Official Epson EH-TW 9200 5030UB Owners' Thread - Page 115 - AVS Forum | Home Theater Discussions And Reviews
 373Likes
post #3421 of 5999 Old 08-07-2014, 07:53 PM
Mike Garrett's Avatar
Quoted: 5617 Post(s)
Liked: 3600
Originally Posted by gec5741 View Post
OK thanks. I'll be shining it on the wall first before deciding on a screen so i guess when the time comes I'll be able to judge for myself. I wish my room was a bit deeper!
When you are ready for a screen or just want to talk screens for your projector, give us a call.
mjgarrett100@gmail.com
Mike Garrett is offline
post #3422 of 5999 Old 08-07-2014, 07:54 PM
Liked: 3600
Originally Posted by JewDaddy View Post
Hey guys. I've been wondering for some time now if my Epson 5030 projector would benefit from doing a panel alignment. I've attached a couple pics to get some opinions. Also, I've went back and read the steps posted on how to perform a panel alignment and it doesn't really make sense. Can someone explain exactly how that works? Thanks for the help.
If the grid looks sharp and white from your seated distance, I doubt that you will be able to improve anything.
post #3423 of 5999 Old 08-11-2014, 06:02 PM
lardo5150's Avatar
Needing some help here.
Have had my 5030 for a few months now. Says I have around 221 hours of lamp time.
Zero issues. No fan issues, just strumming right along.
I come in tonight, turn it on. Watching about 10 minutes worth of tv and I hear the fan on it kick into high gear. It has never done this.
Then the lens shuts, the fan goes even higher, and I get the power blue and temp lights blinking at the same time.
It does this till it shuts down.
If I turn it on, it is rinse and repeat.
Any idea what is happening here? Anyway to access a console or something to see what is freaking out?
This thing does NOT feel hot either.
lardo5150 is offline
post #3424 of 5999 Old 08-11-2014, 06:57 PM
climber07's Avatar
Quoted: 334 Post(s)
Liked: 1339
Sounds like a faulty temperature sensor or processor board. I'd get an RMA right away and get it in for troubleshooting.
The only thing I see in the manual for two lights is:
the flashing blue power light and the orange lamp light, which means the bulb is bad, or the status light flashing blue and orange temp light. Which means overheating.
I don't see anything in the manual or forums for the power and temp light flashing.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #3425 of 5999 Old 08-12-2014, 09:51 PM
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
How large of a battery backup supply do i need for this projector? I cant find how many watts it is on the web site. I dont want to go too big but don't want to under cut either.
metalguy is offline
post #3426 of 5999 Old 08-12-2014, 10:37 PM
climber07's Avatar
Quoted: 334 Post(s)
Liked: 1339
350W (nominal - from the manual). A 650VA UPS will suffice.
post #3427 of 5999 Old 08-13-2014, 08:18 PM
chiltonj's Avatar
Quoted: 52 Post(s)
Liked: 42
Originally Posted by Craig Peer View Post
A better screen can give you a better picture. I really like my Stewart Cima Neve - send me an email with your mailing address and I'll have a sample sent to you.
Received the samples, much appreciated for the quick shipping. Both samples do not show the texture like my current screen. I'm leaning towards the neve. It's a light controlled theater, no outside light whatsoever. Do you know if I can get the screen at 120" to fit in my current elite screen frame?
chiltonj is offline
post #3428 of 5999 Old 08-14-2014, 12:06 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3088 Post(s)
Liked: 3019
I doubt it - the easiest solution would be to sell your old screen and replace it with a new one.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #3429 of 5999 Old 08-14-2014, 04:27 PM
McGuireV10's Avatar
Anybody have an RTI Integration Designer -compatible file of the IR codes for this?
Trying to avoid bugging my buddy to capture the codes for me... didn't see anything for Epson that has 3D (that I know of) listed on Remote Central's database.
http://www.remotecentral.com/cgi-bin/codes/epson/
Edit: A friend sent me an Epson ProCinema 6010 file which seems to have all the same codes -- attached in case somebody else needs it.
Last edited by McGuireV10; 08-15-2014 at 01:08 PM. Reason: Attached RTI .cml IR file
McGuireV10 is offline
post #3430 of 5999 Old 08-14-2014, 06:39 PM
lardo5150's Avatar
Yep, got an RMA, VERY easy process, surprisingly. New one is already up
post #3431 of 5999 Old 08-15-2014, 11:09 AM
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
How do you enable fast mode or even fine mode. I cant find it in the manual anywhere. and want to visually see the difference. Thank in advance.
metalguy is offline
post #3432 of 5999 Old 08-15-2014, 11:14 AM
McGuireV10's Avatar
Signal -> Advanced -> Image Processing
metalguy likes this.
post #3433 of 5999 Old 08-15-2014, 12:54 PM
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
thank you very much
metalguy is offline
post #3434 of 5999 Old 08-17-2014, 09:25 PM
kronik's Avatar
HDMI Not Supported
Looks like whenever I try to play 3D Blu-ray content via an Oppo BDP-93 (via Integra DHC-80.3 to 5030UB), I get not supported errors. It appears to be only with 3D content specifically because it shows the first selection screen for language and subsequent Marvel intro video before the error begins. At that point, the screen just continually flashes on and off as if it can't handshake. Ideas?
kronik is offline
post #3435 of 5999 Old 08-17-2014, 11:25 PM
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
How big can I really go? I have the room to go as big as I want, but to stay bright enough, I am looking at a 150 16:9 screen or a 166 2.35.1 and will just do side masking for 16:9 tv and movies . Is that to big for most projectors including this one, either one of the sizes I listed, or even a 176 2.35.1? I also enjoy 3d quite a bit too thought its not the majority of what i watch. I look forward to the replys, how big are some of you going with your 5030? I know they say they are light canons but are they really that bright?
metalguy is offline
post #3436 of 5999 Old 08-18-2014, 05:05 AM
pacemaker's Avatar
Quoted: 30 Post(s)
Sorry if theses questions gave been asked before but need quick answers to following
Why is this PJ so overpriced in the UK? Should be around £1800 when compared to $ prices?
Upgrading from a TW3600 which had to be swapped out a number of times due to bad convergence. Does the digital adjustment eliminate the problem?
Considering this alongside the new Sony HW40es which has lcos panel alignment plus costs a lot less in UK.
pacemaker is offline
post #3437 of 5999 Old 08-18-2014, 06:22 AM
McGuireV10's Avatar
I'm throwing to a 150" 16:9 screen with a throw distance of about 17 feet. That is supposedly on the high end of what is optimal according to the Projector Central calculator, but we think the picture is simply amazing.
We bump it up to Dynamic (full brightness) in the early evening before it's even dark outside and it looks almost as good as the 50" LCD below the PJ screen -- and this is in a room with 8 big windows in a 22' wall. At night we switch it down to THX mode and it still lights up the room and it really does look like a regular TV. The black levels are simply amazing.
My HomeCinema 400 that it replaced was called a light cannon in its day, but even on day-one of a brand new bulb the 400 doesn't begin to compare to the 5030UB.
I can at least say that for 150" screen at 17' or less, you will probably be quite pleased.
post #3438 of 5999 Old 08-18-2014, 10:33 AM
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
Thank you sir.
metalguy is offline
post #3439 of 5999 Old 08-18-2014, 10:33 AM
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
Anybody else?
metalguy is offline
post #3440 of 5999 Old 08-18-2014, 12:26 PM
willymo's Avatar
Quoted: 21 Post(s)
Liked: 42
I'm doing 100 inches from a throw of just under 11 feet and a seating distance about 9 feet from the screen. It looks incredible in my small HT. I could go up to about 106 inches with no problem in the future. Just saw Noah the other night and it looked amazing! Lots of black level torture tests in that one and the projector passed with flying colors... I say, go as big as you can take, without getting a screen door effect.
willymo is offline
post #3441 of 5999 Old 08-18-2014, 01:20 PM
Liked: 3600
The answer is no. Stewart will only sell fabric to an owner with a current Stewart frame. You have to provide the serial number of the frame. As advised, you would have to sell your current screen. The smoothness of the fabric does make a difference. The smoother the screen, the sharper the image.
post #3442 of 5999 Old 08-18-2014, 01:24 PM
Liked: 3600
Depends on the gain of the screen, as to how big you can go. How are you planning on changing aspect ratios if you go to a 2.35 screen? The Epson does not have lens memory
post #3443 of 5999 Old 08-18-2014, 02:29 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5346 Post(s)
Liked: 4244
Lol, seriously?
Does Stewart buy it back or do they just want to spy on your Craigslist?
McGuireV10 likes this.
Scott Simonian is offline
post #3444 of 5999 Old 08-19-2014, 06:12 AM
McGuireV10's Avatar
I get "HDMI / Not Supported" errors from the PJ at the slightest provocation. We had lightning in the area -- so far away that I could see faint flickers through the window, but couldn't hear the thunder -- and each flicker of lightning was enough to reset the picture, and sometimes we'd lose it entirely with "Not Supported"...
I suspect this thing is highly sensitive to cable quality.
post #3445 of 5999 Old 08-19-2014, 06:20 AM
Liked: 3600
Lol, seriously?
You must have missed something. Customer was asking about putting Stewart fabric into an Elite Screen frame. Stewart will not sell just fabric alone, unless you can provide a serial number for the frame you want to install new fabric into. Stewart has on file (by serial number) all of the screens sold. They pull the original packet to make sure the replacement fabric fits the original screen.
Now if you want to go on Craig's list and buy a Stewart frame, then yes you would be able to buy replacement fabric for that Stewart frame. You could do what you want with the fabric, but by the time you bought a used Stewart frame and new replacement fabric, you might as well buy a Stewart screen, since you would most likely have the same money in it.
post #3446 of 5999 Old 08-19-2014, 08:38 AM
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
What brand screen are you using and what gain does it have?
metalguy is offline
post #3447 of 5999 Old 08-19-2014, 08:40 AM
metalguy's Avatar
Quoted: 127 Post(s)
Liked: 41
What brand screen are you using, and what gain? Also since this is an lcd projector, are you not going to get SDE no matter what?
metalguy is offline
post #3448 of 5999 Old 08-19-2014, 08:45 AM
McGuireV10's Avatar
Elite's R150H1, fixed-frame, 1.0 gain CineGray material... found it somewhere for about $700 delivered, back when $950 was the going price. Was pretty happy with that. Looks great, and install was surprisingly easy despite the size of the thing (74 x 131 or thereabouts).
post #3449 of 5999 Old 08-19-2014, 08:48 AM
McGuireV10's Avatar
The 5030 is my third 3LCD projector since 2005 and I've never seen SDE, nor has anyone at my house ever complained of it or even mentioned seeing anything "weird" -- I think it's mostly a matter of correct seating distance.
A lot of people I know with projectors are throwing waaaay too huge a screen for their seating position. (Mine, 150" at about 17', is fairly optimal, there are online calculators for seating distance and screen height above the floor, I think Proj Central has one.)
post #3450 of 5999 Old 08-19-2014, 09:51 AM
Bass Enabler
Liked: 4244
Yeah I read that wrong, it seems. It had sounded like you had to sell the original material (since one would keep the frame) in order to get the newer material for the same Stewart frame.
Epson 5030ub 2d 3d 1080p 3lcd Projector
