Official Sony VPL-VW500ES / VW600ES 4K Projector Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 394Likes
post #271 of 6172 Old 11-16-2013, 05:11 PM
Nyal Mellor's Avatar
Quoted: 435 Post(s)
Liked: 312
Originally Posted by roxiedog13 View Post
If you are referring to the 500/600ES it was calibrated at 1350 . I had the HW50ES also rated 1700 lumens and the difference is huge you can really notice it. Seems to be way more lumens than the difference should appear to be.
I have a 120" diagonal 2.35:1 1.37 gain screen plenty bright at 50% brightness. Others may have experience with a larger unity screen and can chime in.
Where did u get the 1350 from? Thanks!
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is online now
post #272 of 6172 Old 11-16-2013, 05:31 PM
hwoarang's Avatar
Thanks Roxiedog. So this chip you're talking about will only appear in newer models? There's no way to upgrade correct?
I'm really excited to hear your feedback on the picture quality but it leaves me wondering what next year will hold. In worried that I'm one year out from having a better future "aware" projector, especially at this price point.
I'm so torn. Do I get the hw55 and a great anamorphic screen and a panamorph A - lens, then sell it, keep the screen, and get a 4k projector in 2-3 years when theyre more comprehensive and there is 4k content? Would love some advice from anyone willing to chine in. I have to order "something" next week....
As far as I understand you are correct in that it will not stretch 4k or 3D for anamorphic use. Lumagen are suppose to be making a processor that will do both, available some time very soon, January as I understand. . I've heard rumors the PS4 may be able to do the 3D, not absolutely sure though.
I was adamant that the 500/600ES PJ is not worth the investment without 4K, mostly on the feedback and rants through forums all over the internet. Now that I have witnessed the PJ myself I have to say, without a doubt , the image this PJ will display on ANY content blows me away. Like I said, I'm now eating my words, and very , very
hwoarang is offline
post #273 of 6172 Old 11-16-2013, 05:47 PM
audioguy's Avatar
Quoted: 1917 Post(s)
Liked: 1240
There is ALWAYS a reason to wait. A year from now, you will be able to get a 4K projector (probably another Sony) for less than this one. And a year after that it will be even cheaper (and probably have more features). And there may or may not be a reasonable amount of 4K content.
When we are talking about spending this amount of money for a "TV on steroids", it is difficult to use "logic".
I decided I wanted it and as much as I have loved my 3 different JVC projectors pulled the trigger.
hwoarang likes this.
audioguy is offline
post #274 of 6172 Old 11-16-2013, 06:30 PM
Quoted: 435 Post(s)
Liked: 312
I'm not sure I would buy the Sony based on it's ability to do 4K as who knows what that will look like when it arrives. Resolution is only one part of the equation, there are other things that this Sony may not be able to do such as higher color bit depth, expanded color space, etc that may well be coming with 4K. I would buy it because of it's abilities as a projector - brightness, image quality, black levels, installation flexibility etc.
post #275 of 6172 Old 11-16-2013, 06:56 PM
roxiedog13's Avatar
Quoted: 1271 Post(s)
Liked: 539
cine4 in Germany did the testing, try a Google search , you will need Googe translate to read as it is written in German.
Dedicated Theater: Sony VPL VW 675ESB & JVC X950RU/RS600 , Panamorph DC1 Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 132" diagonal curved 36FT radius, Anthem 1120 AVR , 7.2.4 Atmos, Paradigm Monitor 11 fronts, Monitor 3 Center, Monitor V7 Rear, SA-ADP In-wall Surround, Niles DS-7 In-Ceiling, Subwoofers: (4000 watts peak) Klipsch RW-12 + SVS PC13-Ultra
roxiedog13 is offline
post #276 of 6172 Old 11-16-2013, 07:50 PM
hwoarang's Avatar
Thanks lads. All great points. I like to try and find. A good balance between where the tech is and what's projected. My main Tvs are the Sony XBR960 and XBR2. Both have stood the test of time and I haven't had to worry about tech until now, and that's only because I want bigger and more cinematic.
So I'm guessing you guys are enjoy it now, worry about the rest later, which is wicked, but what do you plan on doing when 4k is out and you want to go anamorphic, do you just sell and upgrade? It doesn't look as though there are a lot of options....
hwoarang is offline
post #277 of 6172 Old 11-16-2013, 08:01 PM
Mike Garrett's Avatar
Quoted: 5571 Post(s)
Liked: 3551
So when 4k content starts rolling in and youre committed to a 2:35 setup, zooming, is your only option with this projector, correct?
Can anyone comment on the performance of 2:35 and zoom as it seems vertical stretch/ A-lens is not a good long term investment (as it can't do 3d or 4k)?
I am pretty sure the 500/600 can do the vertical stretch in 3D 1080P. It just can't do the stretch in 4K.
mjgarrett100@gmail.com
Mike Garrett is offline
post #278 of 6172 Old 11-16-2013, 08:05 PM
Liked: 3551
Originally Posted by blee0120 View Post
I actually use a 1.0 gain screen, but I have used a HP that I rarely seen the screen material. You always make negative comments about the HP screen. I know you think your screen is the best and it is the top unity/reference screen, but a HP screen will work better in most setup than your Snomatt.
The vast majority of front projection setups are ceiling mounted.
post #279 of 6172 Old 11-16-2013, 08:36 PM
Liked: 3551
This review: http://www.projection-homecinema.fr/2013/11/16/test-sony-vpl-vw500es-le-futur-de-la-videoprojection-est-la/ got 1,354 in low lamp iris fully open and 1,533 in high lamp, iris fully open.
post #280 of 6172 Old 11-16-2013, 08:40 PM
Liked: 3551
You plan on buying a device that will perform the vertical stretch in 4K. Lumagen has been working on such a device and there is another company that is supposed to be working on a device for this. smile.gif
post #281 of 6172 Old 11-16-2013, 09:40 PM
hwoarang's Avatar
I see. This is an external unit that adds on but is not currently available? Thanks again.
hwoarang is offline
post #282 of 6172 Old 11-16-2013, 10:04 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
Lumagen does not yet have a processor which can accept UHD or 4K sources, process them, and output them. It does have processor that can take 1080 up to 72 or so in and process them asnd output them as most anything including UHD and 4K. When the HDMI 2.0 input at the high 18 speed become available, we can expect a new Lumagen 4K processor and this will be able to stretch the actual UHD or 4K input vertically.
mark haflich is offline
post #283 of 6172 Old 11-16-2013, 10:26 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
I meant to say work better in more setups than the Snomatt, only because you need a true bat cave and most are not.
blee0120 is online now
post #284 of 6172 Old 11-17-2013, 12:31 AM
Liked: 1010
A reference gain of one is absolutely a bad choice for most set ups. You need a non reflective bat cave and a screen limited to about 8 or 9 ft in width for a projector of the brightness of the Sony 1000ES or you need a lot more lumens.
post #285 of 6172 Old 11-17-2013, 04:08 AM
soupdragon's Avatar
Quoted: 12 Post(s)
Liked: 36
I think thats a typo as he also says 1964 high lamp.....
soupdragon is offline
post #286 of 6172 Old 11-17-2013, 04:52 AM
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
Absolutly not, this a the maximum Brigthess value I was able to get with my VW500ES, of course not at D65.
Visit the new pjhc.fr forum here : http://www.projection-homecinema.fr/forum/
kraine is offline
post #287 of 6172 Old 11-17-2013, 06:47 AM
audioguy's Avatar
Liked: 1240
I hope your wrong.
My screen width is 10 feet but am in a "bat cave", and the "quoted" gain is 1.2 (Seymour XD screen material). I was not totally dissatisfied with the brightness my JVC RS55 on a Stewart 1.3 StudioTec and the Sony (600ES) is a lot brighter so, I'm quite sure I will be more than pleased. And yes I recognize that these are not unity gain screens.
I guess it is all in the eyes of the beholder !!
audioguy is offline
post #288 of 6172 Old 11-17-2013, 06:49 AM
Liked: 3551
I hope your wrong.
The Center Stage has been measured at 0.98 gain.
post #289 of 6172 Old 11-17-2013, 06:53 AM
Liked: 3551
it would have to be three typos then. Sony listed 1,511 in D65 high lamp. He got 1,533. That does not sound like a typo. The 1,964 would have to be dynamic mode.
Added
What are you feeding 16,800 watts to? What is your sub system?
post #290 of 6172 Old 11-17-2013, 06:54 AM
audioguy's Avatar
Liked: 1240
So what's the measured gain of the StudioTec? And what AT screen is available that has a much higher gain (that doesn't cost more than the projector)?
audioguy is offline
post #291 of 6172 Old 11-17-2013, 07:02 AM
peperounet's Avatar
Hello.
Kraine in his review of the 500 ( http://www.projection-homecinema.fr/2013/11/16/test-sony-vpl-vw500es-le-futur-de-la-videoprojection-est-la/) says that Motion flow will only work with 1080p and not with 4K.
For example: upscaling made by the Oppo 103D
Does someone knows if it will be corrected later with a new firmware.
peperounet is offline
post #292 of 6172 Old 11-17-2013, 07:04 AM
Liked: 3551
ST130 was measured at 1.27 gain. If you want higher gains and AT, there is only one game in town and that is Stewart.
post #293 of 6172 Old 11-17-2013, 07:06 AM
Liked: 3551
Originally Posted by peperounet View Post
Hello.
I suspect the problem is the same as for vertical stretch in 4K, not enough processing power.
post #294 of 6172 Old 11-17-2013, 07:17 AM
W.Mayer's Avatar
Quoted: 220 Post(s)
Liked: 264
a good dealer told me today that he measure in the 2000 center lumen range.
he know everything about how to adjust the pr. with the lens and all other things to have the most lumen out the unit can do at good color.
this new lens in the 500/600 may even drop more than the 30% difference between min. and max. zoom position the vw 1000 have.
as this new optic and the new light System are likely offers a bit more lumen per watt i think the native cr will be a bit lower than the
vw 1000 have and the lumen will be almost about the same as the vw 1000.
W.Mayer is offline
post #295 of 6172 Old 11-17-2013, 08:19 AM
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
So that's about a 120" diagonal 16:9 or a 130" diagonal 2.40 (using A lens).....by my math (could be wrong) that's ~30 fl
What is your target foot lambert measurement?
Thx
Here is my build thread:
---->Like a Boss Theater Build<----
Yzfbossman is offline
post #296 of 6172 Old 11-17-2013, 08:44 AM
audioguy's Avatar
Liked: 1240
Four Seaton SubMersive HP's (9600 watts); 3 Seaton Catalysts 12C's (6000 watts) and 4 Seaton Sparks (1200 watts). I think that adds up to 16,800 watts !
I have become a big fan of active high powered speakers. Great for 2 channel, incredible for home theater!!
audioguy is offline
post #297 of 6172 Old 11-17-2013, 10:43 AM
tangcoma's Avatar
Quoted: 33 Post(s)
Liked: 25
Hi , I've got my 500Es , but I find that the crosstalk of the subtitle is very noticeable ! Compare with my last JVC X75 , the X75 produce much less crosstalk on subtitle ! Here is the photo I took from the left len of the 3D glasses , u can see a obvious ghost there , this is almost unwatchable ! Any help ?
tangcoma is offline
post #298 of 6172 Old 11-17-2013, 10:54 AM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
I hope your wrong.
For a 10ft screen with the XD material, you need 900 lumens to get 16ftL. In a batcave, you really don't need more. The Sony is about double that brightness.
post #299 of 6172 Old 11-17-2013, 11:07 AM
coolgeek's Avatar
Quoted: 616 Post(s)
Liked: 278
Which stewart at screen has the highest gain?
coolgeek is offline
post #300 of 6172 Old 11-17-2013, 11:25 AM
Liked: 1010
If you rule out a screen just for 3D, the highest gain is 2.8 and that is a screen which retain polarization at the cost of some 2D performance. A good solution if you need passive 3D and decent 2D performance from one screen
In reality, the highest Stewart gain screen is Ultramat 2.0 which when perforate will get you about 1.9 gain, stewart has a new 1.7 gain, a 1.5 gain, a 1.3 gain, 1.1 gain, 1.0 gain, and lower gain gray screens going down to about .6.
Sony Vpl Vw500es , Sony Vpl Vw1000es Projector , Sony Fmp X1 4k Ultra Hd Media Player
