AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Digital Hi-End Projectors - $3,000+ USD MSRP (http://www.avsforum.com/forum/24-digital-hi-end-projectors-3-000-usd-msrp/)
-   -   Are there manual drop down projector mounts? (http://www.avsforum.com/forum/24-digital-hi-end-projectors-3-000-usd-msrp/1490940-there-manual-drop-down-projector-mounts.html)
malichai 09-16-2013 01:56 PM
I'm moving into a new house and my wife isn't keen on me having my projector hanging down 5 feet off the ground in the living room, so I'm wondering if anyone could point me to a projector mounting solution where I can pull the projector down when it is in use, and push it back up against the ceiling when it isn't in use. I've seen some pretty expensive electric lifts where your projector goes up into the ceiling, but I don't need anything that fancy, I just need to be able to pull it down and push it up.
Mike Garrett 09-16-2013 03:33 PM
You can do this with an adjustable drop tube, but you would want to add a cable, so that the projector can't fall. You would also have to manually, push the projector up and place the pin in the drop tube. If you have attic space above, you would be able to use a longer drop tube and shorten the outer tube. Then the inner tube is able to slide up into the attic space above. Did a system like this once before. You could even add a gas strut to pull the projector back up and you would have to pull the projector down, rather than push up. Also with this system, the projector would not be able to fall.
This would be something that you would have to design and build yourself. I would be happy to answer some questions.
malichai 09-17-2013 02:30 PM
I don't have any idea if there is attic space above. This is a bummer, I was hoping I was just missing some ready-made-product. I'm not remotely mechanical.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
