Official Epson EH-TW 9200 5030UB Owners' Thread - Page 198 - AVS Forum | Home Theater Discussions And Reviews
 362Likes
post #5911 of 5924 Old 08-11-2016, 07:45 AM
Hawkmarket's Avatar
Quoted: 50 Post(s)
Originally Posted by mos7272 View Post
Hi All,
just need help with my Epson 9200 5030UB. i only got mine few weeks ago and the fan noise is unbearable when on higher lamb setting. i have been searching about it and some people have same issue and some say there is no issue. is it possible that some units are better than other ? i want to complain to Epson but then how do i prove that mine is louder than others? can anyone help with that?
You could return it and get the 5040 that comes out in a couple weeks. With that one it has another mode between ECO and Normal that is every bit as bright as high lamp mode on the 5030 but apparently is much quieter. I also have the 5030 and when I hung it on the ceiling it definitely added noise. It's not really bothersome when I'm watching an action movie but fan noise will be a bigger priority with my next projector and the new Epson's in Medium mode supposedly check that box. I'd highly consider that vs. spending the next three years watching a darker picture or noticing the fan noise in high lamp mode during quieter scenes.
Bluescale likes this.
Hawkmarket is offline
post #5912 of 5924 Old 08-11-2016, 05:32 PM
WindsorTheater's Avatar
Originally Posted by xnappo View Post
Blue band is exactly the problem I had with my 3020 that I just bought a 5030ub to fix.
See this thead:
Epson 3010 help fixing blue band on right side
If you go down that thread rabbit hole you willbfind some instructions on opening the projector and reseating lenses. I tried it, it was hard and didn't fix it, but maybe you will have better luck.
xnappo
Worked for me. had to redo it every 6 months or so due to thermal cycling. Today opened it up again to reseat and ended up damaging an LCD ribbon due to over cycling / bending. also some of the clips on the board that clamps the ribbon cables from the LCD to the main board loosened and fell off.
Long story short now looking at a used 5030 to replace the 3010. No regrets though. The lens reseat worked for years.
WindsorTheater is online now
post #5913 of 5924 Old 08-13-2016, 08:11 PM
ejfriis's Avatar
Quoted: 18 Post(s)
Hello, I am hoping someone can help me. I have had the 5030UB for awhile now, and it has served me well.
Right in the middle of a movie today, suddenly these little squares showed up all over the screen in a grid pattern. Each square is made of red, green, blue dots. See photo.
It does it even without the receiver on, and I checked the cables. I think it is the projector.
What can I do about this? I'm going to go dig up my paperwork before I contact Epson, but was hoping there was something I could do on my end?
Thanks for any advice.
ID:	1601361   Click image for larger version
ID:	1601369   Click image for larger version
ejfriis is offline
post #5914 of 5924 Old 08-13-2016, 09:27 PM
climber07's Avatar
Quoted: 315 Post(s)
Liked: 1321
Unfortunately, it's a bad omen. You can try to power the unit down completely by removing the power cable and reseting all options to default. Them try the test screens for panel alignment to see if the problems exist there. If they do, your LCDS or LCD controller are bad.
climber07 is online now
post #5915 of 5924 Old 08-15-2016, 05:29 PM
ejfriis's Avatar
Quoted: 18 Post(s)
Actually removing the power cable and plugging back in fixed it! I called Epson, and that was also their advice. He says a 'false error' occurs occasionally, and it has something to do with the screen door effect in the lens. I pushed for a more technical explanation but didn't get one. He made it sound like this is somewhat common, and might happen once or twice over the lifetime of the projector.
I'll post back if I see it again.
Overall I found the customer support helpful and polite.
ejfriis is offline
post #5916 of 5924 Old 08-15-2016, 06:45 PM
climber07's Avatar
Quoted: 315 Post(s)
Liked: 1321
That's awesome news. Glad you're out of the woods on that one. They do have great customer service.
post #5917 of 5924 Old 08-15-2016, 09:06 PM
jaydee77ca's Avatar
Quoted: 29 Post(s)
Liked: 24
Has anyone found any easy home fixes for a loud iris? I got a new unit recently due to lamp flicker in my old one. The iris on this one is quieter than my old one. I'm not sure if it's the fact that it's a different unit or that I did something different/better when installing it. That made me think maybe there is a way to make it even quieter. Like maybe by putting rubber somewhere to avoid vibration or something. Just thought I'd see. Any ideas? Thanks?
jaydee77ca is offline
post #5918 of 5924 Old Yesterday, 10:14 PM
willieconway's Avatar
Quoted: 104 Post(s)
Liked: 102
My 5030 has developed a semi-bright red blob all of the sudden. It's by the left edge of the picture, about halfway up, about the size of 3 quarters (coins) on my 100" screen, and only visible on darker content. I see it when that area is maybe IRE 40 and down to black. It's fairly distracting. Since it only shows on dark content I can't get a good picture of it though.
Does anybody know what it might be?
willieconway is online now
post #5919 of 5924 Old Today, 02:36 AM
talon95's Avatar
Quoted: 106 Post(s)
Liked: 55
Dust blob on one of the LCD panels. Mine has one too although it's not as visible as yours. Only shows up when the image is mostly black.
willieconway likes this.
talon95 is offline
post #5920 of 5924 Old Today, 12:59 PM
Quoted: 104 Post(s)
Liked: 102
Well, while I'd prefer to get a flawless unit, Epson's great customer service strikes again. I'm getting a warranty replacement sent to me early next week. I opted for the credit card hold so that I can keep my current unit until then.
The rep had me perform a few trouble-shooting steps; clean the lens, unplug all cables, turn on with no HDMI cable plugged in. As expected nothing worked. He didn't tell me what the issue might be but I also didn't ask.
The replacement will be my 3rd unit. My first one developed flickering after about 500 hours.
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D. Currently boxed up: Denon 1713, Klipsch SW-450,
NHT Absolute Center, Energy Veritas 5.1s, 5.2C, V-Mini-C.
post #5921 of 5924 Old Today, 01:39 PM
talon95's Avatar
Quoted: 106 Post(s)
Liked: 55
Mine is so minor that I can't decide if I want to try to get a replacement or not. I've got until next April anyway.
talon95 is offline
post #5922 of 5924 Old Today, 01:47 PM
Quoted: 104 Post(s)
Liked: 102
If it doesn't bother you and you're otherwise happy with the unit, I would also consider doing nothing. My current unit that I'll be returning next week is quieter than my first one. In addition it's almost 100% accurate out of the box in THX mode whereas my first unit required quite a bit of adjustment. It does pain me to send it back but the red blob is just too visible.
post #5923 of 5924 Old Today, 06:45 PM
Liked: 1
Just picked up a 5030UB for $1100. The salesman said it was much better than 2400 and was only $100 more on sale.
This is my first projector and I have quite a bit to say about it.
First, my old tv: LCD (not LED) from 2006. I am moving and this was a really old set with terrible quality so I finally decided to upgrade.
I am currently projecting 5030ub on a yellow wall with small room so only ~50" display.
I calibrated the unit with THX mode, low interpolation, detail enhancement at 3. Did some panel adjustments as my blue was a bit high, everything else is fine.
The quality is out of this world. Better than my local cinema. I can't imagine how it will look on a proper screen and at 100".
The unit is SUPER quiet. I can't even hear the fan running, I don't know how people can hear it at all. I even put my ear all the way to the projector and it's whisper quiet.
SUPER happy with the projector. Glad I spent an extra $100 instead of 2400.
3lcd is offline
post #5924 of 5924 Old Today, 11:07 PM
los seres's Avatar
Definetly a dust blob on the red lcd panel. I had 2 on the green Lcd panel and since my projector was out of warranty I went ahead and opened the projector and
blew the dust out with compressed air. If you ever want to try this and are handy with tools all you will need is a Phillips screwdriver and some patience. This guy has
a cool teardown of the 6030ub Projector (which is basically a 5030ub in black).
los seres is online now
Epson 5030ub 2d 3d 1080p 3lcd Projector
