Official Sony VPL-VW500ES / VW600ES 4K Projector Thread - Page 109 - AVS Forum | Home Theater Discussions And Reviews
 389Likes
Old 06-23-2014, 07:22 PM
mark haflich's Avatar
Quoted: 1416 Post(s)
Liked: 1004
Sony claims a wider color space for its mastered in 4K 1090 Bluerays. They claim to be using xv color which uses the same primaries as rec 709 but adds more colors by using 0 to 15 and 236-255 which are normally not used. Something like that. But if they are actually using xv color the bluray player must be able to play it and xv must be switched on. I have no clue whether the Oppo has this.
mark haflich is offline
Old 06-23-2014, 07:51 PM
Seegs108's Avatar
Quoted: 3404 Post(s)
Liked: 1424
Originally Posted by mark haflich View Post
Sony claims a wider color space for its mastered in 4K 1090 Bluerays. They claim to be using xv color which uses the same primaries as rec 709 but adds more colors by using 0 to 15 and 236-255 which are normally not used. Something like that. Buy if they are actually using xv color the bluray player must be able to play it and xv must be switched on. I have no clue whether the oppo has this.u
I think XV color has the same D65 white point but offers more saturation because the triangle is wider. I'm not sure about the RGB levels and if they come into play.
CRM likes this.
Seegs108 is online now
Old 06-24-2014, 12:27 AM
Liked: 1004
You are correct, the gray scale color temperature would be the same. One calibrates for it by calibrating to rec 709.
Old 06-26-2014, 07:49 PM
Tnedator's Avatar
Quoted: 319 Post(s)
Liked: 119
Anyone using a 132" wide 2.35 screen with the 600? I'm going to have a 11' wide screen (almost certainly Studiotek 130 perfed), and am wondering if the 600 is going to be bright enough using zoom mode vs. an anamorphic lens. One note, I will be near the end of the throw limit, as the lens will be about 22' from the screen (soon to be newly constructed Erskine designed/built HT).
One of the ways to help talk myself into the 600 is not having the need for the anamorphic lens (saving $4-10k depending on make, model, sled, etc), but at least based on the calculator at projector central, it's showing I would be down to about 10 fl using the zoom method on a 1.2 gain screen (left calculator set to 16:9 and changed the width to 132", which is what would happen if I used zoom to fill 2.35 screen). It is showing that it would be 15fl when I'm masked down to 1.78 (115" diagonal). 15fl is fine, 10fl seems a bit weak (even though for years I was using an IN76 in moderately light controlled living room and when I finally got a light meter, I think I was down around 8fl with a new bulb and it always seemed "bright" when new).
I know that calculator doesn't always get it right, so I'm curious if anyone else is using a similar size screen/throw distance while using zoom vs. anamorphic.
My other options are to go with an anamorphic lens and remove it when playing any native 4k content.
Or, possibly get a cheaper projector (Epson 6030 or similar) with an anamorphic lens as a placeholder for a few years until the 4k market settles out.
Tnedator is offline
Old 06-27-2014, 06:56 AM
AVS Club Gold
Mike Garrett's Avatar
Quoted: 4348 Post(s)
Liked: 2634
The calculator that you are using is wrong. A 115" diagonal is around 100" x 57" which is 39.58SF. L (lumens) x 1.3/39.58SF=15FL L=457. So anybody believe the VW600ES in high lamp only has 457 lumens? On the 132" wide 2.35, 1.3 gain screen, I would guess with a new lamp you would be around 26FL and low lamp would be around 18FL. You should be fine. Billy, for the size screen you are talking about, the 600 would be a better choice over what I priced to you earlier. I really like my 600 and more lumens was one of the main reasons, I went with it. If you would like to discuss this more in depth, give me a call.
mike@avscience.com
Sony, JVC, Epson, Denon, Marantz, Yamaha, Onkyo, Parasound, Triad, Atlantic Tech, M&K, RBH, SVS, Polk, Stewart, Seymour, Falcon, DNP, SI, Screen Excellence, Carada, MicroLite & more.
Mike Garrett is offline
Old 06-27-2014, 08:26 AM
Tnedator's Avatar
Quoted: 319 Post(s)
Liked: 119
Mike,
Thanks, I was just talking this through with a friend this morning, and was telling him that I thought the issue might be projector central using a "rule of thumb" post calibration factor that must be much lower than the 1100-1300 lumens post calibration that I'm seeing in most reviews.
I plan to give you a call soon to talk this through. I'm also trying to figure out my timing for now vs. waiting until after Cedia. While I think zoom works, I hate the fact that an anamorph lens can't be used with 4k material for going forward.
Tnedator is offline
Old 06-27-2014, 08:32 AM
AVS Club Gold
Liked: 2634
Mike,
Once a video processor is available for 4K, then that problem is solved. I use an A-lens with my 600. I am just waiting on a new Lumagen. Since this is a scaling function, a Lumagen will do a better with vertical stretch than a projector.
mike@avscience.com
Old 06-27-2014, 08:58 AM
Tnedator's Avatar
Quoted: 319 Post(s)
Liked: 119
Yea, trying to do everything on the cheap (although I guess that went out the window since I'm having Dennis/Steve build my theater), I liked the idea of the onboard vertical stretch (especially since the reviews of the onboard 600 scaler seem great). But, you are right, going with an outboard scaler isn't a major issue.
Tnedator is offline
Old 06-27-2014, 09:21 AM
Home Theater Lover!
Craig Peer's Avatar
Quoted: 2344 Post(s)
Liked: 2131
The Projector Central calculator, while apparently fine for throw distance / mounting info, is notoriously bad with the lumen calculations.
AV Science, Inc. Direct (585) 671-2972 craig@avscience.com www.avscience.com Like us on Facebook
Home theater equipment sales and advice. Call to see the JVC RS600 in Northern California
My theater pics - http://www.avsforum.com/photopost/sh...hp?cat=2386514
Craig Peer is offline
Old 06-27-2014, 10:07 AM
billqs's Avatar
Quoted: 284 Post(s)
Liked: 167
Just got my 500ES in and noticed that to zoom in the right size for the picture from the source I had a good bit of projector generated black bleeding out from the screen. Is that just the normal difference between the native chip's 4096 width versus the 3840 width that UHD is using?
billqs is offline
Old 06-27-2014, 11:01 AM
BrolicBeast's Avatar
Quoted: 987 Post(s)
Liked: 936
The native aspect ratio of Sony's 4k offerings are a tad wider than 16:9. You're seeing the unused sections of the native aspect ratio.
BrolicBeast is online now
Old 06-27-2014, 07:42 PM
jlohojo7's Avatar
Quoted: 27 Post(s)
So I have this problem with my 600. The blue is shifted about 20% off of where it should be. There is a blue outline around everything, and the lettering on the menu is a yellow tint instead of white. Also its not 100% focused. I called sony and they had me ship it back for them to look at it but I was wondering what you guys thought. They think its a factory defect in the PJ. Also had an ISF calibrator I know look at it and he thought something was wrong also. Like I said Ive already sent it back but just curios to see what you guys thought.
jlohojo7 is offline
Old 06-27-2014, 08:55 PM
billqs's Avatar
Quoted: 284 Post(s)
Liked: 167
It obviously had really bad convergence. I've heard of "golden samples" before sounds like you ended up with a lead sample. I'm glad Sony is looking at it.
billqs is offline
Old 06-27-2014, 09:13 PM
jlohojo7's Avatar
Quoted: 27 Post(s)
well thats special. How do I always end up being so lucky? I would like for them to just replace it bc I never really have liked the idea of any kind of broken electronics equipment being repaired. Especially something of that magnitude. However im sure they will just patch it up and send it back.
jlohojo7 is offline
Old 06-28-2014, 08:14 AM
magicj1's Avatar
Quoted: 67 Post(s)
Anyone using the 'Remote' input RS232 to control the Sony?
magicj1 is offline
Old 06-28-2014, 08:19 AM
Liked: 1004
It hard to speculate as to why. Maybe its an issue of clean living or not repainting your mother's closet enough.
Old 06-29-2014, 08:03 AM
Tnedator's Avatar
Quoted: 319 Post(s)
Liked: 119
I have a question for those of you using the zoom method to change between 1.78/1.85 to 2.35/2.40 on a CIH screen.
Let's take a 10' wide 2.37 screen. When you zoom up from 1.78 to fill the 2.37 screen, the "letter boxed" area of the screen will fall off the top/bottom of the screen. On a 10' wide screen, that would be about 8.5" above and below the screen material. So, that would be on the masking and then whatever objects/material you have 5" or so above/below your screen.
How noticeable is the letterboxed area being displayed outside the screen surface area? If you have black fabric (screen mounted in screen wall with black GOM AT fabric, should I expect it to just disappear or am I going to notice some light spill from the "letterboxed" area being displayed outside the screen area?
Tnedator is offline
Old 06-29-2014, 08:21 AM
Liked: 1004
It should pretty much not be noticeable,
Old 06-29-2014, 12:26 PM
AVS Club Gold
Liked: 2634
With black GOM, you will not see it. It is a non issue.
mike@avscience.com
Old 06-29-2014, 04:33 PM
Tnedator's Avatar
Quoted: 319 Post(s)
Liked: 119
That's what I figured, but forgot to ask you when talking on the phone the other day. I'm assuming as long as I don't have anything glossy or reflective between the Stewart masking and black GOM than I'll be ok.
Tnedator is offline
Old 06-29-2014, 07:02 PM
AVS Club Gold
Liked: 2634
Yes, correct.
mike@avscience.com
Old 06-30-2014, 09:03 AM
billqs's Avatar
Quoted: 284 Post(s)
Liked: 167
What's the last date to get in on the preorder price for the new Sony server FMP-x10?
billqs is offline
Old 06-30-2014, 06:07 PM
Quoted: 12 Post(s)
Liked: 0
Questions
I was hoping to get a little advice on my upcoming purchase. I currently have a Sony VW60 1080 projector and a 110 inch Stewart Firehawk screen. I want to upgrade to the Sony VW600ES projector. I was wondering if I purchased the 600 if my current screen would do it justice? Anyone have any thoughts on this? I would really appreciate any advice. Thanks!
ralphcowaniii is offline
Old 06-30-2014, 06:37 PM
Liked: 1004
Your question is unanswerable without further information. Your screen is only 30 sq ft in area. The gain of your screen is about 1.25. With the lumens power of your coming projector, you do not need any positive gain. A gain of 1.0 will be more than enough for a great 2D picture. For 3D, a gain of 1.0 would be adequate but ideally the picture could be made better by having a positive gain screen. The main issues are what is your throw distance, what is the ambient light situation, and what are your screen surrounding walls, floor and ceiling like? Color and reflectivity? More after you answer my questions..
Old 06-30-2014, 07:35 PM
Quoted: 12 Post(s)
Liked: 0
Questions
Old 06-30-2014, 07:42 PM
Quoted: 12 Post(s)
Liked: 0
Thanks for the response Mark. Sorry I was so vague. Sort of a newbie here. My throw distance (I assume how far back i sit from the screen) is about 14 feet. My walls are light tan (not very reflective), room gets very dark and the ceiling is white. The projector is a ceiling mount. Thanks!
Old 06-30-2014, 07:45 PM
Quoted: 12 Post(s)
Liked: 0
July 15th
Old 06-30-2014, 07:56 PM
AVS Club Gold
gdfein's Avatar
Originally Posted by ralphcowaniii View Post
July 15th
I thought July 15th was the ship date, no?
gdfein is offline
Old 06-30-2014, 08:06 PM
Quoted: 12 Post(s)
Liked: 0
My understanding from someone I know that deals with Sony on a wholesale level said it was 7/15. Im hoping that is correct.
Old 07-01-2014, 04:44 AM
mankite's Avatar
Quoted: 72 Post(s)
Liked: 60
Man the screw holes used to mount projector on the ceiling aren't very deep. My Jvc holds a lot of screw. The Sony is like less then 1/2 inch. What ceiling mounts are you guys using?
mankite is offline
Sony Vpl Vw500es , Sony Vpl Vw1000es Projector , Sony Fmp X1 4k Ultra Hd Media Player
