What ceiling mount should be used for a Sony VW85? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-26-2013, 10:43 AM - Thread Starter
KMR
KMR's Avatar
Quoted: 14 Post(s)
A friend of mine bought a Sony VW85, and he wants to ceiling mount it. Is there a model that is recommended for a projector that size?
KMR is offline
post #2 of 2 Old 09-26-2013, 01:12 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
A Chief RPA020 or the key locking faster quick mount RPMA020. He will need a pole of the right length. A 1 1/2 in diameter NT threaded piece of pipe available at Home Depot. Also a ceiling plate for attaching to the ceiling and to screw the pipe into to. A 1 1/2 inch diameter NT ceiling flange at Home Depot will work fine or you can get a pretty one from Chief if the pole length will allow visability of the flange. AVS sells the mount. Call me if you want to discuss what he needs and then you can order from AVS. They have great pricing.
mark haflich is offline
Sony Vpl Vw85
