Panasonic PT-AE3000 problem with brightness - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-25-2013, 08:52 AM - Thread Starter
Gvidosha's Avatar
Hello!
I'm am new at this forum. Please help.
I've purchased occasionally second hand PJ Panasonic PT-AE3000.
Picture is absolutely pale - not enough brightness. I've replaced the bulb, but this didn't help.
I also have PT-AE2000 that I use for the last year,and the picture there is much better.
What can it be? May be I need some kind of calibration?
Best regards!
Gvidosha is offline
post #2 of 3 Old 09-25-2013, 05:55 PM
kendo70433's Avatar
Well, if you bought it second hand, it should be calibrated.
In the mean time, what picture mode is it in, and have you tried other modes?
Also, look at the picture controls. Maybe brightness or contrast is set too low.
Good luck. It's a great projector.
kendo70433 is offline
post #3 of 3 Old 09-26-2013, 02:12 AM - Thread Starter
Gvidosha's Avatar
Thank you for the reply.
But I've already tried to change contrast/brightness levels of course. And changed types of picture.
In any case - the picture is very poor. I've changed the bulb. In comparison with AE2000 the picture is very dark.
Gvidosha is offline
Pt Ae3000u Lcd 1080p Proj 60k 1 1600 Lumens Hdmi Component Svid
