Official Epson EH-TW 9200 5030UB Owners' Thread - Page 168 - AVS | Home Theater Discussions And Reviews
post #5011 of 5017 Old 05-24-2015, 06:33 PM
Kilgore's Avatar
Quoted: 419 Post(s)
Liked: 300
Originally Posted by ji9988 View Post
Thanks yes the glasses are fully charged and they are the active rf format. They just don't sync. Any other ideas?
Just guessing, but if the glasses have a push button to turn them on, maybe you need to hold the button down until the projector syncs with them.
EDIT: just checked the glasses online and they look virtually identical to the ones that come packaged with the 5030. Don't know what to tell you.
Kilgore is online now
post #5012 of 5017 Old 05-25-2015, 12:30 PM
Nuke61's Avatar
All I've ever had to do is turn on the two different RF glasses I had and they did the sync up. Are you sure they're RF? These might be different than what you have, but according to these sites, it's IR:
http://www.panasonic.com/ca/consumer...ty-ew3d3s.html
http://www.projectorshop24.co.uk/3d-...for-3d-size-s/
http://panasonic.net/prodisplays/dow...-EW3D3W_oi.pdf
Nuke61 is offline
post #5013 of 5017 Old 05-25-2015, 07:42 PM
old corps's Avatar
Quoted: 123 Post(s)
Liked: 67
[QUOTE=ji9988;34461034]HI, Just purchased a 5030. I have panasonic 3d model ty-ew3d3s glasses that worked with the 5010. Does anyone know how to sync these glasses to the 5030? I have tried with a 3d movie playing and then turning on the glasses within 10 feet of the projector but they don't ever sync. Thanks!![/QUOTE
Those are great glasses BUT they are IR NOT RF/Bluetooth. The 5010 used IR (so does my 3010 that I had them for). The 5030 uses RF or Bluetooth glasses. Epson switched to RF from the 5020 on. When I got the 5030 I sold the Pannys to someone with the Panasonic 8000. They're in demand for them (IR) and they're hard to find now. Sorry for the bad news!
Ed
old corps is online now
post #5014 of 5017 Old 05-26-2015, 07:10 AM
ji9988's Avatar
Thanks to all!! Silly me thought since they worked with the 5010 they would work with the 5030. I see now that they are IR and not RF. Thanks again!!
ji9988 is offline
post #5015 of 5017 Old Yesterday, 09:12 PM
Quoted: 18 Post(s)
Liked: 4
I once got a replacement Epson 2030, and no glasses would sync. I had to get a replacement for the replacement, and then they worked. I just upgraded to the 5025 though, awesome projector! Pretty much identical to the 5030 minus 200 lumens. I'm in love with this projector!
therealdjnugz is online now
post #5016 of 5017 Old Today, 07:11 PM
Keith Mickunas's Avatar
Quoted: 93 Post(s)
Liked: 78
I've been getting flicker the past few days. I put it on normal and it goes away and I let it run that way for a few hours and switched back to Eco and after a bit it comes back. I'll leave it on Normal for longer this time and hope that it works.
All-in-all I'm horribly disappointed in this Epson and I don't plan to buy another. This is my third or fourth 5030, the first one was bad out of the box with dust and blurs and such. Then I had one die with a power supply problem, and I think the replacement also died, I really can't remember at this point. Recently I turned it on and the right side of the image was a mess, like it had a checkerboard of green squares all over it. I had to unplug everything and toggle the power a few times. I shouldn't have to deal with this with such an expensive projector. I've been through four RPTVs, I have on LCD, and multiple receivers, DVD players, etc., and none have ever given me trouble like this. Not even close. One year of ownership and it's been a painful experience.
Keith Mickunas is offline
post #5017 of 5017 Old Today, 10:32 PM
Zoltrix's Avatar
Quoted: 12 Post(s)
Hi all,
Been having some dramas recently with getting a projector and screen professionally installed. I started out with an Epson Home Cinema 2030, and the installer wasn't able to get the image perfectly aligned on the screen, and said the lack of lens shift was the issue.
I took their advice and took back to the 2030. I then asked what they recommended, and they recommended an Epson Home Cinema 5030UB.
Now that is installed, and the image still isn't perfectly aligned. See following picture:
http://i.imgur.com/no7bHf8.jpg
You can see it drops in the lower left hand corner. Now the bottom of the fixed frame screen is straight, as I have measured the bottom left and right of the frame from the floor.
Would the lean to the bottom left be the projector that is the issue, or how it is mounted? What is weird is the right vertical part of the test image looks straight, so would that mean if you tilted it to bring the bottom left up, it would cause the top right not to be straight?
Cheers,
Zolt
Zoltrix is online now
Epson 5030ub 2d 3d 1080p 3lcd Projector
