Replaced bulb and now get color banding/ Perhaps just replace projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-21-2013, 01:26 PM - Thread Starter
tut2sc's Avatar
Recently replaced bulb in my MARANTZ VP11s2 projector. I started to notice this weird thing happening in A LOT of darker scenes (or portions of scenes .... like backgrounds that were out of focus) in the gradation from dark to light - particularly on faces. It looked almost like solarization. I researched and I THINK this is called color banding. It's like what should be a smooth gradation becomes defined lines. Hard to describe.
The thing is - I had never seen it before. My installer checked cables etc and all was fine. Finally, just to cover all bases, we reinstalled the OLD bulb (thank goodness we kept it) - and VOILA - "banding" is gone.
My installer is going to put the new bulb back in and see if the banding returns - but I was wondering: has anyone ever experienced this???
Also - since this projector is getting old, I have been looking into getting something new. My installer recommends the Digital Projection Cine 260, but I got to test drive their super bright 400 model (with its settings kicking down the lumens to @ 2500) and saw NOTHING but rainbows. Does higher lumens create more rainbows for DLP? And with the advances in LCOS, do the newer SONY or JVC LCOS models costing @8K stand up to the great pic of the old Marantz DLP?
tut2sc is offline
post #2 of 2 Old 08-21-2013, 01:53 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Don't know why a lamp would cause banding BUT I just got a new to me PD8150 that was doing the same thing only in very bright color gradients. Had to adjust the color wheel timing in the service menu to correct it
http://www.avsforum.com/t/1485284/planar-8150-posterization-solarization-fix-color-wheel-timming-in-service-menu/0_100.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Marantz Vp 11s2 Dlp Projector
