Official Epson EH-TW 9200 5030UB Owners' Thread - Page 109 - AVS Forum | Home Theater Discussions And Reviews
 384Likes
Old 05-31-2014, 08:59 AM - Thread Starter
kbarnes701's Avatar
Quoted: 6796 Post(s)
Liked: 5189
This probably the wrong thread, but I'm not sure where else to go. I have the Epson 5030ub. The place that installed it for me I noticed didn't have the projector square to the screen. So the left side of the image was slightly larger than the right. I was able to move the projector so it would be square and then barely use lens shift to get it back in place. So now at least the image size is correct. However, my problem is that the projector is tilted a bit. The left side is slightly higher than the right. I can hold the projector and straighten it out and it lines up absolutely perfect with my screen!... this is great... however, as soon as I let go, it goes back to being slightly off with the left side being higher than the right.
So, here is what I know which is not much. They used some Chief mount. The problem is I know nothing about this mount and how it works. The model number of the mount is RPAUW with the CMS003W extension column and the CMS101w designer plate.
Anyone here know how I can tilt my projector? I'm a wuss and don't won't to screw anything up.
Doug
Sounds like you need to adjust the "roll" - just need a Philips screwdriver to adjust.
Page 7 of the manual - Manual is here: http://downloads.chiefmfg.com/MANUALS-I/RPA-I.pdf
Ahhh... maybe that is why I was having a difficult time. I wasn't doing the roll. I was adjusting the pitch. I guess I don't understand the difference between pitch and roll. I looked like to me in the manual if I wanted to raise the right side of the projector ever so slightly, that would be the pitch. It has those arrows on the right and left side of the projector on the pitch section. But maybe it is the roll I need in order to raise the right side just a bit.
Doug D.
Here's a neat diagram that shows the difference between pitch, roll and yaw, all of which need to be right for perfect picture geometry/alignment and all of which, to some extent, are dependent on each other. So adjusting one often means you need to go back and adjust another, rinsing and repeating until it all clicks into place.
kbarnes701 is offline
Old 05-31-2014, 09:14 AM
ay221's Avatar
ay221 is offline
Old 05-31-2014, 09:18 AM - Thread Starter
kbarnes701's Avatar
Liked: 5189
Old 06-01-2014, 01:58 PM
dougdude9's Avatar
Hey all,
So ok, I found that I need to select "fast" instead of "fine" if I'm playing a game. I haven't tried yet, but I have a game or 2 that is capable of 3D. So, with that said, will I not be able to play these games in their 3D glory because I will have way too much input lag? I did notice that the option to change to "fast" isn't an option when in 3D mode.
Curious if any of you have tried 3D games or what you may have to do to reduce input lag in 3D.
Doug D.
dougdude9 is offline
Old 06-01-2014, 07:30 PM
Stereodude's Avatar
Quoted: 3211 Post(s)
Liked: 2349
Originally Posted by kbarnes701 View Post
Good point. So can the bulb not be damaged by movement while it is lit?
Well hot glass might be more fragile, I'm not sure.
Stereodude is online now
Old 06-02-2014, 03:03 AM - Thread Starter
kbarnes701's Avatar
Liked: 5189
The reason I ask is that the usual advice is never to knock or move the PJ while the lamp is lit, filament or no filament, and I was wondering why.  Maybe it is the extreme temperature that the glass reaches that is the problem as you say.
Old 06-02-2014, 07:43 AM
Mike Garrett's Avatar
Quoted: 6382 Post(s)
Liked: 4125
Doug
As others said, the mount just needs to be adjusted. I usually specify the Chief RPA168 mount for this projector. It has the custom plate for the Epson and holds the projector more rigid than the RPAU. They cost the same, but when you switch to a different brand of projector, you would be required to buy a new custom plate.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 06-03-2014, 08:59 AM
dougdude9's Avatar
Hey all,
Doug D.
Anyone know what the input lag is while in 3D mode? I have search and searched and all I can find is the data for input lag when in 2D with it set to "FINE" and "FAST" Frame interpolation apparently adds some lag too. Anyway, still looking to find what the lag times are in 3D.
Doug D.
Old 06-04-2014, 05:42 PM
flyguyjake's Avatar
Quoted: 179 Post(s)
Liked: 70
Does anyone know when Epson will announce their new projectors? Successor to the 5030ub?
flyguyjake is offline
Old 06-04-2014, 08:59 PM
bkeeler10's Avatar
Quoted: 322 Post(s)
Liked: 192
They will probably debut at CEDIA (trade show) in September in Denver.
bkeeler10 is online now
Old 06-05-2014, 11:55 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3644 Post(s)
Liked: 3620
Yes, this is where and when we will see new projectors - September 11th - 14th.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
Old 06-05-2014, 11:57 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5679 Post(s)
Liked: 4667
Sweet! I hope they do.
I am going to CEDIA for my first time this year. I'm excited to finally go to a show that is ALL about home theater. smile.gif
Scott Simonian is online now
Old 06-05-2014, 12:31 PM
Liked: 4125
Scott, we have talked so much on the forum, it will be good to finally meet you. smile.gif
Old 06-05-2014, 01:54 PM
Bass Enabler
Liked: 4667
Not sure exactly which days I will be there. I think the registration for it opened this week. I'll let you know. smile.gif
Old 06-05-2014, 04:04 PM
gec5741's Avatar
Quoted: 202 Post(s)
Liked: 92
At the rate I'm going with my build the new models may be what I end up with. So I suppose the silver lining to me taking so long to get this done would be a better line of Projector! I guess I'm ok with that smile.gif
gec5741 is offline
Old 06-06-2014, 01:15 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3620
That and considering when the new models are actually available, you'll have yourself a nice Christmas ( or Chanukkah ) present !!smile.gif
Old 06-06-2014, 03:24 PM
WynsWrld98's Avatar
Quoted: 286 Post(s)
Liked: 111
Any rumors of what changes might be coming? Would love power zoom and focus and lens memory for switching between 16:9 and 2.35:1
WynsWrld98 is offline
Old 06-06-2014, 03:30 PM
Bass Enabler
Liked: 4667
Same here.
Probably have to wait til September before any meaty details come about.
Old 06-06-2014, 04:05 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3620
Same here.
You'll need to wait until the week of Cedia!
Old 06-06-2014, 04:19 PM
Bass Enabler
Liked: 4667
Old 06-07-2014, 06:31 AM
trolly's Avatar
Quoted: 62 Post(s)
Liked: 48
The side of my 5030 gets really hot during use.... is this normal?
trolly is offline
Old 06-07-2014, 06:44 AM
kriktsemaj99's Avatar
Quoted: 650 Post(s)
Liked: 371
Yes, one side draws in cool air and the other side vents hot air. As long as you're not restricting the airflow to the vents it sounds normal.
kriktsemaj99 is offline
Old 06-07-2014, 07:26 AM
trolly's Avatar
Quoted: 62 Post(s)
Liked: 48
Thank you. I felt the side of the demo 5030 at my local Best Buy that stays on throughout the day and it didn't seem to be as hot as my unit gets.
trolly is offline
Old 06-07-2014, 08:18 AM
zombie10k's Avatar
Quoted: 3232 Post(s)
Liked: 3324
I've seen several 5030's, they were all the same way, the area where the lamp door is gets very warm. same on the 5020 and older 5010 models. As long as there is proper airflow around it, it should be ok. It's a little alarming at first though.
zombie10k is online now
Old 06-07-2014, 09:14 AM
WestCDA's Avatar
Quoted: 66 Post(s)
Liked: 79
You don't have your location indicated. If you are above 1500m, you should have the high altitude setting enabled - it runs the fan faster to compensate for the thinner air.
WestCDA is offline
Old 06-07-2014, 09:58 AM
Sebastian1029's Avatar
Hello Everyone,
I posted this in the Epson 6030 thread but have not received a reply. I think this thread see more action. This is just a quick question about what HDMI cable to buy.
I am totally new to this aspect of home theater and this projector and screen combo will be my first set-up of this type. I am coming from a 60" Pioneer Kuro and moving to an Epson 6030UB projector with a 113" fixed Black Diamond screen. Where my future projector will be placed, I will need about a 30 foot HDMI cable and the one I was looking at was the Blue Jeans BJC Series 1. I emailed the company and they said it is there most reliable HDMI cable for longer runs. Now I was looking at some pictures of the ceiling mounted Epson 6030, and how the cables bend in for a clean and organized look and I am wondering if that Blue Jeans cable will be able to bend like that. The customer service guy did say that 23 AWG is a little stiff. I have no idea if it will work and don't want to spend money on something that won't work. I was also thinking about the Monoprice RedMere HDMI cable but then read about signal drop out issues.
Can someone please tell me what HDMI cable they are using?
Thank you for your help.
Paul
Sebastian1029 is offline
Old 06-07-2014, 10:04 AM
usualsuspects's Avatar
Quoted: 18 Post(s)
Liked: 30
I am using a monoprice 35 foot 22awg cable. No problems using this cable with 4 different Pj's in the last 8 years.
usualsuspects is offline
Old 06-07-2014, 10:44 AM
TL5
TL5's Avatar
Quoted: 60 Post(s)
Liked: 38
Monster cable makes these little swivel Hdmi adapters that work really well with the thicker cables.
TL5 is online now
Old 06-07-2014, 03:07 PM
Thanks guys, I appreciate your help. If 22 AWG is still flexible then the Blue Jeans 23.5 AWG cable should be fine. And if not, then I might just get a couple of those Monster Cable swivel adapters. (I didn't know that stuff even existed.) This is all still new to me and your knowledge is an asset. Thank you.
Old 06-07-2014, 05:42 PM
HoG_FATALFIRE's Avatar
Another new owner of this fine projector! I'm pumped to get home from my trip to get it all set up. Got a pretty good deal from ABT electronics. They were a pleasure to work with and had me in and out in no time. MASSIVE store with a lot of top of the line stuff to play with. Definitely recommended!
willymo likes this.
HoG_FATALFIRE is offline
Epson 5030ub 2d 3d 1080p 3lcd Projector
