Official Epson EH-TW 9200 5030UB Owners' Thread - Page 159 - AVS | Home Theater Discussions And Reviews
post #4741 of 4754 Old 02-22-2015, 06:45 PM
old corps's Avatar
Quoted: 90 Post(s)
Liked: 55
Originally Posted by ejfriis View Post
A few days ago I received an email "Epson Rebate Submission" with nothing in the body of the message. I tried to reply but now I'm getting an automatically generated failure Delivery Status Notification. They also signed me up for Epson Store emails.
Did you guys get a blank email like that? What number are you calling to check on the rebate status? I just want to make sure they didn't try (and fail) to contact me because some paperwork or something wasn't in order.
The Epson Rebate Response Line # is 1-800-277-6187. The # is on the bottom of the rebate form. Probably have to wait 'til tomorrow to call.
That's the number I called to check on mine. Got my lamp a couple weeks ago.
Good luck!
Ed
old corps is offline
post #4742 of 4754 Old 02-23-2015, 01:40 PM
Liked: 2
Cool
Hi all
I have just joined the forum , I am a happy New owner of a 9200 which is
Hooked up to a darbee 5000 and resides I my total bat cave of a cinema room..converted garage.
seems the 9200 is more popular in the states..I'm from the UK
I am hugely impressed with mine the 2d is superb and the 3d is phenomenal I've gone a bit 3d crazy and my 7 year old son loves it to
I have a homemade acoustic screen 102 inches in 16.9 , with home built masking for 2.35.1 viewing
Hope to learn any tips and give the benefit of my limited experience
old corps and musicalfox like this.
AncientYouth is offline
post #4743 of 4754 Old 02-24-2015, 08:19 AM
farscape105's Avatar
Hi, I am newbie to projectors and have question for experts. Just bought a 5030ub and going to buy a Seymour retractable screen with XD material. I will have the Epson mounted 17 feet on a back shelf and viewing distance be about 14 feet. A 120" diagonal 16:9 is largest screen I can fit and will roll down in front of my 70"tv in corner. My question is would it make much difference in brightness to get a 114" screen and move it 7 inches closer which would make the viewing angle same as 120". But it is slightly small screen and would be a bit closer which might make picture brighter? The projectorcentral calculator showed it would be 2 foot lamberts brighter. It sounds like Epson is a light cannon and probably not big difference? I just worry because Epson will be mounted little over half of telephoto range and I worry it will not be bright enough. It is not a dedicated theater room but I can control light. I wish I could mount Epson closer on ceiling but have to deal with WAF. Thanks! After seeing picture on a mocked up melamine board I can't believe I havn't got into the world of projectors before now! So freakin excited. On a side note, I also just bought a Sierra 2/170se system and a HSU Vtf-15H Mk 2 so you can tell I am a happy camper. I now have a bunch of Athena AS-F2's/AS-B1's for sale if anyone in Iowa/Mn is interested.
farscape105 is offline
post #4744 of 4754 Old 02-24-2015, 08:59 AM
climber07's Avatar
Quoted: 156 Post(s)
Liked: 1061
You are only a foot away from ideal with a 120" screen. I don't think inches will make a noticeable difference anyway. The Epson is very bright and I think you will be pleasantly surprised. I have a 106" gray screen with .85 gain at 14 feet and I use eco mode. The living room setting is very bright and the THX and cinema modes are good for light controlled viewing.
old corps likes this.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #4745 of 4754 Old 02-24-2015, 09:32 AM
AlexanderDelarg's Avatar
Quoted: 60 Post(s)
Liked: 90
I would go with the 120" personally. Mine is ceiling mounted at 17 feet and I have a 118" screen and it works great. I sit about 15 feet from the screen. Good times!
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is offline
post #4746 of 4754 Old 02-26-2015, 01:15 PM
lapino's Avatar
Quoted: 28 Post(s)
Any soluion yet to the projector being very noisy in 3d when ceiling mounted? Really annouing me.
lapino is offline
post #4747 of 4754 Old 02-26-2015, 01:57 PM
nando820's Avatar
Hi to all 5030 owners here, would you recommend a Darbee or is the "Super Resolution" I believe its called good enough?
nando820 is offline
post #4748 of 4754 Old 02-26-2015, 02:11 PM
willieconway's Avatar
Quoted: 44 Post(s)
Liked: 51
You're going to get conflicting responses as tastes and setups vary. Here's my opinion:
I don't like Super Resolution and don't use it at all. For me the effect is very non film like and adds too much of a processed look. Instead I use the Darbee processing in my Oppo 103D - but only when the content is fairly clean. I like movies with grain but I don't like to use Darbee on them. On clean content I find the Darbee effect to be great, partly because it's rather subtle. Also, my eyes are about 8' from a 100" screen. I'm guessing I might be more inclined to use SR if I had a bigger screen.
musicalfox likes this.
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Denon AVR 1713, Energy V-5.1s and a V-5.2C , NHT SuperZeros, Mirage Omni S10, Oppo 103D. Currently boxed up and for sale: Klipsch SW-450, NHT Absolute Center, Energy V-Mini-C
willieconway is offline
post #4749 of 4754 Old 02-26-2015, 02:48 PM
gec5741's Avatar
Quoted: 119 Post(s)
Liked: 70
I don't have a darbee and never have so I can't speak for the differences really. However I do like what they did with the super res personally. It all depends on the movie though like the above thread states. Typically I tend to use sr 2 or 3 on movies unless they have a lot of grain. Sports I crank the SR and FI up and it looks great. I have a 135 inch 16:9 screen in my setup. I was planning to get a darbee before ever having my pj but I think I'm personally going to not worry about it for now at least. I'm way happy with how my picture looks just using the built in SR!
gec5741 is offline
post #4750 of 4754 Old 02-26-2015, 04:37 PM
jaydee77ca's Avatar
I use SR on 3 for most content and I think it looks great. Some movies look good with 4. But generally I find 4 and 5 too grainy. I don't have a darbee so can't comment on that.
jaydee77ca is online now
post #4751 of 4754 Old 02-26-2015, 06:09 PM
musicalfox's Avatar
Quoted: 14 Post(s)
Again, only my personal preferences: on recent big budget movies and animation, I find SR 2 or 3 and Darbee 30 - 40% works pretty well, but for older grainier material (B&W films and color films from 50s and 60s), I tend to turn off SR, but sometimes keep Darbee at 30% or even off completely. I find there's a bit of trial and error involved with each title, particularly if you're setting up for a movie night.
musicalfox is online now
post #4752 of 4754 Old Yesterday, 06:18 AM
Quoted: 60 Post(s)
Liked: 90
I use Super Res at 3 and love it.
post #4753 of 4754 Old Yesterday, 06:34 PM
old corps's Avatar
Quoted: 90 Post(s)
Liked: 55
+1!
Same here, sometimes 4 when watching bluray. I tried a Darbee and FOR ME the tiny bit of improvement that I had to work at to notice wasn't worth the $$$ or hassle. Back it went.
JMHO
Ed
post #4754 of 4754 Old Today, 01:40 AM
home theater's Avatar
I have been so pleased with the Epson 5030ube sample I received that I thought I would share my settings so others might also get further enjoyment from their projector as well. I might add that although I received an excellent 5030 sample the biggest surprise came when I added the Oppo 105D. I previously had the Oppo 95 for almost 3 years but the picture quality is really improved by adding the 105D. I had never seen the the Darbee stand alone systems at work but what I did read was many owners hand shake issues especially with the new JVC models. The integration with the Epson is seamless. There are no handshake issues of any kind. Even if you really like the Oppo 95 which is excellent the video processing combination the Darbee and VRS Clear View bring together is much better with the Oppo105D. The ability to fine tweak and make extremely small adjustments is a real plus.
Projector Settings:
Make sure the projector is as well focused as possible with unit in factory default Super-Res.-0
These settings have worked well for me in my room:
Advance Sharpness- Thick/Thin line Enhancement-+2 Frame Interpolation-+1 Super Resolution- 0
Noise Reduction-+1 Auto Iris- Normal (High Speed works good too)
ISF calibration clearly makes a difference but this projector is fairly close. -85%
Oppo 105D settings:
Darbee Mode- Hi Def-17%
VRSClearView- Detail and Edge Enhancement-+5
Screen/Distances/Summary:
Carada 126 Brilliant White 1.78 Lens distance to screen- 14.8 Seating distance to screen-12.4
Results: Good Blu ray movies always hold my attention so do Live sports. I rarely fall into my fidgeting constantly adjusting mode when watching these sources. DIRECTV and Netflix is a totally different story. I can't seem to stop because the picture quality changes so much on different channels and well you know Netflix. These settings have given me a beautiful well balanced picture for these sources. It is so enjoyable now to just sit and enjoy the movies without the feeling that something doesn't look quite right. My family members always get irritated when I start adjusting the picture. They do not understand I'm just trying to get the very best picture I can. I'm sure many of you do the same thing and your family members don't understand either. Try these settings for DIRECTV and Netflix I think you will be extremely happy.
Good Luck everyone.
home theater is online now
Epson 5030ub 2d 3d 1080p 3lcd Projector
Gear in this thread - 5030ub by PriceGrabber.com
