Projector Advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-28-2013, 08:43 PM - Thread Starter
ShenToN's Avatar
Hi guys,
I'm halfway building my new batcave. The size will be 16 ft by 23 ft. I had ordered 133" diagonal 1.0 Gain fixed screen. Any recommendations on which projector will be suitable for the screen? The room will be totally light controlled. With all the walls painted black. Thanks you smile.gif
ShenToN is offline
post #2 of 2 Old 08-28-2013, 10:52 PM
youngmic's Avatar
Sounds very similar to my situation. Take a look at the thread "Seeking Projector Advice". Maybe we can learn together. smile.gif
youngmic is offline
