Blu-ray 4K UHD - coming 2015? - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 1518Likes
post #991 of 4965 Old 07-15-2014, 09:10 AM
turnne1's Avatar
Quoted: 1991 Post(s)
Liked: 489
Originally Posted by Manni01 View Post
Just found that the new Onkyos (1030, 3030 available this summer), on top of their limited HDMI 2.0b speed, only support HDCP 2.2 on one input (HDMI IN 3) and one output (MAIN HDMI OUT), so absolutely useless for switching more than one 4K protected source, or if you have more than one 4K display.
No interest vs using the dual output of your source if you have only one 4K protected source.
Such a huge fail for ALL AVR manufacturers this year...
Keeping my Denon 3311 until they get their act together and offer HDCP 2.2 on all inputs / outputs and HDMI 2.0a speed.
In regard to Onkyo I would be more concerned about why they dropped Audessey and down graded their amp rating to THX select from THX ultra
that points to a downgrade in sound IMO....no matter what "K" you are looking at
Warren
Rm 1 Samsung 65KS9800 Marantz 8802A prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Vizio P50 Denon X4300 Celestion 305 speaker system
Rm 3 Samsung 55KS8000 Yamaha A1060 Kef 2005.2 speaker system
Rm 4 Vizio P50 Pioneer SC95 Mirage Omni sat speaker system
turnne1 is offline
post #992 of 4965 Old 07-15-2014, 09:38 AM
Mike Garrett's Avatar
Quoted: 7057 Post(s)
Liked: 4762
Originally Posted by GetGray View Post
Or I will.
Don't talk like that. You are my age.
mjgarrett100@gmail.com
Mike Garrett is offline
post #993 of 4965 Old 07-15-2014, 09:39 AM
Pete's Avatar
Quoted: 239 Post(s)
Liked: 84
Warren
Never-ending saga: Storied brand gets bought by conglomerate; cost-cutting campaign soon ensues; product substance undergoes extraction in small incremental stages; product managers rationalize moves as necessary to remain "competitive" (and to keep their jobs).
Pete is offline
post #994 of 4965 Old 07-15-2014, 11:39 AM
AidenL's Avatar
Quoted: 542 Post(s)
Liked: 268
Warren
I believe its supposed to be due to a lack of processing power onboard.
Take Anthems ARC for example, it needs to be run on a laptop as its more processor intensive, seems the Onkyo couldn't handle Atmos and full-on Audyssey internally.
Display : JVC X7000 Projector | SE 103" Enlightor 4k | LG 65B6 OLED |
Sources : Panasonic UDP 700 & HD Fury Linker| Apple TV3 | HTPC | Sky Q UHD Satellite | Sonos Connect | Synology 24Tb |
Audio : Marantz 8802A | Genelec 8050 LCR | Monitor Audio IDC Sides & Rears | Seaton Submersive Master/Slave |
Control : Control 4 |
AidenL is offline
post #995 of 4965 Old 07-15-2014, 11:44 AM
stanger89's Avatar
Quoted: 3669 Post(s)
Liked: 2036
To be clear, Anthem's ARC "solution" is computed on a PC, but the actual ARC processing happens in the SSP.
stanger89 is online now
post #996 of 4965 Old 07-15-2014, 12:55 PM
Kris Deering's Avatar
Quoted: 2219 Post(s)
Liked: 3411
Exactly, this is also the way Audyssey Pro works as well. It comes down to speed of crunching the data which is FAR faster on a PC than it is in a processor.
My Home Theater
Kris Deering is offline
post #997 of 4965 Old 07-15-2014, 01:17 PM
AidenL's Avatar
Quoted: 542 Post(s)
Liked: 268
Yep, I agree with that, but not certain where I read this - it was said that the processing power of the Onkyo couldn't handle Audyssey and Atmos processing at the same time, it could only do one or the other?
That may be incorrect, but it was put forward as the reason Audyssey was dropped by Onkyo.
AidenL is offline
post #998 of 4965 Old 07-15-2014, 02:33 PM
Liked: 3411
It is unclear why Onkyo did or didn't do anything and without something officially from Onkyo I think most of what you hear on the forums is speculation. Ultimately I doubt Onkyo will respond in any official way and will probably state that their solution is every bit as good as what they had before. No manufacturer likes to shoot themselves in the foot by announcing their new stuff is a scaled down version of their old stuff.
My Home Theater
post #999 of 4965 Old 07-15-2014, 03:48 PM
David Susilo's Avatar
Quoted: 636 Post(s)
Liked: 592
The only thing for sure is that Onkyo's AccuEQ is developed by Dolby for Onkyo...based on Onkyo training in Canada.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #1000 of 4965 Old 07-15-2014, 08:50 PM
turnne1's Avatar
Liked: 489
but it is a downgrade.....going from THX ultra to THX select is a downgrade
though It seems that the number of matrixed channels is more important than sound quality is to many consumers
to be clear
The Anthem products are in a different "neighborhood" than any of the Asian manufacturers
Warren
turnne1 is offline
post #1001 of 4965 Old 07-15-2014, 09:16 PM
Liked: 3411
It is unclear what THX select even means in terms of a processor. For an AVR it has to do with the power output and room size. This could be an issue depending on load, but it also may not be. Even if it didn't have enough power for the application you could always increase that with an outboard amp.
post #1002 of 4965 Old 07-15-2014, 09:27 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
Better yet get speakers with a built in electronic cross over and amps designed for each driver. Do it right. The era of passive crossovers and huge big amps to feed each speaker's passive cross over is over. Do what the pros do. At most you need a good audio and video processor and even then you can get surprisingly good audio processing by using just the line level outs from a very cheap receiver.
mark haflich is offline
post #1003 of 4965 Old 07-15-2014, 09:41 PM
millerwill's Avatar
Quoted: 527 Post(s)
Liked: 316
Very good point, Mark. I have Mark Seaton Catalysts for L/C/R, and a Seaton SubMersiveHP sub, all of which have their own internal (and ample) amps. The only thing I need the for amps in the AVR (and elderly Onkyo 3008) is for 5 surrounds speakers, very light duty.
millerwill is offline
post #1004 of 4965 Old 07-16-2014, 07:16 AM
b curry's Avatar
Quoted: 473 Post(s)
Liked: 277
Shooting from the hip Mark?
I would guess the "era of passive crossovers and huge big amps to feed each speaker's passive cross over is over" is far from over.
Amplified speakers require an AC outlet at each position; that or a lot of extension cords lying around. With Dolby Atmos and the advent of increasing channel count/positions active speakers become even more difficult to install unless you're working with a clean sheet of paper.
I think it's safe to say that passive speakers and and big amplifiers are going to be around for a long time.
GetGray likes this.
b curry is offline
post #1005 of 4965 Old 07-16-2014, 07:52 AM
Dan Hitchman's Avatar
Quoted: 3559 Post(s)
Liked: 1903
I also dare say that the speaker probably won't last as long with a built-in amp either. If the amp goes dead... there goes your speaker... unless it has a passive input workaround. Hopefully, there are still spare parts available if it dies after your warranty period is over.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #1006 of 4965 Old 07-16-2014, 09:46 AM
Liked: 1012
I designed my theater for power at each speaker location and the coax feeds to each speakers have adapters so they can be converted from line level to speaker level. I took a lightening hit that several damaged two of the amps but they were fixed by an independent shop. Of course nonpowered speakers and passive x overs and big amps will live on. But the pros use self powered and line level feeds. Obviously top level execution is possible using these methods and they are the most popular. But if you are truly serious, active cross overs and amps designed to drive the specific driver are the way to go.
post #1007 of 4965 Old 07-16-2014, 05:35 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
You must have some fat coax Mark if it can convert to speaker level.
GetGray is offline
post #1008 of 4965 Old 07-16-2014, 06:26 PM
Liked: 4762
I use active speakers for my LCR's, but passive for my surrounds. Rather than the amp in each speaker, I have my amps in my rack.
post #1009 of 4965 Old 07-16-2014, 07:57 PM
Liked: 1012
The cable is just high quality quad shield. The adapters screw onto the standard coax termination. One set has an rca and the other two wire spades. the product was sold by Music Interface Technologies. Remember non of the speaker terminations for such things as sides or rears would carry much power. all the subs are line level for the most part. Come to think of it, I do have two folded sub transmission lines in ,y ceiling weighing in at about 300 lbs each and they do run off plate amps in my rack. These I think are hardwired with speaker wire.
post #1010 of 4965 Old 07-17-2014, 07:33 AM
b curry's Avatar
Quoted: 473 Post(s)
Liked: 277
I think the point GetGray was alluding to was the wire gauge.
Most coax is around 22 gauge, maybe 18 gauge at best. Probably not the best approach for speaker wire considering the length of wire runs in most hometheaters.
Not so much about power needed. More about impedance and damping factor.
b curry is offline
post #1011 of 4965 Old 07-17-2014, 09:05 AM
Liked: 1012
I know quite a bit here gentlemen. Trust me. I would not use this for a high quality 2 channel system. But its surround sound and certainly for line level its more than sufficient. Syrrounds are small in size and power requirements. When hardwiring a customers theater, i use a minimum of 14 x 4. but damping factor is really not an issue. The power draw for surrounds for the most part is minimal . And our concern is not with dc impedence . We are dealing with rather low voltage AC. The network design to make quad carry enough power at speaker level is not brain science. Your passive cross over speakers presents problems fior most home theater amplifiers. But they work and they sound great. Its hard to really screw things up because of spkr wiring. its really eact to not use good room design or no or little ascoustical treatment of the wrong treatment in the wrong spots.
post #1012 of 4965 Old 07-17-2014, 10:43 AM
Liked: 4762
They are talking about the cable being used as passive speaker wire, since you said it has spade ends.
post #1013 of 4965 Old 07-17-2014, 12:14 PM
Liked: 1012
Mike. That is intuitively obvious to me and I am far more than a casual observer. You are using a relatively small guage wire, Shall we discuss the AC impedance of the coax cable and its relatively high capacitance. Its needs a network box on each and to make it at all high level suitable, Its does not need to be low guage number particularly because it is not moving a lot iof air. It ain't used for subs but once again it does make a great line level sub cable. There the network boxes do little except provide the right connector.
post #1014 of 4965 Old 07-17-2014, 12:22 PM
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
Whatever
GetGray is offline
post #1015 of 4965 Old 07-17-2014, 01:03 PM
madshi's Avatar
Quoted: 609 Post(s)
Liked: 589
Why are we discussing passive vs. active speakers in this thread?
madshi is offline
post #1016 of 4965 Old 07-17-2014, 03:37 PM
jlanzy's Avatar
Quoted: 358 Post(s)
Liked: 106
Well, if discussion were limited to new updates on the BR4K, the thread would probably die, so those of us who come here to see what's new, and there is nothing, we just begin yaking about something more relevant while waiting, kinda like chit chat in church before the sermon begins.
Manni01 likes this.
jlanzy is online now
post #1017 of 4965 Old 07-17-2014, 05:08 PM - Thread Starter
Ron Jones's Avatar
Quoted: 920 Post(s)
Liked: 938
One recent 'event' that IS related to BD 4K/UHD is ITU-T Study Group 16 (SG16) just finished up a meeting last week in Sapporo, Japan where they were considering an extensive amendment to HEVC. The already approved h.265/HEVC standard (from early 2013) only has basic support for 4K/UHD and extensions to that standard are necessary to include such things as support for 60Hz refresh rates and 12-bit depth. It is widely believed the baseline codec for BD UHD is going to be HEVC and the updated HEVC version is necessary to satisfy the needs of BD UHD. Going into the recent SG16 meeting the goal was to reach an agreement on the proposed standard that incorporated the extensions to HEVC. If approval was reached then the updated h.265/HEVC standard will hopefully be approved and published by ITU-T within the next couple of months. Also I heard that Sony was pressing SG16 to get the updated HEVC finalized ASAP because they want to get the design for the new HEVC chips finalized so they can get them into production for planned products (hopefully including BD UHD players). The meeting report from the Sapporo SG16 has been posted on the ITU SG16 web site but only members can download a copy. Hopefully we will get word soon if the extensions for this update to the HEVC standard have been finalized, or if it's going to take another SG16 meeting to continue work on it. Based on past history it appears SG16 only meets 3 or 4 times a year so my guess is they would only fit one more meeting in during 2014.
Dan Hitchman and Manni01 like this.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #1018 of 4965 Old 07-17-2014, 05:23 PM
Liked: 1012
Very interesting. Thanks for the update.
post #1019 of 4965 Old 07-18-2014, 08:29 AM - Thread Starter
Ron Jones's Avatar
Quoted: 920 Post(s)
Liked: 938
Good News - HEVC update approved
The executive summary has been released from last week's meeting of ITU-T SG16. The extensions to HEVC have been approved ('consented' in ITU terminology). This removes one technical roadblock for getting the BD UHD spec. completed and allows the manufacturers to move forward with producing the HEVC related hardware/software that will used with BD UHD.
(full text of exec. summary is at: http://www.itu.int/en/ITU-T/studygro...ults-1406.aspx)
Below is extracted directly from that summary:
"Video coding: The 2nd edition of ITU-T H.265 HEVC was Consented It includes three important types of extensions of HEVC coding capabilities, that will increase the quality of compressed video and better user experience:
1. Format range extensions of HEVC, known as RExt, adding improved colour representations. RExt includes support for higher bit-depths and enhanced chroma formats, including the use of full-resolution chroma.
2. Scalable extensions of HEVC, known as SHVC, enabling better performance for dynamic video streaming on networks with varying transmission conditions and other scenarios involving multiple bit-rate services. SHVC adds support for embedded bitstream scalability in which different levels of encoding quality are efficiently supported by adding or removing layered subsets of encoded data.
3. Multiview extensions of HEVC, known as MV-HEVC, as the first native support for 3D video encoding in HEVC. It provides an efficient representation of video content with multiple camera views and optional depth map information, such as for 3D stereoscopic and autostereoscopic video applications.
Conformance testing of image and video coding standards: A pair of new specifications that are used for conformance testing of ITU-T H.265 HEVC video were consented at this meeting:
  • · ITU-T H.265.1 "Conformance specification for ITU-TH.265 high efficiency video coding" (New) [TD 286/Plen]
  • · ITU-T H.265.2 "Reference software for ITU-T H.265 high efficiency video coding" (New) [TD 287/Plen]"
___________________________________----
So among other things the 2nd edition of H.265/HEVC includes support for increased bit depths, up to 4:4:4 chroma, and 3D. The full set of extensions/enhancements will be documented in the actual standards document when it is published and will include such other enhancements as support for higher refresh rates at 4K/UHD resolution.
Manni01 and urskog like this.
Ron Jones
post #1020 of 4965 Old 07-18-2014, 09:06 AM
madshi's Avatar
Quoted: 609 Post(s)
Liked: 589
So far so good. I don't see any mention of HDR (peak white with higher light output), though, and from what I heard studios would like to have support for that, too. Well, maybe it's only needed for broadcasting, though, because none of the current movies are shot with HDR in mind, I think? I'm not sure...
madshi is offline
