Official Epson EH-TW 9200 5030UB Owners' Thread - Page 172 - AVS Forum | Home Theater Discussions And Reviews
 378Likes
post #5131 of 6030 Old 07-20-2015, 05:48 AM - Thread Starter
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5083
Originally Posted by kriktsemaj99 View Post
^ Changing that much is not normal. I start watching within 5-10 mins of turning on the projector and don't have any issues with focus changing.
Same here. I switch on 15 minutes before movie time, and the focus is totally stable during the movie.
kbarnes701 is offline
post #5132 of 6030 Old 07-20-2015, 08:24 AM
gec5741's Avatar
Quoted: 200 Post(s)
Liked: 91
Yea that's strange. I normally don't turn my pj on till it's show time and by the time I have it up and running and plex functional or my BluRay disc in the PJ already looks pretty good. I just turn off the lights and were good. It probably does sharpen up as the movies get's going but I never notice a huge diff. And I'm pretty picky when it comes to image quality too especially with my streaming content.
gec5741 is offline
post #5133 of 6030 Old 07-20-2015, 03:47 PM
Zoltrix's Avatar
Quoted: 57 Post(s)
If you guys could test it out using the built in test pattern and let me know that would be great. As I have to decide if I am going to try and return the projector and the whole process is getting rather depressing. It has a been a long 4 months.
If you could put up the test pattern as soon as your projector is on and check all sides of the white lines to see if it is perfect focus, then recheck after projector has been on for an hour and see if you notice any difference.
Zoltrix is offline
post #5134 of 6030 Old 07-20-2015, 05:30 PM
kriktsemaj99's Avatar
Quoted: 646 Post(s)
Liked: 364
Originally Posted by Zoltrix View Post
...If you could put up the test pattern as soon as your projector is on and check all sides of the white lines to see if it is perfect focus, then recheck after projector has been on for an hour and see if you notice any difference.
That's not really what you want to test. You might expect some change from the initial focus (checked as soon as the projector is on, which means it's still cold). What you should not expect is any change between the 10 minute mark and 1 hour. So never focus right after turning on, always wait a while (e.g. 10 mins, or a bit more to be safe) before you do it.
kriktsemaj99 is offline
post #5135 of 6030 Old 07-20-2015, 07:41 PM
Zoltrix's Avatar
Quoted: 57 Post(s)
Yep that's the problem. If I wait say 20 mins after turning it on, and then adjust the focus, 30 mins later it will be completely different if I check it again. The focus only seems stable after the projector has been on for at least 2 hours. After that if I set the focus it seems to remain stable.
If this isn't normal, then I guess I should be asking for a replacement?
Cheers,
Zolt
Zoltrix is offline
post #5136 of 6030 Old 07-20-2015, 07:44 PM
Quoted: 646 Post(s)
Liked: 364
^ Defiinitely not normal. I would ask for a replacement.
Kilgore likes this.
post #5137 of 6030 Old 07-20-2015, 08:23 PM
therealdjnugz's Avatar
Quoted: 84 Post(s)
Liked: 33
Cheers,
Zolt
Is the focus way off when you recheck it? Just putting this out there, say you're watching something and you have the Super Resolution on at lets say three. If you turn it off the image can look soft and kind of out of focus because you're used to it with the super resolution. Are you making sure you're checking the focus with the same sharpness and super resolution settings? A lot of times when I switch between inputs on my receiver, the projector settings change.
therealdjnugz is offline
post #5138 of 6030 Old 07-21-2015, 03:42 AM
Liked: 0
Hi all,
I have an Tw9200 (80hrs on the bulb) that after about an hours viewing has started to display random white dots all over the screen (looks like static).
I took it to a technician and they couldn't find anything wrong, but replaced the motor. They said if it is still happening it's either a poor power source (power board) or HDMI cable.
Has anyone had any experience with something like this? I am going to trouble shoot with the board and cables, but it sounds suss to me.
Dbuns is offline
post #5139 of 6030 Old 07-21-2015, 12:09 PM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
Originally Posted by Dbuns View Post
Hi all,
Did you call Epson?
Kilgore is offline
post #5140 of 6030 Old 07-22-2015, 04:42 AM
garnuts's Avatar
Quoted: 83 Post(s)
Liked: 59
Hi all,
I had something similar. I called them 'sparkles', especially showing against a dark background.
I replaced some hdmi cables and changed the configuration of my hdmi splitter and Darbee Darblet and that eliminated the sparkles.
Before configuration: (the sparkles did not begin appearing until many months of this set up)
AVR > 6' hdmi > Darblet > 6' hdmi > hdmi splitter >> 6' hdmi to TV & 35' hdmi to projector.
I replaced the three 6' hdmi cables and still had some sparkles but less than before. Then I put the Darblet after the splitter going only to the projector... and that fixed it.
Now: AVR > 6' hdmi > splitter > >6' to Darblet > 35' to PJ and the other split 6' to TV.
I'm not sure how much of my problem was the cables or the Darblet, but it's most likely the hdmi cables. I was also getting occasional 1-3 second random video disconnects going to the PJ with the first setup, and those stopped after placing the darblet after the hdmi splitter.
garnuts is online now
post #5141 of 6030 Old 07-24-2015, 04:23 AM
Liked: 0
I called Epson and that's how I got in touch with the technician.
I tried another HDMI cable and it seemed to fix the problem. The only issue is that I now have a busted 15m HDMI cable that is run through the roof of a 2 story house. No idea if I can get it out, let alone run another one
Dbuns is offline
post #5142 of 6030 Old 07-24-2015, 08:01 AM
Mike Garrett's Avatar
Quoted: 5947 Post(s)
Liked: 3845
Watching a movie is a lot different than watching a test pattern. A test pattern is designed to show any flaw in the image. Flaws that you see on the test pattern will never be seen during movie viewing, so guys watching movies will not notice if projector is not 100% fully focused.
mjgarrett100@gmail.com
Mike Garrett is online now
post #5143 of 6030 Old 07-24-2015, 10:54 AM
Nuke61's Avatar
Quoted: 18 Post(s)
What you could try is to tie a strong, thin, string to the bad cable, and then pull the cable out. Then pull the new cable with string. If you don't think the first string is strong enough, pull it again with stronger string or thin rope. I've had to do this before, although it was only about 7m and not 15m of cable.
Nuke61 is offline
post #5144 of 6030 Old 07-24-2015, 11:31 AM
detroit1's Avatar
Quoted: 98 Post(s)
Liked: 33
what can people tell me about the picture quality improvement after that last firmware update
It it a noticeable difference ?
detroit1 is online now
post #5145 of 6030 Old 07-24-2015, 12:40 PM
Quoted: 646 Post(s)
Liked: 364
Originally Posted by detroit1 View Post
what can people tell me about the picture quality improvement after that last firmware update It it a noticeable difference ?
There's no difference unless you turn on Super-Resolution, which is the main feature they enhanced. It's a kind of sharpening algorithm, but does a good job at a low setting of improving perceived image quality.
post #5146 of 6030 Old 07-24-2015, 02:01 PM
Liked: 0
My case is different, because I need the subtitles. So the focus is very important.
Fabio-RS is offline
post #5147 of 6030 Old 07-24-2015, 05:04 PM
Zoltrix's Avatar
Quoted: 57 Post(s)
That might be the case for movies, though I would still argue the point that on reference level blu-rays you might notice.
Test patterns aside, I was noticing when using gaming consoles like the PS4 that the image wasn't in uniform focus. Especially on the menu system which is full of text and when playing games as well, as games have a very sharp image in most cases.
For a projector that has a $3,599 RRP in Australia, I do think it is fair to expect better.
Zoltrix is offline
post #5148 of 6030 Old 07-24-2015, 06:09 PM
Quoted: 646 Post(s)
Liked: 364
^ Non-uniform focus is a different issue than focus drifting as the projector warms up. The screen may not be flat, or the projector not pointed dead straight at the screen. Both of these things mean the distance from lens to screen varies at different points in the picture, and so they can't all be in focus at the same time.
post #5149 of 6030 Old 07-24-2015, 06:14 PM
Zoltrix's Avatar
Quoted: 57 Post(s)
That was my initial thoughts as well. But I had a loaner 5030UB from the installers before I purchased the new one. The loaner did not focus drift, or have non-uniform focus when using the same projector mount and same projector screen.
Also, as mentioned previously, the new one did weird things, such as, be 50% out of focus 30 minutes after turning it on, then after 2 hours you could adjust it to get 95% uniform focus. I would assume behavior like that wouldn't be caused by the mount or screen?
Zoltrix is offline
post #5150 of 6030 Old 07-24-2015, 06:18 PM
Quoted: 646 Post(s)
Liked: 364
Then you definitely should ask Epson for a replacement. By all accounts they have very good support and shouldn't give you a hard time over it.
post #5151 of 6030 Old 07-24-2015, 07:19 PM
Quoted: 84 Post(s)
Liked: 33
Exactly. When I turn my projector on, the image isn't dead center. But after 10-15 minutes, it is centered. I only know this because I'm obsessed with checking to see if it's center. I honestly probably wouldn't notice if I didn't check every day. Also, the lens shift slides a little out of place time to time. It's all part of the game.
post #5152 of 6030 Old 07-25-2015, 05:09 AM - Thread Starter
kbarnes701's Avatar
Liked: 5083
Fishing line with an enormous breaking strain would be a good choice I'd expect?
post #5153 of 6030 Old 07-26-2015, 11:33 PM
tilani's Avatar
Quoted: 27 Post(s)
Hi Everyone
I just bought my 5030ub and it will be here on Tuesday. I had a question about mounting it.
I have a 150" screen (diagnol) and would like to place this projector at about 20ft back (above my last row of seating). I am going to have the screen about 6" from the ceiling. Is there a recommended distance the projector needs to be from the ceiling? Also the calculator that everyone uses to measure throw distances has mine in the Red zone for this distance and this size. My room is completely dark. Can anyone comment on my decisions here?
tilani is offline
post #5154 of 6030 Old 07-27-2015, 08:50 AM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
You won't need to worry about the screen or projector height. You'll be able to use the lens shift feature to place the image directly onto the screen. Just make sure that your PJ is positioned level to the floor and pointing directly across at the wall.
Hitting the 150" screen from 20' is certainly doable. I would recommend going 3 or 4 feet closer if you can to compensate for loss of lumens as the lamp ages. I think it's better to maximize lumen output overall. If you can manage it, you should try the PJ at different distances on the ground and then decide where to mount it. Again, using lens shift makes this easy.
Kilgore is offline
post #5155 of 6030 Old 07-27-2015, 09:21 AM
climber07's Avatar
Quoted: 336 Post(s)
Liked: 1344
I agree. Getting as close to the screen as possible will maximize your lumens. You should be okay with 20 feet if you are unable to get any closer due to aesthetics or mounting options. Especially if you are in a 100% light controlled room. The 5030 is a pretty bright projector.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #5156 of 6030 Old 07-31-2015, 07:09 PM
Nuke61's Avatar
Quoted: 18 Post(s)
My experience has been that fishing line is difficult to make a secure knot, because it's typically some sort of slippery poly-something or other - I'm not a fisherman, as you can probably tell
But if you can tie a knot with fishing line, that should work well too.
Nuke61 is offline
post #5157 of 6030 Old 07-31-2015, 08:06 PM
climber07's Avatar
Quoted: 336 Post(s)
Liked: 1344
You have to tie a fisherman's knot...
The only difference is that A or B is the loop end.
Nuke61 and old corps like this.
post #5158 of 6030 Old 08-05-2015, 12:56 AM
jrdnlc's Avatar
Quoted: 60 Post(s)
I plan on getting this projector for my living room. I have big windows but have blacked out curtains so light is controlable. Anyone have idea how big of a screen I can get with 12ft from wall to wall? I plan to go with Black Diamond Zero Edge 1.4 gain screen.
Also, is it worth the extra cost for wireless? is it stable enough and reliable?
Any help will be greatly appreciated. Thanks!
Sony XBR-75940C | Denon x4300H | 7.1| OPPO UDP-203 | Xbox One S | PS4 Pro
jrdnlc is offline
post #5159 of 6030 Old 08-05-2015, 06:52 AM
Liked: 3845
Guys with projectors like the Epson, might be interested in a new anamorphic lens that is in development. See this thread: http://www.avsforum.com/forum/24-dig...orph-lens.html
post #5160 of 6030 Old 08-05-2015, 10:19 AM
Quoted: 646 Post(s)
Liked: 364
^ The 5300 has no anamorphic stretch (the 6300 does). Also this new lens seems to be of low enough quality that it needs colour correction at the edges. Maybe the Epson panel alignment feature could be used for that, but I'm not sure the result would be pretty.
Epson 5030ub 2d 3d 1080p 3lcd Projector
