Projector and screen recommendation - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 101 Old 09-20-2013, 11:25 PM
rcohen's Avatar
Quoted: 1195 Post(s)
Liked: 505
I took a couple pictures of the HP 2.4 sample, without flash and with flash. There is indeed a fine cross-hatch pattern. The retroreflective glow is pretty wild.
rcohen is offline
post #92 of 101 Old 09-21-2013, 06:42 AM
Mike Garrett's Avatar
Quoted: 5403 Post(s)
Liked: 3437
Since this is now an HP screen thread, I will post this. Da-Lite is stopping production on the HCHP material.
mjgarrett100@gmail.com
Mike Garrett is online now
post #93 of 101 Old 09-21-2013, 08:37 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1007
Thanks Mike for this great investment tip. Once Da-lite discontinues anything with respect to HP, the discontinued product becomes a classic. Time to put a roll of this HCHP into the vault for cashing in later.
mark haflich is offline
post #94 of 101 Old 09-22-2013, 10:52 AM
samalmoe's Avatar
fwiw i have both hp screens..the 2.4 and the 2.8, one mounted behind the other, one electric that rolls up, other on the wall behind..one for scope format one for full size, both same width, 14 feet..I don't see any difference at all from 18 ft view distance in image quality..also you'd be hard pressed to see the brightness difference between the two. both look great and its the perfect material for my setup....still not bright enough for 3d but adequete..great gatsby was pretty good eye candy in 3d...ps..its projected from eye level so as good as it gets..sony 1000es projector..600hrs
samalmoe is offline
post #95 of 101 Old 09-26-2013, 08:17 AM - Thread Starter
camus2010's Avatar
OP here. Thank everyone for the helpful discussion!
I am now at the stage of deciding where to mount my (to-be-determined) projector because the contractor wants to reinforce the framing there. The room length is 18'. But there is a 2' passage in the back of the room I can utilize. So with some work, I can have a real 18' throw instead of 16'4". (The downside is that anyone taller than 6' cannot use that passage without head injury). Shall I opt for this, if that could substantially reduce the pincushion problem with a 65"x153" screen?
If I totally give up this A-lens/curved screen stuff and stick with zooming, I can invest all my budget of 10k in a good quality flat screen plus projector. Any recommendations for these? Again, the constraint is the screen size and lens memory is almost a sure thing. Thanks!
camus2010 is offline
post #96 of 101 Old 03-19-2014, 09:01 AM
eklan2's Avatar
i wonder if da lite is making fixed screen in portable mount, i am posting this question because i dont want to install the screen on the wall and this screen will be installed in our living room where there some ambient light coming from the right side and some window at the back right side. i hope somebody can help me on this problem.
thanks a lot.
eklan2 is offline
post #97 of 101 Old 03-19-2014, 09:55 AM
millerwill's Avatar
Quoted: 460 Post(s)
Liked: 256
thanks a lot.
Give them a call.
millerwill is offline
post #98 of 101 Old 03-19-2014, 04:24 PM
Liked: 3437
thanks a lot.
I don't think a stand that you attach to any fixed frame screen is going to be very practical for moving into and out of the room. You can look at something like these: http://www.dalite.com/products/product.php?pID=119&cID=11
http://www.dalite.com/products/product.php?cID=11&pID=302
post #99 of 101 Old 03-19-2014, 06:01 PM
eklan2's Avatar
thanks for the suggestion...however, i am worried of the kind of material used in their pre-fabricated portable vs fixed.
eklan2 is offline
post #100 of 101 Old 03-19-2014, 08:04 PM
Liked: 3437
Only thing I can come up with is the following item we sell.
http://www.chiefmfg.com/Series/LPAU
You would need to fasten a couple aluminum bars vertically to the back of any fixed frame screen you purchased. Then fasten the bars to the mount. Then you could roll the screen out of the way. If you want to discuss this idea some more, call me back.
post #101 of 101 Old 03-20-2014, 03:58 PM
eklan2's Avatar
how much are they? i think there are a lot of companies that specialize on this mount. just like the mount for the professional panel display.
eklan2 is offline
Panasonic Pt Ax200u 720p 3lcd Home Theater Projector
