HDMI 2.0 Spec. Released - AVS Forum | Home Theater Discussions And Reviews
post #1 of 146 Old 09-04-2013, 05:49 AM - Thread Starter
Ron Jones's Avatar
Quoted: 907 Post(s)
Liked: 917
This was already posted this morning in the IFA 2013 thread but I felt it needed the visibility of its own thread.
Info from HDMI 2.0 press release:
HDMI 2.0, which is backwards compatible with earlier versions of the HDMI specifications, significantly increases bandwidth up to 18Gbps and adds key enhancements to support continuing market requirements for enhancing the consumer video and audio experience. New functionality includes:
4K@50/60, (2160p), which is 4 times the clarity of 1080p/60 video resolution
Up to 32 audio channels for a multi-dimensional immersive audio experience
•Up to 1536kHz audio sample frequency for the highest audio fidelity
•Simultaneous delivery of dual video streams to multiple users on the same screen
•Simultaneous delivery of multi-stream audio to multiple users (up to 4)
•Support for the wide angle theatrical 21:9 video aspect ratio
•Dynamic synchronization of video and audio streams
•CEC extensions provides expanded command and control of consumer electronics devices through a single control point
HDMI 2.0 does not define new cables or new connectors. Current High Speed cables (Category 2 cables) are capable of carrying the increased bandwidth.
Note the part that I have highlighted above that current high speed cable can handle the increased bandwidth of HDMI 2.0. Also of note is support for 4K UHD video at up to 60Hz, up to 32 channels of audio and also support for 'scope' aspect ratio of 21:9.
The new spec. is available for download only to "adopters" that belong to the HDMI organization. I guess we may have to wait for this Friday's (6 Sept.) press conference to find out more about what HDMI 2.0 will support, unless someone with access to the spec. posts the details earlier.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #2 of 146 Old 09-04-2013, 06:03 AM
Grifo's Avatar
Quoted: 36 Post(s)
Originally Posted by Ron Jones View Post
HDMI 2.0 does not define new cables or new connectors. Current High Speed cables (Category 2 cables) are capable of carrying the increased bandwidth.[/indent]
up to you does this mean that products like Sony 1000 or Ada cinema reference machIV could be just firmware upgraded?eek.gif
mmm too good to be believed....
Grifo is offline
post #3 of 146 Old 09-04-2013, 06:21 AM - Thread Starter
Ron Jones's Avatar
Quoted: 907 Post(s)
Liked: 917
I would expect the HDMI transmitter/receiver chip(s) will be different for HDMI 2.0, so No, not just a firmware update for the Sony VW1000es or other devices with HDMI 1.3 or 1.4 chips. I suspect that even though HDMI 2.0 can use the existing 'high speed' HDMI cables the max. cable length, for a given cable design, will be less when carrying 4K at 60Hz than what it is for the most demanding 1080p signals (e.g., 1080p/60 with deep color or 1080p 3D)
Ron Jones
post #4 of 146 Old 09-04-2013, 06:42 AM
Shepardos's Avatar
Quoted: 60 Post(s)
what exactly is the support of 21:9? Does this mean that it will be directly transferred without the need of cropping?
any news of enhanced 3D support for 1080p or 4k?
Cheers
S.
Shepardos is offline
post #5 of 146 Old 09-04-2013, 07:56 AM - Thread Starter
Ron Jones's Avatar
Quoted: 907 Post(s)
Liked: 917
Cheers
S.
It appears that the video content can be flagged as being in 21:9 'cinemascope' format. This may imply that the full 4K UHD vertical resolution (2160 pixels) is being used and will need to be stretched horizontally to restore the 21:9 aspect ratio for display, or it may just the there to let the display know that the content is in 'scope' format, but it still recorded as letterboxed (as is the case with current blu-rays). Won't know for sure until the details of the HDMI 2.0 spec. are leased to the public. Press conference planned for this Friday should help fill in some of the blanks as far as what HDMI 2.0 actually supports, or doesn't.
Ron Jones
post #6 of 146 Old 09-04-2013, 08:25 AM
stef2's Avatar
Quoted: 411 Post(s)
Liked: 244
I am so happy to see new PJ (sony and ?) already have hdmi 2.0 included...with no upgrade needed. I will buy my next PJ within a few months and I will not have to send it back after a couple of months for this upgrade...UPS handling my dear high end digital projector had me worried a lot!...
stef2 is offline
post #7 of 146 Old 09-04-2013, 12:45 PM
Gradius2's Avatar
Quoted: 20 Post(s)
21:9 is something it should never ever been mentioned (it was by Philips).
Actually the CORRECT one (as correct it won't lead you to more confusion) is 2.37:1
So there you go.
Good to read:
http://www.theregister.co.uk/2013/09/04/hdmi_20_spec_published/
[]s,
Fernando
Gradius2 is offline
post #8 of 146 Old 09-04-2013, 12:51 PM
blee0120's Avatar
Quoted: 561 Post(s)
Liked: 278
Looks like my equipment can stay the same, just a new Oppo
blee0120 is online now
post #9 of 146 Old 09-04-2013, 12:57 PM - Thread Starter
Ron Jones's Avatar
Quoted: 907 Post(s)
Liked: 917
The only existing 'equipment' mentioned that will be compatible with HDMI 2.0 are the high speed cables and the physical HDMI connectors. Existing pieces of electronics with HDMI 1.4 inputs/outputs will not be compatible when you are wanting to use the new features of HDMI 2.0. HDMI 2.0 will be backward compatible with HDMI 1.4 and HDMI 1.3. This means, for example, if a HDMI 2.0 device is connected to a HDMI 1.4 device they well talk to each other and the HDMI 2.0 equipped device will only support the features that can be supported by the HDMI 1.4 equipped device.
Ron Jones
post #10 of 146 Old 09-04-2013, 01:01 PM
blee0120's Avatar
Quoted: 561 Post(s)
Liked: 278
Well, the Oppo have hdmi inputs, which they should keep. My audio is already going through my Oppo
post #11 of 146 Old 09-04-2013, 01:58 PM
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
One of the new features is that is says it supports 4:2:0 chroma sampling.
Was this not supported in previous HDMI releases? Is that why would couldn't have what Blu Rays were natively encoded in output to displays?
IF that is the case, this could be a great feature that all projectors/ TVs / Blu Ray players could implement. No more unnecessary conversion to 4:2:2 or 4:4:4.
hifiaudio2 is offline
post #12 of 146 Old 09-04-2013, 02:42 PM
madshi's Avatar
Quoted: 575 Post(s)
Liked: 542
Yes, 4:2:0 support is new, it was never supported by HDMI, or DVI, for that matter. I wish it had been supported since day 1, but it was not. Now they added it, but not to help image quality, but rather to save bandwidth for 4K transport. Still, it's a welcome addition.
madshi is offline
post #13 of 146 Old 09-04-2013, 03:21 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
It will hurt image quality but reduce 4K data requirements.
mark haflich is offline
post #14 of 146 Old 09-04-2013, 03:25 PM
madshi's Avatar
Quoted: 575 Post(s)
Liked: 542
No, it will not hurt image quality, as long as the source material is encoded in 4:2:0, which 99.9% of today's content is. With the single exception of RedRay/Odemax.
madshi is offline
post #15 of 146 Old 09-04-2013, 03:26 PM
Liked: 1012
Your right with respect to source encoded in 4:2:0. My fear is that 4K souces will now also be encoded at 4:2:0 and that would far less than ideal.
post #16 of 146 Old 09-04-2013, 10:03 PM
Wizziwig's Avatar
Quoted: 1251 Post(s)
Liked: 904
The primary source for 4:4:4 60hz native 4K content is going to be gaming via PC or next-gen consoles. Does this mean all future 4K TV gaming will be stuck at 4:2:0 because of HDMI 2.0 limitations? That can't be right.
Wizziwig is offline
post #17 of 146 Old 09-04-2013, 11:00 PM
madshi's Avatar
Quoted: 575 Post(s)
Liked: 542
If my math is correct 60Hz 4:4:4 with 8bit RGB should fit into the HDMI 2.0 bandwidth. So it should be technically possible, if they use chips which can handle the full HDMI 2.0 bandwidth. However, it's possible that cheaper devices will use cheaper chips and as such might not support the full bandwidth. Or it could be possible that I made a mistake, after all I did it late last night...
madshi is offline
post #18 of 146 Old 09-05-2013, 03:41 AM
Liked: 1012
post #19 of 146 Old 09-05-2013, 05:58 AM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
Is there any official information from the HDMI group that 1080p 60hz 3D is a mandatory format?
Also, how about 4k 3D at 60hz?
conan48 is offline
post #20 of 146 Old 09-05-2013, 07:36 AM
Matrixfan's Avatar
While a confirmation would be a relief for us PC gamers, it shouldn't be a problem. 120 Hz 1080p should have in theory the same bandwidth requirement as 30 Hz 4K.
Matrixfan is offline
post #21 of 146 Old 09-05-2013, 10:33 AM
blee0120's Avatar
Quoted: 561 Post(s)
Liked: 278
I know we get to know actually whats going on tomorrow but I saw it said 8 bits. I thought the higher bit of color was going to make more of a difference than the resolution.
post #22 of 146 Old 09-05-2013, 11:00 PM
ICvdo's Avatar
Is there 4K 3D support?
ICvdo is offline
post #23 of 146 Old 09-06-2013, 09:48 AM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
Yes, but only up to 30hz.
conan48 is offline
post #24 of 146 Old 09-06-2013, 07:34 PM
Gradius2's Avatar
Quoted: 20 Post(s)
They did on purpose, never offer all if you can do it slowly and in a very profitable way.
[]s,
Fernando
Gradius2 is offline
post #25 of 146 Old 09-07-2013, 05:05 AM
Liked: 1012
I think the webnair on Thursday will not tell us a lot more that has been publically announced. Only forum members have access to the actual specs which will undoubtedly be revised or clarified etc over time. A forum member has access but not the right to disclose. The big message is no new cables or connectors required and video bandwidth increase to allow 4K 60 and 4K 39 in 3D. A lot of audio enhancement but here we don't care much about them.
post #26 of 146 Old 09-07-2013, 06:38 AM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
It's a sham the 2.0 spec is ALREADY outdated and it's not even out yet. The Hobbit and it's sequels were shot at 4k 48hz in 3D, and Avatar is most likely gonna be shot at 4K 60hz 3D (not confirmed yet) yeah thats only a few movies right now, but I wouldn't be surprised if more 3D films are shot at 4k 48hz or 60hz. While you lose some of the "film" look with 48hz, the 3D fluidity is stunning with the higher refresh rate. Now the wait begins for HDMI 3.0. LOL
conan48 is offline
post #27 of 146 Old 09-07-2013, 07:01 AM
Liked: 1012
The specification is a political action and does not represent what is technically achievable. I guess one will have to buy a commercial theater machine and arrange for DCI content, which can be done, if one wants to get what a commercial state of the art theater can do. Of course you want get the higher contrast and low black levels a commercial theater environment can't support. But HDMI 2.0 is mostly for consumers and their toys. Conan. You and I are also outdated in many ways. smile.gif
post #28 of 146 Old 09-07-2013, 07:33 AM - Thread Starter
Ron Jones's Avatar
Quoted: 907 Post(s)
Liked: 917
It's my understanding that the Hobbit, when shown in theaters at high frame rate (i.e., 48 fps), was only shown with 2K resolution for the 3D presentation. It was said that limitation was due to the interface (non HDMI) used on the commercial digital cinema projectors. I do wonder if HDMI 2.0 will at least support 1080p 3D signals at up to 60Hz even if 4K UHD 3D signals are limited to 30Hz. Also for the 4K signals, there is still the question of what bit depths will be supported at the various supported refresh rates (i.e., up to 60Hz). I would like to hear from anyone attending IFA that sat in on the HDMI 2.0 press conference that was held at noon on Friday. Perhaps they provided more info on HDMI 2.0's capabilities beyond those mentioned in their brief press release. The HDMI organization will be at CEDIA Expo, so perhaps they will be willing to answer some more detailed questions there.
Ron Jones
post #29 of 146 Old 09-07-2013, 08:08 AM
coolscan's Avatar
Quoted: 18 Post(s)
Liked: 88
It was only shown in 2K (in all formats) because they haven't made a 4K version yet.
But if they do make a HFR 4K~3D version they can't release it for consumers because it can't be played back through HDMI.
I believe there is nothing more exciting hidden in the specs. They could as well called this HDMI 1.5 for the little improvements they have made over vs.1.4.
Best thing to ask if somebody encounters anybody from the HDMI forum is to ask why the heck they didn't include 120fps 4K.
That would have opened up some incentives for both display and content creators to release some more inventive stuff in the next few years.
coolscan is offline
post #30 of 146 Old 09-07-2013, 01:16 PM
Liked: 1012
Its all done by votes. Whatever is not there is mostly likely because not enough forum members would vote for it. Some of it MIGHT require a new cable I SUPPOSE and not many members wanted to go there.
Sony Vpl Vw1000es Projector
