Official Epson EH-TW 9200 5030UB Owners' Thread - Page 76 - AVS Forum | Home Theater Discussions And Reviews
 376Likes
post #2251 of 6017 Old 01-29-2014, 08:30 PM
domitron's Avatar
I wanted to update everyone on my projector and the focus issue. It's gone. I don't know if it was a new bulb thing (have 62 hours on now) or that I was just not waiting 30 minutes for the adjustments as the manual stated. Whatever the reason it hasn't slipped focus again. I don't even notice it off when the unit first heats up either. In fact it's really perfect focus across the entire screen.
domitron is offline
post #2252 of 6017 Old 01-29-2014, 09:14 PM
Mike Garrett's Avatar
Quoted: 5663 Post(s)
Liked: 3627
Any three panel projector needs around 30 minutes for the panels to warm up and stabilize. Glad to here that your problem is gone. smile.gif
mjgarrett100@gmail.com
Mike Garrett is offline
post #2253 of 6017 Old 01-30-2014, 06:05 AM
bigly's Avatar
Originally Posted by Skylinestar View Post
How do I correct the convergence error? FYI, I have the red line appearing slightly above the white line.
I've went to the pattern settings, with color R, R/G/B, then adjust with the UP, DOWN, LEFT, RIGHT buttons....but I don't see a difference. Am I pressing it wrong?
Hi Skylinestar,
I recently posted in the 5020 thread on my experience with panel alignment which applies equally to your 5030:
http://www.avsforum.com/t/1449027/epson-5020ub-owners-thread/1170#post_24283018
My advice, after trying both methods is to totally ignore the corners and intersections in the LCD alignment process.
Instead, identify what your problem is from any image with easy to identify pixel structure. The Epson's menus are good for this.
Then simply apply your pre-calculated adjustment equally to all four corners in the alignment process.
Note that until you have done that to all four corners, it doesn't seem to be working.
According to historical threads for this projector's lineage, a value of 8 equals one whole pixel.
I.E. If you want to move the red line down a pixel, apply a Vertical + 8 to all four corners in the alignment process for red.
If you do anything else, such as changing each intersection or corner to make each area look good whilst doing the alignment, you are forcing the Epson to apply scaling, potentially with a different ratio in each area of the screen.
In my experience doing that lowered the overall sharpness of my image.
Following the 'all four corners the same in multiples of 8' method I now have great alignment with uniform sharpness.
The crucial post for me to change my alignment method was in the 5010 thread @ http://www.avsforum.com/t/1377321/official-epson-powerlite-home-cinema-5010-6010-thread/930#post_21631035
bigly is offline
post #2254 of 6017 Old 01-30-2014, 04:30 PM
Orwellflash's Avatar
http://www.projectorcentral.com/epson_6030ub_runco_x200i.htm?page=Observations
:)Home Theater Projector Shootout:
EPSON 6030UB vs RUNCO X-200i
That's a picture of Leadbelly's grave in Shiloh Baptist Church Cemetery Mooringsport Caddo Parish Louisiana (with Arlo Gutherie's guitar picks placed in memoriam). Arlo put them on his grave in 2005 and they were still there in 2012.
Orwellflash is offline
post #2255 of 6017 Old 01-30-2014, 08:50 PM
teebo2345's Avatar
Originally Posted by jmhart View Post
That looks like the moire effect caused by the texture of the surface you're projecting onto interacting with the visible pixel structure of the projector, though you've said you tried projecting onto a wall and noticed the same thing which should rule that out. Does changing the 'roll' angle of the projector make any difference in the pattern (by raising one side of the projector)?
You were exactly right. I thought I tested on a blank wall but that must have been an error on my part. I held up a piece of white paper and the lines totally disappear! Does this mean that my screen material is defective? The screen is the Elite acoustically transparent 1080P2 material.
http://www.amazon.com/gp/product/B008M11Y9U/ref=oh_details_o08_s00_i00?ie=UTF8&psc=1
They do have a P3 which was more expensive and supposed to be for 4K which didn't seem to have a benefit for me. Any suggestions would be very much appreciated!
teebo2345 is offline
post #2256 of 6017 Old 01-30-2014, 09:00 PM
AlexanderDelarg's Avatar
Quoted: 151 Post(s)
Liked: 171
Projector Central loves the Epson 6030 and for good reason - it is a solid projector and best in class in its price range. I will get mine in two weeks and I can't wait. The Oppo 103 paired with the 6030 should make for some fine movie viewing.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is offline
post #2257 of 6017 Old 01-31-2014, 04:46 AM - Thread Starter
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5073
kbarnes701 is offline
post #2258 of 6017 Old 01-31-2014, 06:48 AM
Greg_R_STL's Avatar
Quoted: 16 Post(s)
Liked: 25
You know what? The screen material isn't defective, you're just more demanding than most people, you actually don't want your screen material to cause visual artifacts. Welcome to my world biggrin.gif
Greg_R_STL is offline
post #2259 of 6017 Old 01-31-2014, 07:49 AM
teebo2345's Avatar
Haha - yes this is true. No denying it. Do you have a recommendation for an acoustically transparent screen that wont show this moire effect?
post #2260 of 6017 Old 01-31-2014, 07:54 AM
lapino's Avatar
Quoted: 73 Post(s)
Ordered my TW9200W, should be here within 2 weeks. Have someone installing it for me at home, and calibrating it at the same time (with a re-calibration after 500 and 1000 hours of use). Very anxious to see how it'll stack up against my previous projectors (Optoma HD20 and Benq W1070).
lapino is offline
post #2261 of 6017 Old 01-31-2014, 07:59 AM
Greg_R_STL's Avatar
Quoted: 16 Post(s)
Liked: 25
Heck, the problems I had were with NON a.t. screen materials. Putting a bunch of little holes in your screen is just asking for trouble tongue.gif Seriously though, if you go DIY, I think that spandex would be a good way to go for AT. I tried a two layer test with JoAnn spandex, there are many, many threads on this, and it looked pretty good, it just wasn't quite right for my particular frame.
post #2262 of 6017 Old 01-31-2014, 08:32 AM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
New 6030 owner, quick question.
Is it normal on startup for the image to be completely green for aprox. a min or so?
After colors balance out.
TL
trans_lux is offline
post #2263 of 6017 Old 01-31-2014, 08:34 AM
Greg_R_STL's Avatar
Quoted: 16 Post(s)
Liked: 25
TL
Mine does it, as do others in this thread, so I would say yes.
post #2264 of 6017 Old 01-31-2014, 08:40 AM
WestCDA's Avatar
Quoted: 66 Post(s)
Liked: 78
Good stuff - I don't think you'll be disappointed with your decision. Let us know your impressions once you get things set up. smile.gif
WestCDA is offline
post #2265 of 6017 Old 01-31-2014, 08:42 AM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Thanks for the quick response and info.
post #2266 of 6017 Old 01-31-2014, 08:57 AM
lapino's Avatar
Quoted: 73 Post(s)
I have a Beamax M-Series 102" motorized screen with a 1.5 gain (I think, invoice says 1.5 but internet info seems to differ between 1.2 and 1.5). Is that ok for this projector? Type is Beamax 10236 M.
(this one http://www.livingcinema.eu/beamax-10236-white-size-244x142-169-matte-white-gain-p-542.html)
lapino is offline
post #2267 of 6017 Old 01-31-2014, 09:05 AM
WestCDA's Avatar
Quoted: 66 Post(s)
Liked: 78
I have a Beamax M-Series 102" motorized screen with a 1.2 gain (I think, invoice says 1.5). Is that ok for this projector?
At that size and gain, in a light controlled environment, you should be very happy with the performance in both 2D and 3D. This projector is capable of generating a lot of light, and a positive gain 102 inch screen should really pop. Light control in the room, as with any projector, is key.
WestCDA is offline
post #2268 of 6017 Old 01-31-2014, 09:43 AM
bkeeler10's Avatar
Quoted: 298 Post(s)
Liked: 176
You might try talking to the guys at Seymour. They have what are probably the two best AT screen out there. One line is available only through custom dealers and is quite expensive. However, their CenterStage XD screen is reasonable and you can buy directly from them.
If you're doing a fixed screen, they will tilt the screen material in the frame before mounting it to make it moire-proof. If you need a retractable, they will send you a sample to test with your projector at your viewing distance and screen size to see if moire will be a problem for you, although they claim that it is almost never a problem.
Anyway, check them out at www.seymourav.com. There is also a thread for owners on AVS.
bkeeler10 is offline
post #2269 of 6017 Old 01-31-2014, 10:37 AM
dlbeck's Avatar
Quoted: 509 Post(s)
Liked: 585
dlbeck is offline
post #2270 of 6017 Old 01-31-2014, 11:43 AM
willymo's Avatar
Quoted: 21 Post(s)
Liked: 42
Hey everybody. I'm experimenting with different sharpness and super resolution settings and have settled on sharpness 2, SR 3. Can you guys post your numbers? I'm wondering if I'm on the high side, but so far it looks great to me. My calibrator had it as 0 sharpness and SR1, which looks very detailed. The way I have it now looks more detailed, sharper IMO. Thanks!
willymo is offline
post #2271 of 6017 Old 01-31-2014, 12:10 PM
Quoted: 151 Post(s)
Liked: 171
http://www.projectorcentral.com/epson_6030ub_runco_x200i.htm?page=Calibrations
Here is Projector Central's calibrations for their 6030..........
post #2272 of 6017 Old 01-31-2014, 05:37 PM
mintchris's Avatar
Anyone have any idea if this projector would beat my JVC RS10 in contrast, black levels, etc?
mintchris is offline
post #2273 of 6017 Old 02-01-2014, 12:34 AM
usxplong's Avatar
Quoted: 104 Post(s)
Liked: 92
Originally Posted by bigly View Post
Hi Skylinestar,
How do you know if Red or Blue is not aligned?
All I get from alignment grids is gray lines (small boxes).
usxplong is offline
post #2274 of 6017 Old 02-01-2014, 03:25 AM
bigly's Avatar
That is probably a good thing as it sounds like you have good alignment already although they should be more white than grey when you have the pattern set to R/G/B.
If you go right up to the screen and see the blue or red lines separated from the green lines (or each other) that is misalignment.
At a certain distance your eyes will merge those lines back into a white line.
So if they are only slightly misaligned (indicated by a red or blue tinge/glow around the line) that is normal for 3 panel projectors and I probably wouldn't bother with the digital alignment feature.
If you can see separated colours at over half your viewing distance (I could see mine at actual viewing distance) the alignment is probably bad enough to give the LCD Align feature a go.
bigly is offline
post #2275 of 6017 Old 02-01-2014, 05:00 AM
Nuke61's Avatar
Quoted: 18 Post(s)
I had a similar thought when I first tried it, but it turned out that my projector had dead-on alignment from the factory -- although I'm seeing essentially white lines/boxes and not gray. Anyway, I moved the alignment by 8 pixels off from 0 and then I could see the color shift that means it's misaligned. I do this alignment from a few feet from the screen, not from the normal viewing distance.
Nuke61 is offline
post #2276 of 6017 Old 02-01-2014, 06:15 AM
lardo5150's Avatar
Can't remember if I asked this, but does anyone here who owns the 5030 have an elite screen or monoprice?
If you do, how are they with this projector?
My screen is going to be one or the other based on budget.
The elite will be the cinetension, and monoprice will also be the tensioned one.
lardo5150 is offline
post #2277 of 6017 Old 02-01-2014, 08:22 AM
KBS756's Avatar
My Epson 8100 ... seems to be starting to die ... Buzzing and overheating every time ... so I was considering upgrading, the 5030 is a bit of a stretch but was wondering how much of an upgrade this would be in terms of Overall picture quality, and how much better does an Epson 5030 seem compared to an Epson 8350?
KBS756 is offline
post #2278 of 6017 Old 02-01-2014, 01:47 PM
usxplong's Avatar
Quoted: 104 Post(s)
Liked: 92
Thanks. So far I don't see any B, R or G colors. So I think I am set.
Now why I see grayish instead of pure white?
Maybe my projector has only about 2 hours on it or my brightness is too low.
usxplong is offline
post #2279 of 6017 Old 02-01-2014, 01:49 PM
usxplong's Avatar
Quoted: 104 Post(s)
Liked: 92
Thanks for the tip. I moved my alignment by 8 pixels and I could see the colors too then I moved it back to 0 and no colors.
usxplong is offline
post #2280 of 6017 Old 02-01-2014, 01:52 PM
lapino's Avatar
Quoted: 73 Post(s)
Guys how is 3D with this projector? This is the only reason holding me off a bit to buy it. Been using a w1070 dlp before and absolutely loved the 3d especially for its lack of crosstalk. How does the Epson stack up?
lapino is offline
Epson 5030ub 2d 3d 1080p 3lcd Projector
