Official Epson EH-TW 9200 5030UB Owners' Thread - Page 200 - AVS Forum | Home Theater Discussions And Reviews
 373Likes
post #5971 of 5997 Old 10-24-2016, 06:49 AM
Nuke61's Avatar
Quoted: 18 Post(s)
Originally Posted by merceg100 View Post
Hi guys. I'm planing to buy myself 5030ube cos I think I won't get much of improvement on 5040 on 1080p content only. there are just a few stores selling 5030 and I think I should hurry before they are sold out like 5030ub. but i'm suspicious whether I'm going to get new or refubrised ones. I'm asking these cos I won't be here in the states much and wouldn't like to take home refurbished pj. thanks for any help provided.
I'm pretty sure that if a store is selling a refurbished item, they must explicitly tell you that it's refurbished. With that said, I've never heard of a brick and mortar store selling any refurbished items -- but I've seen "open box" many times. As long as the store is a big chain store, you should have no reason to worry.
Nuke61 is offline
post #5972 of 5997 Old 11-13-2016, 07:49 PM
KBS756's Avatar
I'm sure its probably been answered on here before but is there a cheaper alternative to buying the $300 bulb with housing ... like can one buy the bulb and replace it themselves and save a significant part of the cost?
if so does anyone have any suggestions on where to buy and what to buy?
thanks!
KBS756 is offline
post #5973 of 5997 Old 11-14-2016, 09:41 AM
gec5741's Avatar
Quoted: 200 Post(s)
Liked: 91
Hi everyone. It's been a while since I've been on this thread. I've had my Epson 5030ub now for about 2 year. Just put in my second bulb and have recently started getting reunited with the 3d on this projector! I have to say some of the newer 3d movies have looked absolutely awesome! I 6 pairs of glasses but would like to get a few more. 3 of my glasses however takes batteries which is kind of a drag. Does anyone have any recommendations on good deals for rechargeable? A while back best buy had some going cheap butI was only able to get 1 pair before they went out of stock. Thanks in advance!
gec5741 is offline
post #5974 of 5997 Old 11-21-2016, 01:17 PM
Quoted: 16 Post(s)
Liked: 0
Hello guys. My tw9200 had a no signal problem 2 weeks after the end of warranty. So i end up with a motherboard change issue. It was very expensive at service. Do you know any site that i can find a tw9200 motherboard for sale. Thank you very much.
Serkan
-spawn- is offline
post #5975 of 5997 Old 11-21-2016, 03:26 PM
Liked: 1
My TW9200 have started to do a high pitch "pip.. Pip.." sound when i play movies in ECO mode,anyone know what it is and why it does it?
Squeegie is offline
post #5976 of 5997 Old 11-30-2016, 01:40 PM
eliocon's Avatar
Hi guys,
I have a dust blob on screen. Does anyone know the procedure to open the 5030 up? I'm out of warranty so I have to clean it myself. I've cleaned other projectors before so I know what I'm doing in that regard. Just can't seem to figure out how to open this projector. There must be a screw I'm missing.
Thanks in advance!!!
Elio
eliocon is offline
post #5977 of 5997 Old 11-30-2016, 02:25 PM
talon95's Avatar
Quoted: 130 Post(s)
Liked: 63
Originally Posted by eliocon View Post
Hi guys,
Elio
talon95 is offline
post #5978 of 5997 Old 12-01-2016, 07:39 PM
jenielsen's Avatar
Hello all,
I bought a new house and the previous owner left his Epson 5030UB in the media room (lucky me). The lamp has ~2500hrs on it and I see some flicker... Thinking of replacing the bulb as I've seen simliar issues in other DLP PJs that I've owned over the years. There are a LOT of replacement lamps out there, and I'd prefer an original OEM lamp. Can anyone share a source to purchase a new lamp & housing from? I'm not afraid to spend $300 on one, I just don't know besides directly from EPSON who carries the original OEM lamps. Will you share where you have purchased them from? TIA.
jenielsen is offline
post #5979 of 5997 Old 12-02-2016, 09:11 AM
eliocon's Avatar
Originally Posted by talon95 View Post
Thank you so much, Talon!!!!
Elio
eliocon is offline
post #5980 of 5997 Old 12-02-2016, 12:29 PM
optoguy's Avatar
Could someone tell me the size of screws to mount the 5030? I've been doing a search in this thread and the manual, but no luck. I just moved, originally had the projector shelf mounted, and am now going to go with a ceiling mount.
Darren
optoguy is offline
post #5981 of 5997 Old 12-28-2016, 07:29 AM
dougdude9's Avatar
Hey all,
What is the best place to get a new lamp? I've done quite a bit of searching and it seems most places have non-oem bulbs and the reviews are terrible. I definitely want to go OEM and I'm curious what the price should be and what might be some good places to look.
Doug
dougdude9 is offline
post #5982 of 5997 Old 12-29-2016, 01:19 PM
xnappo's Avatar
Quoted: 89 Post(s)
Liked: 86
Honestly I would skip the hassle and just buy it direct from Epson:
https://epson.com/listing?q=%3Arelev...lTgt_onRefresh
xnappo is offline
post #5983 of 5997 Old 01-17-2017, 10:43 PM
KilroyNo1's Avatar
Liked: 1
Darren
Did you ever find out the size of the mounting screws? My HT room is nearing completion and I'm finally able to unbox and mount the 5030 I purchased on Boxing Day 2015 and to my surprise....no mounting screws. Talk about your cost cutting measures!
No person is an island.
KilroyNo1 is offline
post #5984 of 5997 Old 01-18-2017, 09:27 AM
optoguy's Avatar
Hi KilroyNo1,
Screw size is M4 x 9. Congrats on finally being able to unbox your 5030!
optoguy
optoguy is offline
post #5985 of 5997 Old 01-18-2017, 04:10 PM
KilroyNo1's Avatar
Liked: 1
Hi KilroyNo1,
optoguy
Thanks optoguy. I stopped at Rona and purchased #6 -32 x 3/8" and #8 -32 x 3/8" screws on the way home and #6 was too small and #8 a hair too large. They don't even offer metric sizes. Go figure.
post #5986 of 5997 Old 01-18-2017, 11:48 PM
tguzz's Avatar
Hello all,
I have the 5030ub (which I love). Does anyone have a solution for keeping my image from moving down after I set the image height?
tguzz is offline
post #5987 of 5997 Old 01-19-2017, 12:47 PM
jcp2's Avatar
Quoted: 37 Post(s)
Liked: 27
Originally Posted by tguzz View Post
Hello all,
Tape?
jcp2 is offline
post #5988 of 5997 Old 01-20-2017, 11:07 AM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
Hello all,
The 5030 seems to have fairly crude image position adjustment. The gears are coarse and do not allow "fine tuning". It also seems to creep over time. I have to adjust the height of the image occasionally. I wish they had used finer gears for the adjustment so that it would solve this problem.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #5989 of 5997 Old 01-20-2017, 02:15 PM
trailblazer's Avatar
Quoted: 21 Post(s)
My 5030UB also shifts every day, top comes down and also shifts left or right slightly. Real annoying when you set the image 1:1 (no over scan) pixels. The slightest movement shifts you into the black area of the picture. My opinion is that this is an internal problem as mentioned above about the gears and not the dials.
trailblazer is offline
post #5990 of 5997 Old 01-28-2017, 10:52 PM
Keith Mickunas's Avatar
Quoted: 104 Post(s)
Liked: 81
For the last few days my 5030UB has been shutting down for no reason every thirty minutes or so. I can't quite figure out what's going on. I can turn it right back on and it works fine again, but it'll shut itself off again after a bit. There's no messages and nothing happening with the LEDs on the projector to indicate any kind of problem. The projector is over 2.5 years old now and I have over 3300 hours on the bulb. Anybody have any idea what could be wrong with it and if there's any way to fix it? It's out of warranty so I'm a bit concerned about what getting it repaired by Epson will involve.
Keith Mickunas is offline
post #5991 of 5997 Old 01-29-2017, 01:46 PM
garnuts's Avatar
Quoted: 79 Post(s)
Liked: 57
My 5030 is also about 2.5 years old with only 1500 hours on the original bulb. I've never had any problems with it.
My first thought is maybe it's overheating, though I don't know how you would diagnose that.
Have you cleaned the filter lately?
Living Room: Denon X4000, XPA-5, Polk RTiA9, CSiA6, RTiA3-wides, FXiA4, OWM3, SVS PC12+, 4 Shakers, Epson 5030, VApex 92”, Sony XBR9 52”, PS3, Xbox 360, Darbee, Harmony 1.
Bedroom: Denon X2000, Polk: RTiA3, CSiA4, RTiA1, SVS SB12-NSD, Sony XBR-55X850B, Sony BPD-S590, Xbox 360, RPi2-RasPlex, Darbee, Harmony 510.
Home Office: Onkyo 707, Polk: LSiM 703, LSiM 704, Monitor 70, Yamaha SW315 x 2, Turntable, Triple Monitors, Harmony 610.
garnuts is online now
post #5992 of 5997 Old 01-29-2017, 01:55 PM
Quoted: 21 Post(s)
Since you have a lot of hours on the bulb, it may be the problem. Unfortunately the only way to test it is to get a new bulb to see if that addresses the problem! Also check your air filter and make sure that the bulb assembly is properly seated in the projector.
post #5993 of 5997 Old 01-29-2017, 02:30 PM
Quoted: 104 Post(s)
Liked: 81
I cleaned the filter yesterday and the problem persisted. And since it came right back on and ran for about the same amount of time as before it doesn't seem like the problem is heat related.
I could swap the bulb, I bought a spare quite a while back. I'd expect a message or some blinking lights if it's a bulb problem though.
post #5994 of 5997 Old 01-29-2017, 09:38 PM
Quoted: 104 Post(s)
Liked: 81
I swapped the bulb and no effect. I went into the menu and found the sleep timer and disabled that, no effect. But tonight I started timing the occurrences and noticed that it was happening at just about 30 minutes each time. So I disabled the HDMI Link feature or whatever that is. The only device it was recognizing was my nvidia Shield. That got a major software upgrade just prior to this happening and is the only change that occurred in my system recently. Now it's been running for about an hour without an issue.
I think the upgrade occurred on Thursday, and that day I only spent a lot of time watching the Shield and nothing else. However Friday, Saturday and Sunday I used the DVR most of the time. Friday I started watching the Shield for a bit, then I switched inputs on the receiver to the DVR and the projector shut off at that point. Everything runs through the receiver but I'm guessing those HDMI connections are live to most devices most of the time. I'm thinking that when I powered on the projector and receiver the Shield detected it, even though it wasn't in use. It started its sleep timer and after 30 minutes it turns off the projector as it believes nothing is being used since it received no commands. And every time I restarted the projector it would restart the timer on the Shield.
I certainly hope the problem is fixed. While I wouldn't mind upgrading to one of those 4k-like projectors I'm not quite ready to do that yet, and I'm hoping to sell the 5030 to help cover some of the costs.
post #5995 of 5997 Old Yesterday, 06:46 PM
Gabre's Avatar
Quoted: 135 Post(s)
Take it to epson for a diagnose, they charge like 50$ for ir.
Gabre is online now
post #5996 of 5997 Old Yesterday, 09:22 PM
Quoted: 104 Post(s)
Liked: 81
Why? I found the problem. See the post directly above yours.
post #5997 of 5997 Old Today, 11:24 AM
Gabre's Avatar
Quoted: 135 Post(s)
Sorry, missed that post somehow.
Allthough its quit weird that some other device can turn off projector which is receiving signal at the time?
Gabre is online now
Epson 5030ub 2d 3d 1080p 3lcd Projector
