 4 Old 07-15-2013, 06:37 PM
Ron Jones's Avatar
Quoted: 903 Post(s)
Liked: 908
What is the aspect ratio (i.e., Width/Height = Aspect Ratio) of your screen? Is It 1.33 (standard definition format), 1.78 (HDTV format), or 2.35 (movie cinemascope format)?
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #4 of 4 Old 07-15-2013, 06:43 PM
stanger89's Avatar
Quoted: 3312 Post(s)
Liked: 1772
Something seems off, you shouldn't have to zoom, TV, DVDs, Blu-ray, Games, it doesn't make any difference. I think we need more info on what projector you have, it's aspect ratio, what aspect ratio your screen is...
stanger89 is offline
