You should watch this - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 09-25-2013, 07:11 AM - Thread Starter
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
I strongly recommend you go the AVS Radio Show Forum, go to the Joe Kane on 4K thread, and watch the video at post 115. You will learn much there particularly about increases in dynamic range and HDMI 2.0. After a brief introduction in German, it is all in English and there is much information there most of it I bet YOU didn't know.
mark haflich is offline
post #2 of 18 Old 09-25-2013, 07:51 AM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 231
Good to listen and learn on 4K
blee0120 is offline
post #3 of 18 Old 09-25-2013, 08:04 AM - Thread Starter
Liked: 1010
Interesting on not viewing further away than 1.8 times the viewing height for 4K, the effects screens have in generating noise and the support for gray screens. I think JK would recommend his .6 JKP affinity for a screen only 2M wide as in the German lab at the end of the video, but mainly to keep the screen within illumination standards. Note they are using a Samsung SP-a800 or 900 which is only 1080p. A screen width of 2M would not be adequate to observe all that is going on as a result of 4K mastering although, and I have modified my previous position on this, some of the benefits of 4K source resolution will be apparent on smaller than 10ft wide screens.
post #4 of 18 Old 09-25-2013, 11:36 AM
stanger89's Avatar
Quoted: 2663 Post(s)
Liked: 1359
I haven't made it all the way through, but the first thing that jumps out at me is his comments about there being a (I can't remember the exact term he used) "huge" destruction of image quality scaling from 4096 to 3840, and determining this based of the results of artificially generated test patterns.
While that is true, it is completely not applicable to real world content. Single pixel wide alternating black bars are an "impossible" signal, it's essentially a square wave, and square waves have infinite bandwidth. Even if you were to approximate it, in order to sample a signal of 4096 columns of alternating bars, you would have to sample it about 14336 times (square waves have significant bandwidth up to about 7x the fundamental frequency, so 7*2048cycles).
These alternating pixel patterns completely ignore/violate the foundations of sampling theory, that being that the sampled signal is band limited to 1/2 the sampling frequency.
What I'd like to see, for/from all those folks who claim resampling is bad, is to take a picture of a physical test pattern with, say on a high end DSLR, render it down to say 2048, and then scale that test pattern to 1920, and compare the two and see just how much difference in sharpness there is. There will be a difference, 1920 can't be quite as sharp at 2048 (same with 3840 vs 4096) since it's lower resolution, but it shouldn't be a dramatic difference.
It's the same theory as resampling audio from 48kHz down to 44.1kHz, you can do that just fine without any major problems assuming it's done correctly.
stanger89 is online now
post #5 of 18 Old 09-25-2013, 11:40 AM - Thread Starter
Liked: 1010
And even if it were true, which I agree it wouldn't be if done correctly, the industry could just err pan and scan to eliminate 3 1/2 percent of the 4096 wide frame.
post #6 of 18 Old 09-25-2013, 02:36 PM
noah katz's Avatar
Quoted: 884 Post(s)
Liked: 304
Originally Posted by mark haflich View Post
You will learn much there particularly about increases in dynamic range...
What kind of dynamic range?
If it'sfrom bit depth, I don't see the need.
Noah
noah katz is offline
post #7 of 18 Old 09-25-2013, 03:29 PM
stanger89's Avatar
Liked: 1359
post #8 of 18 Old 09-25-2013, 04:26 PM
noah katz's Avatar
Quoted: 884 Post(s)
Liked: 304
Right, not a problem for me, so not a reason to be interested in UHD; my not-quite-perfect lasik job makes it so that I can't even fully resolve 1080P.
Noah
post #9 of 18 Old 09-25-2013, 05:05 PM - Thread Starter
Liked: 1010
This is not the response I would expect to get from an engineer of your caliber. Banding can mean other things and arise from other causes. But here we are talking about gray scale steps and the numerical limitation imposed by 8 bits. Of course any bit limitation has its own limitation on the number of steps but going to 10 bits increases the number of steps fourfold. I am sorry to learn about your eye problem. Perhaps some fixes can still be done. Here's hoping.
post #10 of 18 Old 09-25-2013, 06:20 PM
noah katz's Avatar
Quoted: 884 Post(s)
Liked: 304
Why, should I demand less banding when I don't see it now?
I went back but they said they got close enough that if they try again it may actually come out worse.
I test as having 30/20 or 20/30 (whichever one is worse than 20/20) but the odd thing is that with high contrast, like lit signs at night) I see two clear double images from my distance eye.
Noah
post #11 of 18 Old 09-25-2013, 06:48 PM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
A lot of banding is from the source interacting with how a device translates the colors I think.
Even having dealt with lots of graphics over the years (some professionally, some not), I don't know all the causes of banding. My guess is it will improve re-sampling, streaming, compression efficiencies, and some CMS interaction.
To some that doesn't mean much, to some others it might. To some devices, it might not fix much, to others it might?
Without the source being purer in its own form (hence still being susceptible to banding), perhaps there is still a lower chance of banding using a higher bit-rate with a bad source simply because the chances of 2 close colors being overlapped from the lack of precision in CMS errors would be lessened.
That said, I doubt this is going to have much visible effect on reference level content, unless it allows them to change the codec used and reduce the lossy-ness of some type of enhanced bluray (well an updated version) encoding (haven't seen too many superior formats on my own PJ in an objective and comparative manner, so who am I to argue).
Access HERE from this thread
coderguy is offline
post #12 of 18 Old 09-25-2013, 08:47 PM - Thread Starter
Liked: 1010
Any non uniformity in a color field, gray field, what ever is banding. Also there only 255 gray scale steps available with an 8 bit signal.As you blow the picture up, you can see steps in say facial tones where the color should blend. This is banding because there are not enough graduations to fool your cleaver sharp discriminating eyes. As the resolution increases and the dynamic range increases, banding worsens.
post #13 of 18 Old 09-25-2013, 08:57 PM
rcohen's Avatar
Quoted: 1219 Post(s)
Liked: 520
I haven't watched the video yet, but...
8 bits is not quite enough for normal displays with smooth gradients, and you will see subtle banding.
Add 1/2 bit of noise before quantization, and the banding is imperceptible.
Often, cameras already have that much noise present, and some sources (including 3D rendering) add noise for this reason.
Unfortunately, that kind of subtle high frequency noise gets lost with lossy compression, although it works great for uncompressed signals.
Aside from compression, the other big culprit is multiple stages of quantization. For example, take an 8 bit source, process it (i.e. color correction), then send out an 8 bit signal over HDMI, then process it again, then show it on an 8 bit display device, you get 3 stages of quantization. This will result in strong banding. The solution to this is to do all the processing in higher precision, and never quantize back to 8 bits. For example, take an 8 bit source, process, transmit in 10 bits, process, then display on a 10 bit device.
Another culprit is high dynamic range. The better the dynamic range, the more bits you need to keep up with the precision of your eyes. 8 bits starts to fall really short as displays get better.
rcohen is offline
post #14 of 18 Old 09-25-2013, 09:09 PM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
Thanks for the detailed info, this is the most complete explanation I have seen thus far.
That's true, but I don't usually notice banding artifacts on the better video devices of today unless streaming or watching older movies or poor transfers, but I suppose if I looked harder for them.
coderguy is offline
post #15 of 18 Old 09-25-2013, 09:47 PM - Thread Starter
Liked: 1010
post #16 of 18 Old 09-26-2013, 01:56 AM
madshi's Avatar
Quoted: 501 Post(s)
Liked: 474
Nothing new for me. Seems that even Joe doesn't know everything, though. Two complaints from my side:
(1) "720p is vastly superior to 1080i". Such nonsense, at least for movies. IVTC converts 1080i60 to perfect lossless 1080p24. You can even encode progressively to 24p and just flag the video stream to 60i. Some USA broadcasts and DVDs are doing that. It's called "soft-telecine". Actually that's exactly what HD DVD did.
(2) Upscaling of 1080p to 2160p "should be an easy conversion to do well". The usual linear scaling algorithms which have been used for decades (Bilinear, Bicubic, Lanczos, Sinc etc) do not care whether the scaling factor is a cardinal number of a fractional number. A scaling factor of exacty 2.0x does make it possible to use non-linear scaling algorithms (and both Sony and JVC are doing that), but those algorithms can be mathematically quite complex. For example, I believe Sony has a database of learned patterns ("Reality Creation") which they use to perform the upscaling. That's not an "easy" algorithm to apply. In the HTPC world we have NNEDI3 which is using a similar technique and it's quite slow and involves a lot of math. But it does give very good results.
madshi is offline
post #17 of 18 Old 09-26-2013, 04:27 AM - Thread Starter
Liked: 1010
Joe often is wrong. He doesn't understand every thing about video and has often made incorrect statement and drawn incorrect conclusions based on inadequate knowledge. But he also often is right and has done much good for the sport. His primary fault and he indeed has many, is that he feels he is intellectually superior and has far more knowledge than the audience he is addressing. He justifies using incorrect terms because he feels his audience wouldn't understand the use of the correct term. If a question or statement contradicts his position he tends to ignore it and answer some other question. But he would absolutely suck if he tried to be a politician. But we should be glad we have him.
post #18 of 18 Old 09-26-2013, 08:11 AM
rcohen's Avatar
Liked: 520
GPU acceleration has opened the door to doing much more sophisticated scaling algorithms in real time. One example of sophisticated algorithms are ones that analyze the image, identify the angles of edges, and maintain a perfectly sharp, anti-aliased edge in that direction. Old-style fixed filter kernels are non-adaptive to the image, and they always apply the same kernel in all directions. Non-integer scaling can be done whether using fixed or variable kernels. You just have to recompute the kernel, or use filtered sampling from a precomputed kernel. The big change with a non-aligned filter is that you lose the ability to do separable filtering on each axis. With GPUs, all these things are possible.
rcohen is offline
Samsung Sp A800b Dlp Projector 1080p
