NEW RANGE JVC 2014 - Page 133 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 04-13-2014, 01:13 PM
Highjinx's Avatar
Quoted: 382 Post(s)
Liked: 175
Originally Posted by Kris Deering View Post
It would but that doesn't apply here. Even with the iris closed down all the way the new models aren't anywhere near the CR as with the DI. The DI is about 3-4x's the contrast still.
I realise that, however when the user iris set to -15 doesn't the DI have to work less aggressively to provide the same or better black floor?...less aggressive action less negatives?
If such a machine existed, say with a 1,500,000:1 native CR, would it not be preferable to a machine that needed to employ a DI to provide a 1,500,000:1 CR?
May the success of a Nation be judged not by its collective wealth nor by its power, but by the contentment of its people.
Hiran J Wijeyesekera - 1985.
Highjinx is online now
Old 04-13-2014, 01:25 PM
R Harkness's Avatar
Quoted: 1973 Post(s)
Liked: 1685
I was playing with the RS57 DI while looking at my Apple TV's "screen saver" mode (or whatever we'd call it these days), the pattern with the animal photos floating against the black background. I didn't think turning the DI on would make much difference as it wasn't really a "low APL" image. Nonetheless switching the DI on did seem to make a slight difference in the apparent contrast of the image - there seemed to be a slight brightening of the images against the black backdrop, which I presumed was due to the dynamic gamma activating. I've also noticed this effect in some other brighter scenes (that is mixed dark/bright images).
R Harkness is offline
Old 04-13-2014, 06:28 PM
blee0120's Avatar
Quoted: 448 Post(s)
Liked: 237
Originally Posted by Highjinx View Post
Blee a little experiment, run the user iris at -15, but shrink the image, till the bright levels match the larger image, sit at the same ratio(closer now with the smaller image)
Purely from an image quality and dynamics point of view not size, with the ILA/DI engaged, your impressions would be interesting.
The picture looked dimmer but the perceived blackness on dark scenes looked similar with the aperture at -15 and 0. In fact, with the iris open, the blacks looked better because of the brightness
blee0120 is online now
Old 04-13-2014, 08:05 PM
Highjinx's Avatar
Quoted: 382 Post(s)
Liked: 175
If the image was made smaller to match max brightness when the iris is O on the large image vs -15 on the smaller image, it should not any dimmer...just smaller.
Old 04-14-2014, 05:06 AM
blee0120's Avatar
Quoted: 448 Post(s)
Liked: 237
I forgot you asked me to shrink the image. Ill try that later. But the CR with the DI looks the same, I still prefer the iris open.
Old 04-14-2014, 02:12 PM
Highjinx's Avatar
Quoted: 382 Post(s)
Liked: 175
I can definitely understand that....brightness is seductive!
Old 04-14-2014, 02:24 PM
mbw23air's Avatar
Quoted: 160 Post(s)
Liked: 152
With the new iris I definitely like the picture more with my iris at 0.
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Oppo BDP-93 blu-ray player Panasonic UB-900 UHD blu-ray player
mbw23air is offline
Kris Deering's Avatar
Quoted: 1717 Post(s)
Liked: 2710
Absolutely. I'm just saying for the example you listed. If you are getting the peak white you want from the JVC with hte iris completely closed, more power to you!!
My Home Theater
Kris Deering is offline
Old 04-14-2014, 02:27 PM
Liked: 2710
That it is, but the funny thing is our eyes adapt to what they see very well. So going from a high brightness projector to a high contrast/how brightness projector would be easier than the opposite. It is actually pretty easy to go to a lower brightness so long as you don't jump back and forth. Your eye adapts over a very short amount of time. But if you are used to inky blacks like the JVC has, it is hard to go to a lower contrast display because your eye never adapts to that. Personally, I want both but at the moment I'm sticking with inky blacks.
My Home Theater
Old 04-14-2014, 02:28 PM
blee0120's Avatar
Quoted: 448 Post(s)
Liked: 237
I don't think its much of the brightness, it just the CR would look the same with the iris open or closed on dark scenes.
Old 04-14-2014, 02:32 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3230 Post(s)
Liked: 3189
I like decent black levels, but I never get used to less brightness. Not anymore. In fact, I just changed my lamp out early. The brightness on my Lumis with only 7 hours of lamp time is very nice ! 12 foot lamberts looks dim. It makes me depressed! smile.gif
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
Old 04-14-2014, 02:38 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
mark haflich is offline
Old 04-14-2014, 02:52 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3189
If that were true Mark I'd switch back to 2Buck Chuck every time I installed a fresh lamp. Fact is, good wine tastes better, and a bright projector looks better. smile.gif
Old 04-17-2014, 11:24 AM
Liked: 1010
At high altitude you really need to substantial aerate the reds, cheap or expensive.
In case anyone doesn't know, 2 Buck Chuck, is a brand that Trader Joe's sells.
Old 04-17-2014, 12:22 PM
DavidHir's Avatar
Quoted: 1753 Post(s)
Liked: 1357
I'm at about 13.6 ftL with my RS4810 and that seems perfect to me (1.1 gain screen, 2:35, 108" wide, nearly 10 feet back, completely blacked out room).
DavidHir is offline
Old 04-17-2014, 03:02 PM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
Art has posted his review of a RS4910 at Projector Reviews. Some direct comparisons with a Sony VW600 are included.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
Old 04-17-2014, 04:13 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3189
I'm pretty much addicted to 16 - 18 foot lamberts in a dark theater. But that's just me. I need to change lamps more often but what the heck - you only live once !
Old 04-17-2014, 04:25 PM
Highjinx's Avatar
Quoted: 382 Post(s)
Liked: 175
Has anyone done a detailed analysis on the JVC DI: User iris at 0 with DI vs user iris at -15 with DI(with smaller image size to match brightness of larger image at user iris at 0).......keen to hear of differences in image quality.
Old 04-17-2014, 05:04 PM
blee0120's Avatar
Quoted: 448 Post(s)
Liked: 237
I did it yesterday when I watched the new Hobbit. I paid attention to scenes where the DI worked. The dark scenes actually looked the same. I'm sure the two higher models would be a bigger difference. Going from 30k to 45k probably will not make a huge difference.
Old 04-17-2014, 06:34 PM
DavidHir's Avatar
Liked: 1357
That would seem very bright to me.
However, even on my Panasonic 65" VT60 I only like 31 ftL in a dark room when a lot of people are at 35-40ftL (or more) on that display.
DavidHir is offline
Old 04-17-2014, 10:17 PM
Kamikaze13's Avatar
Quoted: 104 Post(s)
Liked: 49
So I watched Avatar tonight which looked absolutely stunning but 5 or 6 times the picture flickered, and 4 or 5 times the picture flashed black for a split second.
Has anyone experienced this? Feels like an HDMI issue?
VIDEO: JVC DLA-RS57U Projector / 122″ EluneVision Reference Studio 4K Cinemascope Screen - Oppo BDP-103 Blu-Ray Player - PlayStation 3 AVR: Anthem MRX-1120 SPEAKERS: Paradigm Monitor 11 Mains - Paradigm Monitor CC-390 Center - Paradigm Monitor ADP-390 Surrounds x 4 - Polk MC60 Atmos Ceiling x 4 SUBWOOFERS: SVS PB2000 / Velodyne DPS-12
Kamikaze13 is offline
Old 04-18-2014, 02:15 PM
Highjinx's Avatar
Quoted: 382 Post(s)
Liked: 175
Thanks Blee.
I guess the advantage with closing the user iris down(as long as one is getting the peak white/brightness one wants) is the variation of CR when the DI is performing it's function is less...perhaps 10:1 when the user iris is open to 3:1 when the user iris is closed.
Old 04-19-2014, 11:21 AM
JOE-C's Avatar
Using the 4910 DI I notice on a movie's end credits with white letters on a black backround the white lettering will be bright then get dim in the same scene then on the next set of white letters be bright again at first and get dim again ( it will not do this on every set of new lettering). I don't notice this on any other parts of the movie or if I turn the DI off- only on the end credits. Not sure if this has been discussed before. Just wondering if that is what others are experiencing and if that is normal DI behavior for this projector.
JOE-C is offline
Old 04-19-2014, 12:59 PM
blee0120's Avatar
Quoted: 448 Post(s)
Liked: 237
Thats how a DI works. The goal is to not notice it during the actual movie. The end credits should not really bother anyone, but some people can be bother by it
Old 04-19-2014, 01:09 PM
R Harkness's Avatar
Liked: 1685
Yeah, I think we all notice that on credits. I'm fine with it given the DI seems to give visible benefits in movie watching and I don't notice it, mostly, during the actual movie. I didn't notice the DI once last night watching Captain Philips which went back and forth a lot between super dark and bright scenes, and I even looked for it sometimes (this place is a curse!)
cardoski likes this.
Old 04-19-2014, 03:36 PM
Highjinx's Avatar
Quoted: 382 Post(s)
Liked: 175
Joe...what happens during the credits, if the user iris is closed down to -15, does the DI pumping get visually less?
Old 04-19-2014, 04:25 PM
Liked: 2710
It isn't pumping as much as maximizing contrast based on APL. But with iris clamped the white level won't change much as the iris can only go down a bit more. JVC doesn't boost whites as much when the image is that dark, that is why some post credits are dim and some aren't. Depends on overall APL.
My Home Theater
Old 04-19-2014, 09:22 PM
JOE-C's Avatar
I haven't tried that but I would imagine it would just as Kris states.
JOE-C is offline
Old 04-19-2014, 09:54 PM
krichter1's Avatar
Quoted: 1752 Post(s)
Liked: 2001
Most have found about -7 iris & Auto2 to be the sweet spot for minimizing visible white blooming (use the movie The International Darin & Kris pointed to months ago when Armin Muehler-Stahl is being interrogated by Clive Owen).
Kevin
You only live once, but if you live it right, once is enough.
==> The Richter Family 4K/3D Theater
krichter1 is online now
Old 04-20-2014, 12:39 AM
Highjinx's Avatar
Quoted: 382 Post(s)
Liked: 175
Thanks gentlemen.....I'm trying to figure out what JVC nay do next...use a advanced next gen E-shift panel like a 4th panel to provide local dimming.....?
Sony Vpl Vw1000es Projector , Jvc Dla X900r , Jvc Dla X700r
