Official Sony VPL-VW500ES / VW600ES 4K Projector Thread - Page 122 - AVS Forum
post #3631 of 3651 Old 09-25-2014, 10:22 PM
wse
wse's Avatar
Quoted: 418 Post(s)
Liked: 339
Originally Posted by Craig Peer View Post
Yes, but on the other hand, the VW600 has one of the brightest and best pictures I've seen, with Blu Rays, and HDTV - both of which will be around for many years. So I'll be enjoying mine for the next 4 or 5 years while the whole 4K UHD mess sorts itself out. If it ever does. Then I can see if I need to replace it. Or not.
If I could get one at dealer cost I would buy one but paying $15,000 when it is sold in Japan for less than $7,000 is a problem for me !
My humble Cinema
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
wse is offline
post #3632 of 3651 Old 09-25-2014, 10:47 PM
magicj1's Avatar
Quoted: 30 Post(s)
I read this then looked at your signature. You have a sweet set up so I'm surprised by your comments 'although I know what you mean'
magicj1 is offline
post #3633 of 3651 Old 09-29-2014, 11:38 AM
M_Coupe's Avatar
Trying to dig up official/reputable confirmation of an upcoming firmware update that will address input lag (and whatever else). Where is this information coming from? As far as I can tell, various forum members are bringing it up, but nothing from AVS, Sony, etc... which to me just leaves it as your typical internet hearsay... "I heard from a guy whose best friend interned in sony's call center" type stuff Dare I get my hopes up?
etc
M_Coupe is offline
post #3634 of 3651 Old 09-29-2014, 11:39 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 373 Post(s)
Liked: 418
etc
We were told at CEDIA that an update was coming.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me:
Brands we sell:
Call for B-stock projectors
Stewart, Seymour, SE, SI, Falcon & many more.
RBH, Martin Logan, Triad, Atlantic Technology, MK Sound, BG Radia, SVS & Def Tech.
AV Science Sales 5 is online now
post #3635 of 3651 Old 09-29-2014, 11:51 AM
M_Coupe's Avatar
Thanks Mike! I couldn't dig that up through the searches I did. Any indication of the time-frame?
M_Coupe is offline
post #3636 of 3651 Old 09-29-2014, 01:05 PM
antorsae's Avatar
It's also mentioned here:
http://www.cine4home.de/tests/projek...vw300_test.htm
(search for "input lag")
OOO CRT Blend powered OOO
antorsae is offline
post #3637 of 3651 Old 09-29-2014, 04:45 PM
RearProjection1292's Avatar
Home cinema manufacturers have been rushing to release new AV receivers with 4K capable HDMIs, yet only one AVR brand has implemented HDCP 2.2 and that's Onkyo. Five of its new receivers, plus one processor, offer the copy protection, albeit on a single HDMI (STB/DVR).
The new Sony ZA3000ES has 2 HDMI 2.2 inputs and 2 HDMI 2.2 outputs.
Think of What You Have Instead of What You Want
RearProjection1292 is offline
post #3638 of 3651 Old 09-29-2014, 04:50 PM
Manni01's Avatar
Quoted: 167 Post(s)
Liked: 144
Onkyo has HDCP 2.2 (only on one input and out output) but it only supports HDMI 2.0 level B (same bandwidth as HDMI 1.4, 10Gb/s limited to 4K 60p at 4:2:0 8 bits).
The others manufacturers don't have HDCP 2.2 but they support HDMI 2.0 level A (full 18Gb/s bandwidth).
Do you mean that the Sony ZA3000ES has both HDMI 2.0 level A and HDCP 2.2 on 2 inputs/outputs?
Manni01 is online now
post #3639 of 3651 Old 09-29-2014, 04:54 PM
mark haflich's Avatar
Quoted: 446 Post(s)
Liked: 489
But it doesn't have Atmos.
Mark Haflich
call me at: 240 876 2536
mark haflich is online now
post #3640 of 3651 Old 09-29-2014, 05:02 PM
Manni01's Avatar
Quoted: 167 Post(s)
Liked: 144
Thanks, I won't waste time looking it up then
post #3641 of 3651 Old 09-29-2014, 06:38 PM
I think if it has 2.2 it doesn't need 2.0. I would think its backwards compatible. I am waiting on Sony to return my call regarding the 2.2 specs. Getting more sources to input 2 my 600 ES via AV switching is my immediate goal. Currently outputting 4096x2160/60 to the 600ES from my HTCP with a NVIDIA 760 graphic card
post #3642 of 3651 Old 09-29-2014, 09:09 PM
Quoted: 446 Post(s)
Liked: 489
Don't hold your breadth. Sony after the last layoff is slow to respond.
I do believe you are a little confused about what is being discussed here. 2.2 means HDCP 2.2. That means the receiver will act as a HDCP 2.2 relayer. It will pass HDCP 2.2 as well as all earlier HDCP versions. Sony 4K content is protected by HDCP 2.2 and the display must be HDCP 2.2 compliant protected and all things in the video chain must be able to relay or send HDCP 2.2 if the source material at 4K is protected by HDCP 2.2.
HDMI is something else. Its is a method of transmission and it is bandwidth limited. HDMI 2.0 technically has a bandwidth of 18 GBS. HDMI chips need to accept 18 GBS to be fully HDMI 2.0 compliant. We nerds around here, but no one else,stuck up techies like us have our own idiotic labeling to save posting bandwidth.. We call chips with 18 GBS bandwidth HDMI 2.0 A. Most stuff out there because of chip unavailability use chips with only 10.2 GBS bandwidth. This can be remembered because it rhymes with Tippecanoe and Tyler Too. Our UK friend, Manni01 is sloppy. He cites 10.0 GBS when as a video nerd he should say 10.2. But he is English and can be forgiven for not knowing this old political slogan. We call these 10,2 chips HDMI 2.0 B. This bandwidth is used on say the Sony 4K projectors and because of the limited bandwidth will as far as 4K or UHD signals are concerned only pass 60 fps info at 8 bits with only chroma subsampling at 4:2:0.
This is deemed as low quality by us and pretty much all video nerds in the free or other worlds. We want more, say 10, 12, or 16 bits at a minimum of 4:2:2 subsampling. At 24 or 30 fps there is enough band width to up the bits and subsampling to make us happier than pigs taking a mud bath. We are basically simple nerds.
antorsae, buzzard767 and Manni01 like this.
Mark Haflich
post #3643 of 3651 Old 09-30-2014, 09:46 AM
rak306's Avatar
Quoted: 17 Post(s)
I don't understand why the cry for 4:4:4 or even 4:2:2. Are there even any movies shot in 4:4:4?
Your high end Nikon and Cannon still cameras have bayer color matrix resulting in 4 green pixels for every 2 blue and 2 red pixels.
Redraw and Arriraw digital movie camera recording formats - both record the raw sensor directly - and both have bayer sensors.
Now I understand need for 10 bit video (possible even 12 bit). But even here, proper dithering would eliminate banding on 8 bit.
M_Coupe likes this.
rak306 is offline
post #3644 of 3651 Old 09-30-2014, 01:20 PM
Quoted: 446 Post(s)
Liked: 489
4:2:0 was chosen in order to conserve bandwidth and not cause a large drop in perceived color quality. Thanks our eyes for not being color sensitive to blue. the errors cause by 4:2:0 are significant but not extremely noticeable EXCEPT when viewed in direct comparison. We know even though the non nerds don't know. What would be better? Going to 10 bits or upping the chroma subsampling to 4:2::2
Our color rabbi, Joe Kane, says up the subsampling. We don't like dither because dither is like adding random noise just like an off topic post here. Noise is not good unless it is generated by an Atmos generator and bounced off the ceiling or just coming from ceiling mounted speakers.
Mark Haflich
post #3645 of 3651 Old 09-30-2014, 02:17 PM
rak306's Avatar
Quoted: 17 Post(s)
We don't like dither because dither is like adding random noise just l;ike an off topic post here. Noise is not good unless it is generated by an Atmos generator and bounced off the ceiling or just coming from ceiling mounted speakers.
The additional noise added by dithering gets distributed uniformly across spatial frequency and is no where near as objectionable as banding. All digital systems should be random at the LSB. It can be natural (from the signal), or added noise. It is necessary to distribute the "error" uniformly over the frequency band. Sure 10bit is better but 8 bit can be very good.
You mostly see banding is computer generated imagery. On TV commercials it's often in a color gradient. Have you ever noticed banding from your Nikon SLR when displayed on your (8bit color) PC?
rak306 is offline
post #3646 of 3651 Old 09-30-2014, 05:29 PM
Thanks Mark for clarifying the comments. I have to decide which AV receiver to purchase which would allow me to connect multiple sources, HTCP and 4k server, to the 600 ES hdmi input 2.
post #3647 of 3651 Old 09-30-2014, 05:34 PM
Quoted: 446 Post(s)
Liked: 489
I do see some banding on my VPL-vw1100ES but that is white banding caused by the power supply interacting with the arc flash protection circuitry. It could have been fixed in the 1100ES but it wasn't. Likely a new power supply design would have been needed. But it is hardly noticeable unless you know where it is and are looking for it.
I do see some color banding from time to time but it can be eliminated by the smooth graduation toggle (three levels of settings) which I suspect may introduce some dither.
For photos displayed on my PC, I have not noticed banding.
Mark Haflich
post #3648 of 3651 Old Yesterday, 05:02 PM
hwoarang's Avatar
Good to see some familiar names on here. Hi Mark! I was one of the first owners of the projector. I've had it for almost a year now and I have to admit, it's amazing. I had some acclamation issues in the beginning, but once overcome, i was blown away. As more tech info has developed on HDMI 2.0, I had a few questions myself.
My setup is the VW600, a 120" 2:35 Firehawk G4. Everything is being routed through a Yamah RX-V675, with Redmire HDMI cables @ 10gb/s. My sources are the puck, PS4 and Xbox one.
My questions are these:
1) Is the Yamaha receiver which has either HDMI 1.4a or b, affecting my video quality at all? I have it set to 4k pass-through on the receiver.
2) Will I see a boost in quality if I upgrade to a HDMI 2.0 receiver?
3) Is the 60 frames advantage of HDMI 2.0 really only for gaming?
4) Does the 600's HDMI support 8 or 10-bit colour, and again, is this reason enough to upgrade the receiver if your source is the PS4 and puck?
5) Any word on if Sony is going to update the original puck to get us some Netflix 4K? If not, that's some real ********.
6) Can someone recommend a calibrator in LA?
6) Anyone live in LA and want to see this beast? Come over.
I'm hoping the PS4 will at least pseudo support 4K blu ray, or they may do what xbox did and release another version with HDMI 2.0 down the line. Either way, help with the above questions would be very much appreciated. I'm also greatful that this years line up of projectors doesn't over shadow the 600; if anything, it highlights how good it is. I feel better about my investment.
Off topic, the series "Dusk till Dawn" on Netflix is awesome and the quality is fantastic, particularly for streaming. It's the best streaming I've seen yet. Clone wars also looked great!! I also wanted to offer that the firmware update on the Projector, receiver and the PS4 have been extremely welcome. There has been a noticeable improvement from what was already amazing. The PS4 blu ray and streaming quality has gotten better and better with the updates.
hwoarang is offline
post #3649 of 3651 Old Yesterday, 05:49 PM
Quoted: 446 Post(s)
Liked: 489
I want to watch the NL MLB wild card game now but I will answer more later.
As to the first question, try physically bypassing the receiver and make you own video determination.
4K 60 obviously needed if you want to upscale HD television. You must feedUHD or 4K into the projector at 60 or you will be dropping every other frame if you feed it in at 30. So 4K 60 in is very important. For movies, not. They are 24 fps and accepting 60 in is not needed for that.
Mark Haflich
post #3650 of 3651 Old Yesterday, 06:11 PM
rak306's Avatar
Quoted: 17 Post(s)
From the Sony Press release at Cedia:
"... the VPL-VW1100ES and VPL-VW600ES have been further enhanced by new calibration software, which takes full advantage of this capability, via a new PC application. ..."
Any idea what this means, and does it involve new firmware on the projectors?
rak306 is offline
post #3651 of 3651 Old Yesterday, 08:04 PM
hwoarang's Avatar
We can always count on you Mark. Sorry to read about your dog. Thats horrible. My Boxer/Ridgeback rescue, Nala, is my baby. I know the day will come, but I try not to think about it. I look forward to reading the rest when you have time.
hwoarang is offline
Sony Vpl Vw500es , Sony Vpl Vw1000es Projector , Sony Fmp X1 4k Ultra Hd Media Player
