NEW RANGE JVC 2014 - Page 76 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2251 of 4136 Old 12-17-2013, 08:36 PM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
Can someone please post the physical specs on the RS57 – i.e. weight, length, width, height? JVC’s site doesn’t appear to have this detail (yet). Trying to figure out if I could build a shelf for it at the back of the room (~19’ back from the screen) instead of a ceiling install, and if so how deep it will need to be and how much weight it has to handle. Thanks.
Citivas is offline
post #2252 of 4136 Old 12-17-2013, 08:37 PM
cischico's Avatar
Quoted: 128 Post(s)
Liked: 95
Here you go
Width: 17 7/8"/455mm
Height: 7"/179mm
Depth: 18 1/2"/472mm
Weight: 33lb/15kg
cischico is offline
post #2253 of 4136 Old 12-17-2013, 08:52 PM
ScottJ's Avatar
Quoted: 318 Post(s)
Liked: 162
Also keep in mind, assuming it's the same as the 2013 models, it needs 200mm clearance in rear for ventilation.
ScottJ is offline
post #2254 of 4136 Old 12-17-2013, 08:53 PM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
Originally Posted by cischico View Post
Here you go
Height: 7"/179mm
Weight: 33lb/15kg
Citivas is offline
post #2255 of 4136 Old 12-17-2013, 08:55 PM
StevenC56's Avatar
Quoted: 219 Post(s)
Liked: 80
That's what I'm planning to do with the X500R I have ordered. My Mits HC400 is ceiling mounted, but it has to be with it's huge offset and it only weighs something like 8 lbs.
StevenC56 is offline
post #2256 of 4136 Old 12-17-2013, 09:03 PM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
So I’d need a shelf at least 26” deep? That’s pretty substantial.
Anyone have real world experience with shelf vs. ceiling mount? Seems like my optimal throw position will be the back of the room whether I ceiling or shelf mount.
Citivas is offline
post #2257 of 4136 Old 12-18-2013, 04:51 AM
Manni01's Avatar
Quoted: 3359 Post(s)
Liked: 3084
There is no need for a 200mm clearance at the back if you shelf mount on an open shelf (ie with good ventilation on the sides and up). I have an rs45 (same chassis) mounted almost flush to the back wall (about 30-40mmn gap due to plugs/cables, I used a right angle adapter for the power and HDMI cables to put it as far back as possible) and there is no ventilation/overheating issue, even in high lamp. I had it installed that way for about two years. I checked with JVC UK before doing this, and they had no issue with that installation.
You might want to do the same with JVC USA just to make sure your warranty won't be voided, but from a practical point of view it works absolutely fine shelf-mounted with a 30-40mm clearance with the back wall if you use right angled adaptors like I do for power/HDMI. You might need 70-80mm with standard cables, possibly up to 10mm with extra-thick cables.
My shelf is 18" deep (back wall to front of shelf) and the front feet of the PJ rest fully on the shelf. The next shelf is 11" above (but isn't wider than the PJ) and there is nothing to the left/right of the shelves.
Of course there might be some minor variations with this year models as they are more silent, so the fans might spin a bit slower, but the back vents are from air intake only (not exhaust, which is through the front vents) and they are angled, so there shouldn't be any issue really.
Manni01 is online now
post #2258 of 4136 Old 12-18-2013, 04:56 AM
jstach500's Avatar
Quoted: 44 Post(s)
Liked: 43
I'm upgrading from an old JVC RS-1 to the 4910 and couldn't be more excited. Do you think it would be worthwhile for me to run a network cable to the projector? I am not interested in using a phone or tablet to control it, and I can temporarily connect a network cable if I need to perform a firmware update every now and then. Are there any other reasons for running a network cable to it? Thanks.
jstach500 is offline
post #2259 of 4136 Old 12-18-2013, 06:46 AM
krichter1's Avatar
Quoted: 2048 Post(s)
Liked: 2293
No other benefit of running the RJ45 if you don't use IP cmds and can hook one up temporarily for any updates needed. wink.gif
jstach500 likes this.
Kevin
You only live once, but if you live it right, once is enough.
==> Our 4K/3D Immersive Theater
krichter1 is offline
post #2260 of 4136 Old 12-18-2013, 06:51 AM
viper14's Avatar
Quoted: 41 Post(s)
I curentally Have a Panasonic PT-AE7000 projector that i will be replacing with the JVC-X700/RS57, the back of my projector is flush mounted to the wall, with the drywall cut out on both sides and 2 120MM pc fans installed on the back side to help pull in air to the projector does anyone think this will be a problem with the JVC i've used this setup on a few different panasonic projectors with no problem but i know the JVC is longer and taller so i'll need to modify the box anyway i cant really make the box any longer so more of the projector might stick out of the front and also stick out the back side in-between the wall. anyone think this will cause an issue with the JVC?
viper14 is offline
post #2261 of 4136 Old 12-18-2013, 08:40 AM
R Harkness's Avatar
Quoted: 2116 Post(s)
Liked: 1823
Good to see a bunch of respondents to the "Which JVC Projector Have You Ordered?" roll call.
Looks like we'll have some reports rolling in soon.
BTW, I nominate lpnaz480 and jollyguy23 as most likely to be the first to receive and post about the new JVC projectors. wink.gif
R Harkness is offline
post #2262 of 4136 Old 12-18-2013, 08:55 AM
Citivas's Avatar
Quoted: 317 Post(s)
Liked: 191
Looks like I may have the projector before the full room setup, including the audio. If I wanted to preview the projector on a white all, will a typical sound bar be adequate for audio (not quality I get it, but technically), or will I likely have audio sync issues that I’d need an AVR to correct?
Citivas is offline
post #2263 of 4136 Old 12-18-2013, 10:53 AM
noah katz's Avatar
Quoted: 1099 Post(s)
Liked: 380
Getting 4910 from AVS, have RS10 now
noah katz is offline
post #2264 of 4136 Old 12-18-2013, 11:29 AM
StevenC56's Avatar
Quoted: 219 Post(s)
Liked: 80
X500R on order. Using a Mitsubishi HC4000 currently. 105" wide 2.35 Seymour AV CenterStage XD retractable screen.
post #2265 of 4136 Old 12-18-2013, 11:32 AM
R Harkness's Avatar
Liked: 1823
So you've waited about 4 generations and will be getting double the contrast at a great price. Nice.
post #2266 of 4136 Old 12-18-2013, 11:44 AM
R Harkness's Avatar
Liked: 1823
I see there are two top end models this year:
DLA-RS6710 ($12,499 suggested retail), DLA-RS67 ($11,999),
Out of curiosity, does anyone know what makes the RS6710 more expensive?
post #2267 of 4136 Old 12-18-2013, 11:48 AM
StevenC56's Avatar
Quoted: 219 Post(s)
Liked: 80
5 year warranty instead of 3, plus an extra bulb. Factory QC as well I think.
post #2268 of 4136 Old 12-18-2013, 11:49 AM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2581
I'm fairly certain it has an additional quality control check and it has an extended warranty over the RS67.
Seegs108 is offline
post #2269 of 4136 Old 12-18-2013, 12:33 PM
jschefdog's Avatar
Earlier someone posted a link to the PDF manual for all the 2014 JVC projectors. It has detailed drawings with dimensions and info about clearance under the specifications section. But I don't remember the link.
John S
jschefdog is offline
post #2270 of 4136 Old 12-18-2013, 12:51 PM
viper14's Avatar
Quoted: 41 Post(s)
Im Switching to the RS57/X700 from a panasonic pt-ae7000, before that i had the pt-ae5000,4000,3000. so this is my first jump from Panasonic to JVC, has anyone else here made the switch at some point from the panasonic's to the JVC's, i've swapped projectors almost every year for the past 5, i only ever seem to run up 200-300 hours per, i figured this time making the switch to a way better model might keep me on the same unit for a few years... worked out well tho because every unit i've purchased in the past came with extra bulb so wasn't too hard to re-sell, my x700 also came with 2 pairs of glasses, the RF glasses adapter and a spare bulb.
viper14 is offline
post #2271 of 4136 Old 12-18-2013, 12:52 PM
StevenC56's Avatar
Quoted: 219 Post(s)
Liked: 80
https://www.dropbox.com/s/25n7uja7sxtibnu/Manuel%20JVC%20X500%2C%20700%20et%20900.pdf
post #2272 of 4136 Old 12-18-2013, 01:00 PM
R Harkness's Avatar
Liked: 1823
Not sure how relevant it is but I started with an older Panasonic AE900 projector and moved to the JVC RS20 (50,000:1 contrast) 4 years ago. It was of course a huge upgrade in every way.
When I bought my RS55 projector 2 years ago I sold my RS20 to my friend who also replaced his Panasonic projector and, again, he was just giddy at the increase in contrast and over all
picture quality.
You are going for an absolute killer projector (in all likelihood) with almost matchless contrast at this point, so it should be a keeper and quite an upgrade.
post #2273 of 4136 Old 12-18-2013, 01:06 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4025 Post(s)
Liked: 4078
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #2274 of 4136 Old 12-18-2013, 01:12 PM
Mike Garrett's Avatar
Quoted: 6957 Post(s)
Liked: 4652
mjgarrett100@gmail.com
Mike Garrett is online now
post #2275 of 4136 Old 12-18-2013, 01:12 PM
erkq's Avatar
Quoted: 664 Post(s)
Liked: 465
Originally Posted by Craig Peer View Post
Well, then... I'm doing it even "right"-er! I've got an RS-20 and I'm waiting for the next generation next year!
erkq is offline
post #2276 of 4136 Old 12-18-2013, 01:35 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4078
We have plenty of brand new shiny projectors available in case you change your mind ! wink.gif
post #2277 of 4136 Old 12-18-2013, 02:34 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
If only they were not so shiny though I really can't imagine case reflectiveness causing any change in performance in a black pit. smile.gif
mark haflich is offline
post #2278 of 4136 Old 12-18-2013, 02:53 PM
Liked: 4652
post #2279 of 4136 Old 12-18-2013, 02:55 PM
Sailor Bill's Avatar
I'm getting an RS4910 to replace my ailing Panasonic Ae900u. Just need to muddle through which DIY screen and/or receiver to complement it!
Sailor Bill is offline
post #2280 of 4136 Old 12-18-2013, 02:55 PM
Liked: 1012
Your new one is a Sony, of course its not shiny. Trick answer, nice try.
Sony Vpl Vw1000es Projector , Jvc Dla X900r , Jvc Dla X700r
