Best projector for watching sports? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-16-2013, 09:10 PM - Thread Starter
daaaaaan's Avatar
I thought the 5020 was the solution for me, but then was informed it wasnt great with motion.
So for a projector that will primarily be watching sports with a few movies, what would you purchase? 106" screen @ 20 feet will be the set up.
5,000< MSRP
daaaaaan is offline
post #2 of 9 Old 07-16-2013, 09:25 PM - Thread Starter
daaaaaan's Avatar
Sony VPL-HW50ES seems to be the best from what I'm reading.
daaaaaan is offline
post #3 of 9 Old 07-16-2013, 09:28 PM
Mike Garrett's Avatar
Quoted: 5553 Post(s)
Liked: 3539
Not if the throw has to be 20' for a 106". The Sony can't shoot a 106" from that far back. The JVC RS45 and the Epson can shoot that size screen from 20'.
mjgarrett100@gmail.com
Mike Garrett is online now
post #4 of 9 Old 07-16-2013, 09:43 PM - Thread Starter
daaaaaan's Avatar
What min size screen woukd the sony do @ 20 feet
daaaaaan is offline
post #5 of 9 Old 07-16-2013, 09:46 PM
Seegs108's Avatar
Quoted: 4195 Post(s)
Liked: 2084
130" Diagonal for a 1.78:1 screen.
Seegs108 is online now
post #6 of 9 Old 07-17-2013, 08:36 AM
humbland's Avatar
Quoted: 327 Post(s)
Liked: 78
We watch a lot of HD sports.
DLP sharpness and motion handling are a good match for sports.
We have the Sharp Z30K and it excels at HD sports. As a bonus, it has state of the art 3D. We watched Wimbledon in 3D. Incredible!
Also, the powered lens controls and placement flexibility make it easy to use. Top it off with a 3 year warranty.
For <$2K it's tough to beat.
humbland is offline
post #7 of 9 Old 07-17-2013, 08:52 AM - Thread Starter
daaaaaan's Avatar
Neglecting cost, would you say the sharp is better than the sony?
daaaaaan is offline
post #8 of 9 Old 07-17-2013, 09:06 AM
humbland's Avatar
Quoted: 327 Post(s)
Liked: 78
I have not seen the Sony, so it's tough to say.
Art at PJ Review had the Z30K as best in class for <$2K.
If you look at the Z30K thread, there are comparisons there. The main complaint seems to be less than accurate color. If that's important to you, then the Sony is probably a better choice (cost not withstanding). The color on the Sharp seems great to me, but I'm not anal about it. If you add the Darbee, the picture is stunning on our HP screen. smile.gif
humbland is offline
post #9 of 9 Old 07-18-2013, 06:05 AM
biliam1982's Avatar
Quoted: 340 Post(s)
Liked: 164
Here's a list from PC of FPJ's that can do 106" @ a 20ft throw.
Not too many on there under $5k. The Sharp that humbland mentioned (which I also own) is.
I also have not seen the Sony but can concur that the Sharp gives an awesome picture!
Having that far of a throw and size screen, most projectors will be close to the limit of the zoom and you'll end up w/ a lot less light on the screen. You may want to consider getting a High Gain screen.
Both humbland and I also have High Gain screens and it helps increase brightness and makes sports look great!
http://www.projectorcentral.com/projectors.cfm?g=1&hide=0&st=1&mfg=&p=&w=&r=13&br=&ll=&ltg=&t=&db=&dt=&c=&ar=&dvi=&wr=&pjl=&pjw=&pjh=&td=20&i=d&is=106&sort=date&sz=15
biliam1982 is online now
Sony Vpl Hw50es 3d Projector , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi
