Official Epson EH-TW 9200 5030UB Owners' Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 385Likes
post #361 of 6082 Old 10-15-2013, 05:24 AM
chooze's Avatar
Originally Posted by WilliamG View Post
Jeez, looks like one of those blue laser pointers.
Yeah, the pictures do make it look that way don't they. Luckily it's not that bad. I used a long exposer (2.5 s) to try to capture both the stuck pixels and the surrounding black pixels to give a sense of scale. This resulted in the dot being overexposed and "bleeding" into the surrounding area. In reality it is just two pixels one directly on top of the other.
chooze is offline
post #362 of 6082 Old 10-15-2013, 06:30 AM
FilmReverie's Avatar
Quoted: 14 Post(s)
Liked: 74
Two dead pixels on a brand new projector that cost thousands of dollars being described as "not that bad". eek.gif I do hope they have a zero dead pixel guarantee.
FilmReverie is offline
post #363 of 6082 Old 10-15-2013, 06:32 AM
odedia's Avatar
Liked: 25
I intend to purchase this projector and need some advice on screen size.
I will need to purchase a tab-tensioned electric screen since this is going into the living room.
I am siting 4 meters (13 feet)away from the projection wall.
I am deliberating between a 120 inch and a 133 inch screen. Does anyone has similar setup and can share his experiences? I like a big picture but I worry 133 inch might become too much for me to handle and would actually become uncomfortable viewing. For 2.35:1 content I think 133" will be ideal but for 16:9 content it might be an overkill.
Also, my projector will be sitting 6 meters (about 19 feet) from the wall, on top of a closet behind me and a bit to the right, I tried calculating using epson's 5020 tool and it seems to be alright, close to the limit of the 120 screen and more comftable angle for a 133 inch screen. Do you believe that in terms of light output this setup would be alright for 2d and 3d? most content will be in a dark room, occasionally for sports and the likes there will be some lights on.
Any input on screen gain? I was thinking about a standard matt white 1.0 or 1.1 gain screen.
odedia is offline
post #364 of 6082 Old 10-15-2013, 06:42 AM
Quoted: 14 Post(s)
Liked: 74
From a four meter viewing distance thx recommends around a 120" screen. Whether that suites you is another matter, some like going a little bigger some a little smaller (and some a lot bigger). Personally I would go a little bigger then what thx would recommend, but that is just me.
I can't imagine brightness will be an issue for 2d though at a guess I would say a higher gain screen may be needed once you go above 130" for bright 3d images (especially as the bulb dims). Hopefully someone like zombie will be able to provide you with some more help on such matters.
post #365 of 6082 Old 10-15-2013, 06:55 AM
varkeast's Avatar
Three choices:
1. Sell the complete mount that you have and buy a Chief RPA168.
2. Buy the SLB168 plate to go on your mount.
3. Sell your mount and buy the Chief RPAU.
Not a big fan of the 3rd choice. The RPAU does not gold the projector in place as well as the custom 168 mount. If you would like projector and mount pricing, give us a call.
Thanks for the quick and detailed response Mike! I will probably be giving you a call in a few days
Originally Posted by kbarnes701 View Post
This Peerless mount is the best I have ever seen. It has micro-precision adjusters so you can dial in tiny movements of the PJ, making setting up very easy.
http://www.amazon.com/Peerless-PRGUNV-Precision-Universal-Projector/dp/B000TXNS6G
Thats a good option, considering the quick search i did for the SLB168 appears that just the metal bracket to attach the PJ to the mount is over $100... that seems pretty ludicrous for a basic piece of metal w/ some screw holes, specially when a whole mount can be purchased for less.
I have $5 that says if you're even a reasonably hardcore gamer the Epson is NOT the projector for you. I'll paypal zombie $5 if I'm wrong. I'm guessing >60ms input lag. Maybe even as high as 80ms.
I am just hoping for somewhere near 50ms or better
varkeast is offline
post #366 of 6082 Old 10-15-2013, 07:15 AM
chooze's Avatar
I just got off the phone with Epson. They will be sending me a new projector overnight. The rep was courteous and efficient in processing the swap. So far I couldn't ask for better customer service.
chooze is offline
post #367 of 6082 Old 10-15-2013, 07:17 AM
chooze's Avatar
Hi FilmReverie,
I think I may have worded my post poorly. What I wanted to convey is that the photographs make it look worse than it actually is. I agree it should not have any dead pixels.
chooze is offline
post #368 of 6082 Old 10-15-2013, 07:35 AM
FATHERFORD's Avatar
Question:
Can you only use the Picture and Picture mode with wireless hd?
On the 5020 I read you can't use both HDMI ports and have picture and picture.
Can you hook up one HDMI and another component?
FATHERFORD is offline
post #369 of 6082 Old 10-15-2013, 08:02 AM
garrettmoore's Avatar
Can anyone post a picture showing the bottom of the projector (or top, if you have it upside down for ceiling mounting)?
I'm trying to figure out if I can use my current projector mount, a Vogels EPC 4010. It has 4 positionable arms and seems like it ought to work fine but I wanted to check.
garrettmoore is offline
post #370 of 6082 Old 10-15-2013, 08:08 AM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 41
Originally Posted by john2910 View Post
Oooo Nooooo so if i use my dune hd base 3d to stream my 3d movies the frame interpolation wont work:eek:??
I hope this is not true??
Please let me know ........
john2910 is offline
post #371 of 6082 Old 10-15-2013, 08:59 AM
zombie10k's Avatar
Quoted: 3700 Post(s)
Liked: 3831
Is it sbs or full stream? It works fine with full stream using my mede8tor 1000.
I havent tested sbs, I prefer either full 3D BD or I'd sooner watch in 2D. Its too soft on my size screen.
zombie10k is online now
post #372 of 6082 Old 10-15-2013, 12:06 PM
SWvdM's Avatar
The 5030UB is now also in stock at B&H.
SWvdM is offline
post #373 of 6082 Old 10-15-2013, 01:42 PM
Quoted: 14 Post(s)
Liked: 74
Hi FilmReverie,
It is all good, I hope you can get if replaced/fixed in quickly. smile.gif
post #374 of 6082 Old 10-15-2013, 02:53 PM
briandaniella's Avatar
How does the Epson 5030ub compare to the PT-AE8000U?
briandaniella is offline
post #375 of 6082 Old 10-15-2013, 03:23 PM
mumbleypeg's Avatar
Quoted: 26 Post(s)
Originally Posted by JewDaddy View Post
Just tried out the 2D to 3D conversion and it's not the best implementation I've seen, but also not the worst. I never tried it on my 5020 so not sure whether it's an improvement or not. Probably not something I would ever use though.
The frame interpolation makes such a huge difference for me in 3D. Because of how smooth the motion is and also making it easier on the eyes, I feel like it does add to the sense of depth somewhat. The brightness is outstanding just like the 5020 was but not much of a difference, if at all. I feel like the crosstalk and ghosting is non existent on this model, which allows me to keep the glasses brightness setting on high without any negative side effects. Again, best 3D I've seen in a home theater yet.
I have the 5020 prob a silly question , but i dont recall any adjustments for the glasses. Could you post a link please?
mumbleypeg is offline
post #376 of 6082 Old 10-15-2013, 03:52 PM
JewDaddy's Avatar
Quoted: 199 Post(s)
Liked: 98
Lol. No prob. Just do this. Press Menu on the remote, go to the Signal Tab. Choose 3D setup and then and then within the 3D menu is an option call 3D Brightness. Give it a shot.
mumbleypeg likes this.
JewDaddy is offline
post #377 of 6082 Old 10-15-2013, 03:54 PM
JewDaddy's Avatar
Quoted: 199 Post(s)
Liked: 98
I currently own the 5030 and previously owned a PT-8000 for about a month and I love the Epson. The Panasonic was no slouch but the 3D experience and black levels are much better on the Epson. Gaming seemed to be a little faster on the Panasonic but that was about the only thing I preferred more on the Panasonic. Everything about the Epson is as good or better than the Panasonic IMO.
JewDaddy is offline
post #378 of 6082 Old 10-15-2013, 04:17 PM
aBuLhAgaG's Avatar
I demo'd the PT-AE8000U but ended up buying a 5030UB based on the preliminary reviews from CEDIA. Whilst the Panny is a great piece of kit, the Epson 3D implementation/performance appears substantially better to my eyes. I earlier reported an issue with white field uniformity, however after using the projector for a number of hours 100% IRE is now much more consistent, go figure! I guess it was just a case of running in the new lamp a little. I watched The Hobbit in 3D last night and was absolutely blown away by the image quality, the bundled glasses also provided a better image than the Panny ones that came with my TV presumably due to the brightness of the image and the shutters being a little darker. The only trade off is that in 3D mode the Epson is a lot noisier (32db) than the Panny which remains virtually silent...
aBuLhAgaG is offline
post #379 of 6082 Old 10-15-2013, 05:46 PM
Alad's Avatar
Greetings all! Excited to soon be upgrading. Have the 8500ub and my 5030ub pre-ordered. Expecting to be wowed!!
I have a couple of questions.
1. I ordered one extra pair of Epson brand glasses, but need a few more. Are there any glasses besides the stock Epson that would work or even be better?
2. Along those lines: I already received said extra pair of glasses (cruel since without my 3D projector, I have to wear them around the house and just look at the boring 3d world of reality and not my beautiful artificial Hollywood-created one!). So when I opened them up, I realized that one can’t simply charge them with what is supplied. You have to have an adapter to plug the charging (USB) cable into. Should I assume that the projector comes with that? Can you plug in multiple glasses at once with said assumed included adaptor? Could I use one of the thousands of Apple charging adapters that I have lying around?
3. So I had my 8500ub ceiling mounted and it was pretty high up, about 6” above the top of the screen. Lens-shift took care of getting the picture onto the 106” fixed screen without any keystone correction. My ceiling mount came with various lengths so I could lower the projector. Would there be a noticeable improvement in picture quality if I then was able to use less lens shift? Would that difference be worth the possible increase in audible noise perception since the projector is right above my seat on the couch?
Thanks in advance for any info.
Alad is offline
post #380 of 6082 Old 10-15-2013, 05:50 PM
presenter's Avatar
Quoted: 13 Post(s)
Liked: 32
Greetings, some good news. Naturally everyone's waiting for the first formal reviews and for the first end users to comment on their new 5030UB / TW9200 projectors. While I don't really believe it until a review projector arrives, latest word from Epson is it looks like something's going to be arriving here at projectorreviews.com end of this week or early next.
I honestly don't know if it will be the 5030UB, or a 4030, or one of the three high bright projectors - that are targeting family rooms and living rooms not home theaters, but, from "best guesses", I put the chances of the first Epson to arrive being the 5030UB.
I'm waiting patiently. I also have a calibrated 5020UB here (with 1100 hours on the lamp), for direct comparison, when the 5030UB arrives. As soon as the Epson arrives, Mike will calibrate it as well. Whatever arrives, that review should publish by next weekend. With a little luck it will be the 5030UB. I'll probably get to hang on to the Epson for a few weeks, so I hope that it will still be here when the Sony HW55 arrives. -art
Art Feierman
"Reviewing projectors is fun, but watching the 5th Element for the 500th time..."
Which means I'm really looking forward to Valerian: City of 1000 Planets
www.projectorreviews.com
presenter is offline
post #381 of 6082 Old 10-15-2013, 06:38 PM
rprice54's Avatar
Quoted: 94 Post(s)
Liked: 45
Art- thanks for the reply. I've been waiting for you to review this bad boy- although when I found out they were back ordered for a few weeks I went ahead and grabbed a spot in line.
Re:charging glasses- I used an iPhone wall charger to charge my first pair (I too have glasses and no projector). After reading around I ordered a powered USB hub since I will have 6 pairs of glasses eventually.
rprice54 is offline
post #382 of 6082 Old 10-15-2013, 06:48 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Alad, I've read the Samsung 5100 glasses worked great with the 5020 so the same should apply.
gpmbc is offline
post #383 of 6082 Old 10-15-2013, 08:23 PM
TechBuf's Avatar
Originally Posted by TechBuf View Post
Hi, I am completely new to the world of projectors and screen displays. I got my new 5030 UB last week and was able to mount it on the ceiling in my basement over the weekend. I watched Iron Man3 (2D) yesterday and was impressed with the performance. I am just wondering if my projector is located at the right spot on the ceiling. It currently stays at 21' from a 110" diagonal Elite Sable Fixed frame screen. Is the projector too far away from the screen? It was my mistake to have installed the ceiling mount at a predetermined location before the projector arrived.
Also, are there any tests that I should perform to make sure the 5030UB unit is fine? I am just nervous that I have a relatively new model that has just become available in the market. Any advice is appreciated. Thanks!
Hi Everyone, would somebody be able to help with my questions, especially the distance between the projector and the screen being 21' ?
TechBuf is offline
post #384 of 6082 Old 10-15-2013, 09:07 PM
TimmyJo's Avatar
I have this projector, and LOVE it. It's in my living room, shooting at a cheap 80" electric (white) screen. The screen is not tensioned, so it curls on both sides. I'm thinking of replacing the screen material with some "Carl's Pro Gray". It's supposed to be more rigid and help offset any ambient light. Anybody have any input on this?
TimmyJo is offline
post #385 of 6082 Old 10-16-2013, 12:24 AM
Justin Morgan's Avatar
Once I can verify there's no issues, I'll have it calibrated by Chad B smile.gif
Generally IIRC from what I've read it's best to wait until you have about 100 hours on the bulb before calibrating. That's because new projector bulbs are often super bright for the break in period, then stabilize and slowly dim over time. Basically if you calibrate right away you may need to re-calibrate 100 hours later.
Justin Morgan is offline
post #386 of 6082 Old 10-16-2013, 01:55 AM
beasttopray's Avatar
Hey TechBuf! Some other people might be able to give you a better explained answer to your question but I will TRY to answer it for you. From my understanding it is best to have your zoom knob somewhere around the middle or close to it, And have the projector as far back as necessary to get you to project the screen of your size without zooming all the way in. This is just an estimation on my part. So id recommend asking someone with better knowledge if you want completely accurate settings. But im estimating somewhere between 12 feet to 17 feet.  21 feet is a bit too much I THINK for a 110 inch screen. No point going too far back from my knowledge, unlessyou plan on going bigger then 110 inches as you will lose light. And if you have light coming in your screen will get washed out. But id say around 14 feet would probably be ideal. (Im estimating) I just noticed your post and thought id TRY to answer it for you. Everyone will have different opinions I think. But try asking some of the professional people on here. They will be able to help you a bit more accurately. Im not a pro installer or anything. Im just going by my experience that I had with the 5020. I hope this helps a bit
Try using this link. Itll give you a bit of an idea. Its not accurate but itll give you an estimation of where to place the projector for your desired screen size.
http://www.epson.com/alf_upload/landing/distance-calculator/
beasttopray is offline
post #387 of 6082 Old 10-16-2013, 02:00 AM
Barsk's Avatar
Quoted: 36 Post(s)
Hi,
I am from Europe and we have not had our versions of the new Epsons out yet. They will start to ship late october/Early November.
The equivalent to the US 5030UB is the EH-TW9200 as far as I can tell. Both versions appear identical in hardware. Some differences i sofware, e.g missing THX modes.
There are three improvements of interest that has been mentioned on both of these versions and these are:
1) Better 3D with FI. This has been confirmed here.
2) Better/newer lens. There should now be Fujinon lens on the new version. Has anyone seen any difference according to this. Is the lens really updated or is it the same as last years? Has the image become crisper, less CA etc?
3) Better contrast. Is this due to better LCD panels, i.e actual native contrast improvements? Or is it just the iris darkening further than last year?
Barsk is offline
post #388 of 6082 Old 10-16-2013, 02:33 AM
KUV1977's Avatar
Cine4Home writes that the contrast is indeed improved before adaptive Iris-Usage.
http://www.cine4home.de/
KUV1977 is offline
post #389 of 6082 Old 10-16-2013, 06:07 AM
mumbleypeg's Avatar
Quoted: 26 Post(s)
I have my 5020 14' back projecting a 130" image on a 180" screen. I use custom adjustable black felt masking all around. I sit 15' back from the screen. On flat white lettering I can sometimes see the pixels, but otherwise the image looks great!
post #390 of 6082 Old 10-16-2013, 06:14 AM
Knd
Knd's Avatar
Quoted: 111 Post(s)
Liked: 31
I own a 5010 and calibrate it using Stereomandan's guide here: http://www.avsforum.com/t/1134710/epson-calibration-guide-1080-1080ub-6100-6500ub-7500ub
I did a calibration at 0 hours, 100, 200, 300 and 500 hours, and what I found was that up until 300 hours it held very steady, but the 500 hour cal had significant changes, primarily in the black level, white level, gray scale and gamma. Colors moved a little but nothing like the others.
Knd is offline
Epson 5030ub 2d 3d 1080p 3lcd Projector
