Returned a BenQ W7000. Need help selecting new projector. - AVS Forum | Home Theater Discussions And Reviews
Old 07-24-2013, 07:10 PM - Thread Starter
JewDaddy's Avatar
Quoted: 178 Post(s)
Liked: 89
I already posted in the under $3,000 projector range. Trying to get as many opinions as possible.
So I need help selecting a projector for my mancave. Im projecting onto a 120" EZ Frame 1.1 gain cinewhite screen from 16 ft. I'm recently on my FIFTH BENQ W7000!!!!!! Yes that's right, 5th. I've had nothing but bad luck out of this thing. I don't know if I'm cursed, or just not meant to own this projector. One positive thing about this whole situation is how well BenQ's Customer Service has handled this. They'be been absolutely great.
Here's my dilemma. I have no freakin clue which projector I should go with. I really enjoy the look of the W7000 for a few reasons. The first being how sharp and crisp the picture is. The second being the great 3D (other than a smidge on the dark side) And thirdly, the motion handling. My biggest complaint from this projector other than the QC of course, would be the black levels, low contrast and the colors just not quite popping like my Sony HX850 LED. No matter how much I turn up the color, or mess with the fine tuning and turning up the saturation, it just never pops. Not sure how to explain it. I guess I'm looking for deep colors and that could possibly go back to the subpar black levels.
So here's what I use my projector for. 50% Movies, 40% Gaming and 10% Direct TV watching. My top pick right now would be the Epson 5020 but after reading through the entire thread, I'm not sure that would be my best choice. I've heard that it has pretty bad lag for video games, bad motion handling and bad convergence/panel allignment. I'm also highly considering the Panasonic PT-AE8000 and possibly the Sony HW50ES if I can find a good enough price.
I'm not sure how recently any of you have been to the movie theater, but I went and watched The Conjuring a couple days ago and saw it at an AMC Theater. BTW, if any of you like horror movies, it was freaking awesome!!! Totally old school with a concept that's been done hundreds of times, but rarely done this well. Highly recommended.
Anyways, They showed it on a Christie Projector and it just looked fantastic!!! The colors really popped, it was almost crystal clear with decent but not great sharpness. I don't know, it just looked like a huge LCD to me. That's what I'm looking for. To be honest, I'm not that big on having an accurate picture. In fact, I kind of prefer an overly processed picture with the dreaded soap opera effect all the way up. I know most people on here would have my head for saying that, but it's just my preference. I'm trying to find something that can maybe get me as close to an LED or LCD experience as possible. Although, I plan on having Chad B calibrate whatever projector I get.
So after saying all this, here is where i would put my top wants in a projector in order.
1 - Sharp, Clear and Crisp. If it has a lot of noise in the picture and looks too soft, I just wouldn't like it.
2 - Good deep saturated colors. I like my picture to pop!
3 - Good to great 3D with good to great motion handling.
4 - Lastly, black levels. I want good to great black levels, but if I can get my top three and sacrifice a little bit of the black levels in the process, I'm ok with that.
Again, The epson 5020 and Panaonic PT-AE8000is at the top of my list but it may not fit what I'm looking for. I would love to get someone's opinion on it or any other projector they think I might like or should consider.
Another option I was considering is waiting for the new BenQ W7500 people have mentioned here on the forums. Sounds like it will give me the same great picture of the W7000 except with better black levels and hopefully better contrast. Any idea when that might become available?
JewDaddy is offline
Old 07-24-2013, 07:32 PM
zombie10k's Avatar
Quoted: 2833 Post(s)
Liked: 2808
With that rear shelf mount setup, you could easily run 2 projectors. It's hard to find 1 model that has all those attributes you listed. a good, affordable combo could be a b-stock RS45 for the movies, and the new Optoma HD25 for 3D and gaming.
if you were down to the 5020 vs. 8000, 5020 all the way imo. I don't think you will like the smoothscreen. 5020 pixel structure is a little harsh up close, but it looks surprisingly sharp at normal seating distance. Blacks are way better than the W7000.
zombie10k is online now
Old 07-24-2013, 08:54 PM - Thread Starter
JewDaddy's Avatar
Quoted: 178 Post(s)
Liked: 89
Thanks Zombie. The rear mount shelf looks a little decieving because I was barely able to fit the W7000 on it. Although, a dual projector setup might ultimately be the way to go for me.
Do you know the biggest pros and cons of both the 5020 and 8000? What exactly is the smoothscreen? If that means a less sharp picture, I have a Darbee that can help with that. How do the black levels of the 8000 compare to the 5020 and the W7000 I had? Also, my front row or seating in my mancave is about 10-11 feet from the screen. Would that be too close for the 5020?
JewDaddy is offline
Old 07-25-2013, 02:54 AM
coderguy's Avatar
Quoted: 339 Post(s)
Liked: 293
8000's black levels about halfway between the 5020 and w7000. Trust Zombie on this, the Epson 5010/5020 easily beats the Panny for image quality. The only reason I'd consider the Panny is if you need less gaming lag for competitive FPS, or if you wanted a CIH / 2.35 setup (but JVC's can do this as well).
Forget gaming lag IMO, one thing that is seldom mentioned about gaming lag is that on a screen as big as a projector, most gamers aren't as good at FPS anyways. So for competitive FPS, you are still better off on a monitor. Just play all other games on the projector is my advice, otherwise none of these projectors really have all the attributes you are wanting.
The JVC RS-46 is better for movies IMO than the Epson, but has even a tiny bit more gaming lag. Personally, I'd go for the JVC, but that's just me, ultimately it's your preferences that decide your fate.
Access HERE from this thread
coderguy is online now
Old 07-25-2013, 05:50 AM
stanger89's Avatar
Quoted: 2694 Post(s)
Liked: 1380
I guess if it were me, and you liked how your W7000 looked, I'd look at the Sharp Z30000. If 3D wasn't on your list, there's a couple great deals on high end DLPs in the classifieds, but they don't do 3D. Another interesting option is the Panasonic PT-RZ470. It's a LED/Laser machine so it could (should?) have really solid/saturated colors (the high end LEDs like the Mico, Vango, Runco, etc all do), though I haven't seen any user reviews of this Panny yet.
Or, since you didn't mention budget, you could always get a Sim2 Lumis 3D Solo and be done with it biggrin.gif
FWIW, you only see about 2000:1 native/sequential contrast on those big Cinema DLPs. wink.gif
stanger89 is offline
Old 07-27-2013, 12:07 PM - Thread Starter
JewDaddy's Avatar
Quoted: 178 Post(s)
Liked: 89
Thanks everyone. I started to look at the Mitsubishi HC5 but the 3d quality has me a little concerned. Everything else about it sounds great though. Anyone have any experience with the HC5 and if so, what are some of the pros and cons? And how is the 3D?
JewDaddy is offline
Old 07-27-2013, 08:23 PM
3dmaven's Avatar
I just watched a little bit yesterday and there was some ghosting, though I had not let the lamp properly warm up. I will probably do a feature length movie tomorrow or Monday, and I will get back to you. It was plenty bright on my 106" screen.
3dmaven is offline
Old 07-28-2013, 10:27 AM
Pete's Avatar
Quoted: 219 Post(s)
Liked: 79
If you can justify spending a bit more, @ $10K or thereabouts (street) you can get into a SIM2 NERO 3D-1. Reviews are excellent and performance is on par with projectors costing much much more.
Pete is offline
Old 07-28-2013, 12:31 PM - Thread Starter
JewDaddy's Avatar
Quoted: 178 Post(s)
Liked: 89
I wish I could. My wife would freaking kill me if I did!!!! Lol
JewDaddy is offline
Old 08-02-2013, 07:42 PM
WynsWrld98's Avatar
Quoted: 280 Post(s)
Liked: 106
It's funny you mention soap opera effect which most people hate but I like it as well, have it cranked up on my Epson 6010 and love it. I have a Darbee too (set to HD 45%). 3D on the Epson is just fantastic, so bright and punchy compared to most of what I see in movie theaters. I absolutely love the 6010, fantastic black levels, 3D great, very sharp looking tweaked with frame interpolation, Darbee, etc.
WynsWrld98 is online now
Benq , Benq W7000 Home Projection System , Sony Bravia 55 Inch Led Tv 3d Support Bravia Hx850 Kdl 55hx850 , Epson 5020ub Powerlite Home Cinema 3d Front Projector , Sony Vpl Hw50es 3d Projector
