Official Sony VPL-VW500ES / VW600ES 4K Projector Thread - Page 131 - AVS Forum
 115Likes
post #3901 of 3925 Old 11-02-2014, 01:09 PM
AVS Club Gold
chiliman's Avatar
Any input on this unit vs the Marantz 11s2? Love my Marantz but upgrade bugs do bite occasionally.
chiliman is offline
post #3902 of 3925 Old 11-02-2014, 01:38 PM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 604 Post(s)
Liked: 516
The Sony has higher resolution, better contrast and a ton more light output. Though the Marantz is a good projector, I would not put it in the same league as the Sony. I had to use a 106" HP (2.8 gain) screen with my Marantz and I light up a 9' wide 0.85 gain screen with my Sony. If we can help you, give us a call.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, BG Radia, SVS & Def Tech, Denon, Marantz & Yamaha .
AV Science Sales 5 is online now
post #3903 of 3925 Old 11-02-2014, 01:56 PM
AVS Club Gold
chiliman's Avatar
Purchased my current set up from AVS. The Marantz on a Stewart Studiotech 130 235:1 screen. Have always been very pleased. Will shoot a PM.
chiliman is offline
post #3904 of 3925 Old 11-02-2014, 03:55 PM
AVS Club Gold
Quoted: 604 Post(s)
Liked: 516
Went to look at your room, but the "The Room" link did not work.
post #3905 of 3925 Old 11-02-2014, 06:52 PM
pevco's Avatar
Is there a page with settings for the Sony 600ES, and or preferred set up selections for new install ?
pevco is offline
post #3906 of 3925 Old 11-03-2014, 03:50 AM
Canary_Jules's Avatar
Just a quick note about the new firmware. I noticed that my panel adjustments had been reset after applying. It's worth checking to see whether yours have been reset as well. Also, the update has cured a handshake issue I was having with my PS3 where the latter would repeatedly report 'out of range' and would take an age to connect. Problem was fixed with the update - which is very welcome. The new gamma adjustment software works a treat too. So much easier to connect and use than the old Image Director. I have dialled in a BT1886 gamma on my VW500 and it looks superb. Thanks Sony.
Canary_Jules is offline
post #3907 of 3925 Old 11-03-2014, 06:44 AM
egrady's Avatar
Not that I could find. But, check out the review by Sound and Vision magazine. Their setting worked pretty well, particularly for color. I had to adjust the brightness and contrast some as my screen, throw and room are different. Still, their setting would be a good place to start.
egrady is offline
post #3908 of 3925 Old 11-04-2014, 07:32 PM
subhash_i's Avatar
Thanks to Mike@avscience i got my 600es installed few days ago and very happy with it.Bought all my HT components from Mike along with DNP supernova screen,onkyo TX-838 and speakers.My room has little light in day.So day time viewing is little challenging but night time viewing is great.Mike helped me a great deal getting all equipment at great price and even finding an installer to come to my home and do the installation.My cousin also ended up buying his JVC4910 and all his equipment from Mike.Can't thank him enough for his excellent service.
subhash_i is offline
post #3909 of 3925 Old 11-04-2014, 08:02 PM
AVS Club Gold
Quoted: 604 Post(s)
Liked: 516
Thank you. You are very welcome.
post #3910 of 3925 Old 11-07-2014, 11:46 AM
Liked: 0
Hello.
I've just bought and installed my VW500 and upgraded the unit to 1.100. If anyone else is having issues upgrading, I think the USB-stick / hard disk needs to be FAT-formatted before it accepts it (not FAT32). However I'm not familiar with the gamma adjustment software. Is it separate software that you can download and do you need to use network access to use it? I'd love to test it.
Can you give me any help where I can get it and how to use it?
best regards
AM
Filmmaster is offline
post #3911 of 3925 Old 11-07-2014, 12:07 PM
Originally Posted by Filmmaster View Post
Hello.
best regards
AM
Hi. The software is available on the Sony Professional website but you have to be a registered user to be able to download. The software is available on the Partners tab on this page but you won't be able to see the tab unless you're registered and logged in.
post #3912 of 3925 Old 11-07-2014, 01:09 PM
Michael9009's Avatar
Quoted: 60 Post(s)
Errr...no. I formatted my USB stick on my MacBook Pro in NTFS using Tuxera NTFS and it worked like a charm.
Welcome to the Forum!
Michael9009 is online now
post #3913 of 3925 Old 11-07-2014, 01:28 PM
Liked: 0
Good to know. Even as a long time mac user I have never formatted anything to NTFS using mac. Always felt those NTFS-programs weren't reliable enough. Maybe I should test this one.
Thank you!
post #3914 of 3925 Old 11-07-2014, 08:46 PM
Quoted: 60 Post(s)
Thank you!
I've only used Tuxera NTFS and it has worked well. Voilá!
Name:	Screen Shot 2014-11-07 at 22.39.58.jpg
post #3915 of 3925 Old 11-10-2014, 07:57 PM
wagnerc's Avatar
Just installed the new firmware. It reset my settings...
wagnerc is offline
post #3916 of 3925 Old 11-12-2014, 01:44 AM
RealJEDI's Avatar
Strange. Did the firmware update twice (1.005 -> 1.006 -> 1.100) and it kept the settings both times.
Cheers, Alex
RealJEDI is offline
post #3917 of 3925 Old 11-12-2014, 05:40 AM
RioBar4U's Avatar
I also updated the firmeware without change...
RioBar4U is offline
post #3918 of 3925 Old 11-12-2014, 11:23 AM
kjlewie's Avatar
Quoted: 12 Post(s)
I completed the firmware update two days ago. I just rechecked the settings on my 600 and they are unchanged here as well.
The improved lag is quite noticeable. Sadly, my daughter continues to thoroughly pound me in FIFA for the playstation on the 600 just as easily as she did on the TV upstairs.
Clearly, I'm a man of action - just give me a few minutes to think about it.
Lewis Family Cinema 1.0
Lewis Family Cinema 2.0
kjlewie is offline
post #3919 of 3925 Old 11-12-2014, 01:04 PM
AVS Club Gold
Quoted: 604 Post(s)
Liked: 516
Now if there was a way that she had the added lag and you didn't, then maybe you would stand a chance.
kjlewie likes this.
post #3920 of 3925 Old 11-15-2014, 12:55 AM
Manni01's Avatar
Quoted: 221 Post(s)
Liked: 160
I have a favor to ask 500ES owners.
I'm hearing that HDCP 2.2 wouldn't be compatible with legacy (non HDCP 2.2 compliant) sources, which would be pure non sense, but sadly not the first time the industry does something crazy.
Has anyone tried to connect a non HDCP 2.2 compliant device in HDMI 2, and does it work? It would be a relief if it was the case.
[EDIT] Forget it, sadly it's confirmed:
Denon AVR-X7200W 9.2/13.2ch 2014/2015 Receiver Details-
Manni01 is online now
post #3921 of 3925 Old 11-15-2014, 07:46 AM
AVS Club Gold
Quoted: 604 Post(s)
Liked: 516
I have connected to HDMI port #2 and feed the projector 1080P content without any problem.
Manni01 likes this.
post #3922 of 3925 Old 11-15-2014, 09:18 AM
Manni01's Avatar
Quoted: 221 Post(s)
Liked: 160
Thanks Mike, that's good news. I hope this will translate when an HDCP 2.2 AVR is in the chain.
post #3923 of 3925 Old 11-15-2014, 10:28 AM
Andreas21's Avatar
Quoted: 127 Post(s)
Liked: 93
Same here with the VW1100.
Manni01 likes this.
Regards
Andreas
My Homecinema
Andreas21 is online now
post #3924 of 3925 Old 11-16-2014, 08:19 AM
clausdk's Avatar
Quoted: 70 Post(s)
Liked: 44
Anyone have experience with the lens at near max lens shift vertical shelf mounted?
Planning my rear shelve and it would be practical to mount as high as possible. For scope movies it wont be an issue but zooming to 16:9 on my scope screen will be the limiting factor. I am planning to use 70% out of 80% max. Recommendations?
My previous projector infocus sp8602 was at it's max vertical lens shift and zero problems with focus etc.
clausdk is online now
post #3925 of 3925 Old 11-16-2014, 05:57 PM
me23's Avatar
It is very noticeable. I was considering a second projector for my xbox. Not now. Very pleased.
me23 is offline
Sony Vpl Vw500es , Sony Vpl Vw1000es Projector , Sony Fmp X1 4k Ultra Hd Media Player
