Want JVC RS40, have Epson 8700UB, it is a good upgrade? - AVS Forum | Home Theater Discussions And Reviews
Old 09-23-2013, 08:52 AM - Thread Starter
vampat's Avatar
Quoted: 37 Post(s)
Can have a JVC-RS40 for 1500 $ with glasses and the lamp has 500 hour, i already have a epson 8700UB that I like very much...
What do you think, does it worth the change? Can sell my epson 1200 $ to a friend... so the RS-40 will cost 300 $.....
Projector: JVC DLA-RS55 | Screen: Carada Brilliant White 118 | Bluray: Oppo BDP-105D | Receiver: Arcam AVR-750
Speakers: Totem Hawk (front), Model 1 Signature (center) and Rainmaker (surround) | Subwoofer: Funk Audio 18.0C
Light Control: Lutron | Remote: Harmony Smart Control
vampat is offline
Old 09-23-2013, 03:25 PM
Charles R's Avatar
Liked: 536
Since no one else has given their two cents I will... if you are happy with the Epson I can't see swapping with the RS40's track record and less than stellar 3D. Now if I could demo it and decide then perhaps... other wise unless I was simply looking for a change I'd pass. This from someone who hasn't demoed a Epson I could live with and currently has a RS45.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
Old 09-23-2013, 08:17 PM
mbw23air's Avatar
Quoted: 154 Post(s)
Liked: 141
Do you know if the lamp on the RS40 is the 003 version with the metal flapper? I have a RS40 and I have seen a friend's 8700UB, the RS40 does have a better black level and better native contrast than the 8700UB. I can't see 3D but I have heard that the 3D is not that good on the RS40 but for 2D it puts out a very good image. So, it will be an improvement but how much might depend on the convergence and what version lamp you are getting(don't accept anything but version 003).
Mike
JVC RS600(Calibrated with Chromapure using an iD3), Stewart Cima Neve 2.35 115" diagonal screen, Lumagen Radiance XD, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Panasonic UB-900 UHD blu-Ray player, HDFury
mbw23air is offline
Old 09-23-2013, 08:25 PM
Seegs108's Avatar
Quoted: 4198 Post(s)
Liked: 2088
That's a great price. As far as 3D goes, it starts off pretty solid but gets progressively worse as the lamp ages. Unless you plan on doing quite a bit of 3D viewing or hate seeing any ghosting most would be generally happy with it's 3D performance. If you plan on watching a 3D movie a few times a year I really wouldn't worry about all the hubbub and criticisms about 3D performance on non-DLP projectors as, like I said, occasionally viewing will still yield more than acceptable results. If you're that concerned you can pick up a cheap $900 1080p (or cheaper 720p unit) for 3D usage.
The original lamps do dim fairly quickly so if you decide to buy a new one make sure it the revision 003 lamp as the brightness will not dim anywhere near as fast as revision 001 and 002 lamps for this projector. I think you'll love the performance of the RS40 over the Epson. The native contrast ratio of these units can be addicting and should look great overall over an LCD based unit like your Epson.
Seegs108 is offline
Old 09-23-2013, 09:22 PM
tigerfan33's Avatar
Quoted: 350 Post(s)
Liked: 168
I've had both. The RS40 is in another league.
Much brighter in best mode and better contrast.
tigerfan33 is offline
Jvc Dla Rs40u , Epson Home Cinema 8700 Ub Projector
